Sharp LC-60EQ10U no display code 3-1
  • Zduncan8
    • Mar 2018
    • 5
    I have a Sharp LC-60EQ10U that does not turn on. Minutes after plugging it in. The power light blinks 3 slow and 1 fast. I have replaced the power board, and still the same issue. Anything I'm missing or do I need to replace the main board? I'm not too tech savvy, just looked like a pretty basic fix. Any help is appreciated.
  • nomoresonys
    • 12330
    • U.S.
    Re: Sharp LC-60EQ10U no display code 3-1
    You may have gotten a faulty board.
    • nomoresonys
      • 12330
      • U.S.
      https://www.youtube.com/watch?v=HaKxWCEaAcw
      This guy fixed his with a new powersupply.
      • nomoresonys
        • 12330
        • U.S.
        https://www.youtube.com/watch?v=mUvclBfaMXg power supply testing, BE VERY CAREFUL WITH POWERSUPPLY, VOLTAGE ON PRIMARY/HOT SIDE CAN BE DEADLY, THE CAPACITORS CAN HOLD A VERY BIG CHARGE LONG AFTER TV HAS BEEN UNPLUGGED.
        • Zduncan8
          • Mar 2018
          • 5
          Yeah I watched that video. Is the power board the only cause of this code? I plan to test the new power board asap and see if it's doing what it's supposed to. Just curious what the other issue(s) could be.
          • Zduncan8
            • Mar 2018
            • 5
            I went to test the board and I am having trouble determining which pin is what. As the pins dont seem to be in any specific order counting them (maybe I'm just overlooking something). I have located the PS ON pin, and it reads 5 volts. I am unable to figure out which pin to jump it too though. As the video lists it as 5VSB, and I do not have that pin. If someone could guide me on which pin to jumper it to, and how the pins are counted itd be much appreciated. I will attach pictures of the labeling. And which pin is the PS ON.
            • Zduncan8
              • Mar 2018
              • 5
              Here is the labeling and pin location.
                https://www.badcaps.net/forum/attach...3&d=1522413928
                The exposed pins you can see from the top side of the board are the ODD number pins, the EVEN number pin (you can see where pin 1 is as marked on the board) you will have to access them from the bottom side of the board or from the back side of the connector using probe with skinny tips.
                • amfm144
                  • Apr 2018
                  • 6
                  I have the same TV and the same issue too. I tested all the pins and was able to pin point 2 pins whose volts did not match with what was listed.
                  Pin 1 & 2 shows 12V on the board but when I tested it Pin 1 only gave me a little more 7V and Pin 2 was 0V.
                  So, does that mean the issue is with both Power and Main boards ?
                  • amfm144
                    • Apr 2018
                    • 6
                    Sorry, correction Pin 1 gave me a little more than 7V and Pin 2 as 0V
                      PNL-12V Pin 1 and pin 2 of the connector PD are electrically connected together so pin 2 should also show the same reading as pin 1.
                      The 7V PNL-12V output is more likely due to common fails switched 12V LDO regulator IC Q7120 (KIA378R12PI).
                      See this thread here:
                      https://www.badcaps.net/forum/showth...602#post592602
                      • amfm144
                        • Apr 2018
                        • 6
                        Thank you so much for the quick response.
                        Is this regulator located on the power board ? If yes, installing a new power board will fix this issue ?
                          Yes it is on the power supply board, just look for that part I give the info about.
                          That should fix the PNL-12V power supply problem, but I do not what else is wrong with your TV beside the bad PNL-12V, you have to have good power supply first to know if there are other problems with other boards or not.
                          Do you have tools and know how to solder?
                          • amfm144
                            • Apr 2018
                            • 6
                            Yeah that makes sense. Unfortunately, I don't. I'm an IT guy so I have 0 experience when it comes to this stuff. Everything I have done so far is from online reading and research.
                            Let me see if I can find any tools and tutorial for soldering.
                              I would buy the part and then take the board to good local electronic repair shop and have them install the new part.
                              • amfm144
                                • Apr 2018
                                • 6
                                That's a good idea. Thanks a lot.
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  +10...It would be a lot less expensive rather than replacing the PSU. Try to fix the board first and if that does not resolve the PSU issue, then look for anew board.
                                  • amfm144
                                    • Apr 2018
                                    • 6
                                    I ended up getting a used power board from ebay and it worked like a charm. Thank you for all your help.
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      Thanks for the follow up.
                                      • neilc6
                                        • Nov 2015
                                        • 1550
                                        Got this model and the owner had tried a second power supply. Both generate a 3-1 error code. Measured the output of Q7120 and it is 12V on the output and not low on the one ps currently installed. TV doesn't turn on and no backlight. Backlights test good with LED tester.
                                        • valvashon
                                          Sharp R-930CS microwave/convection oven, dim display
                                          by valvashon
                                          Older microwave/convection oven I picked for free on Marketplace. Previous owner replaced turntable motor which didn't fit in the mounting hole properly. Shaft was at an angle causing plastic thing that fits onto it to eventually break. Filed the hole bigger, fitted the motor correctly, put on a new plastic thing, all (almost) is OK.
                                          The fluorescent display is quite dim. The camera doesn't see what the eye sees so these pictures are brighter than what the display really looks like:
                                          As you can see even from these pictures, the tops and bottoms of the...
                                          11-14-2025, 12:34 PM
                                        • eurgenca
                                          Philips TV 43pus7505 setting display option code, help please.
                                          by eurgenca
                                          Hello.
                                          I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
                                          So I ordered a used CPU board, and now I have wired picture.
                                          I think the problem lies in display option code. According to SM, the command for setting
                                          display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
                                          But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
                                          or can I manually edit option code in SAM.​
                                          10-07-2024, 02:09 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • lanovey
                                          SF314-41 BIOS without internal display
                                          by lanovey
                                          Hello there,
                                          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                                          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                                          06-13-2025, 02:38 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
