HP DV6-3141se wont power up with charger
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Hello all,
    I'm in a trouble please help me to sort it out. . . I'm working on a HP DV6-31411se which is not turning on with charger but it is perfectly turning on with battery. . . I checked the motherboard number is DA0LX6MB6H1 REV : H.
    When i check the VIN with connecting the charger. There are no voltages. I'm gonna upload the schematic diagram, please help me. . .
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Re: HP DV6-3141se wont power up with charger
    hello all,
    I've already checked voltages on PQ42, No Voltage on Pin # 3, and Pin # 1 Present when i connect the charger.
    But when i connect battery and check the voltages, there are 11 voltages on Pin # 4 and pin # 3 but no voltages on pin # 1. But with the battery laptop turning on perfectly. . .
    • sonunigam
      • Aug 2013
      • 151
      • Pakistan
      PQ 42 is NIKOS P0603BDG. . . .
      • polytek
        • Dec 2013
        • 496
        • TUNISIA
        hi,
        are you tried with another dc adaptor ?
        it can be adaptor problem, check the Id signal is it correct ?
        • FShahid
          • Nov 2012
          • 57
          • United Kingdom
          Some newer DV series, ProBoook series and G series like G62 are picky about ac charger, they will not show any signs of power until you connect a genuine 90W charger. I would say to try different charger first.
          • Levi
            • May 2014
            • 59
            • Ghana
            Soninugum, check pd20 is 19v crosses, if not change it, nd check pc180 if it is shorted to ground. if u v got 19v on pc180 then i will suggest u change pq42, it could probably be opened.
            • sonunigam
              • Aug 2013
              • 151
              • Pakistan
              Hey all,
              I'm gonna attach an image in which i explained on a page number # 42. When i remove Resistor PR12 (100 Ohms), The voltages present on PQ42's Gate Pin #1 +VH28.. And voltages now present everywhere. But Laptop is not turning on still. But when i connect this resistor again there are no voltages......
              Please let me know what should i do?
              One more thing, i changed ENE KB3926QF D2.
              But problem still exit.
              • sonunigam
                • Aug 2013
                • 151
                • Pakistan
                The Image is here. Sorry i couldn't attach before.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3607
                  • slovakia
                  i think u have shorted/bad pq4.
                  • sonunigam
                    • Aug 2013
                    • 151
                    • Pakistan
                    Hello KTMMotcross,
                    I've changed it already, But it is not faulty. . . .
                    any other suggestion????
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3607
                      • slovakia
                      so there must be something with its base signal. ACOK# must be 0V. check pq3, acok_in, acin
                      • sonunigam
                        • Aug 2013
                        • 151
                        • Pakistan
                        Hey Ktmmotocross,
                        I'm gonna sending you an attachment, Please check this.
                        • sonunigam
                          • Aug 2013
                          • 151
                          • Pakistan
                          One more thing, I've changed R5 because it was devalued, So i changed it with 100 Ohms the original one, but nothing happened positive.
                          Any help?
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3607
                            • slovakia
                            when connect charger pq3 must short that 8.9V to ground. chck for acokin and acin signals
                            • sonunigam
                              • Aug 2013
                              • 151
                              • Pakistan
                              Hello Ktmmotocross,
                              I've checked everything even every single component. But not successful. I've checked every single Resistor, Capacitor, Diode, Transistor, MOSFET. . . .
                              Any other help?????
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3607
                                • slovakia
                                check acok and acin signals. u must have signal on pq3 to short acok# to 0V
                                • sonunigam
                                  • Aug 2013
                                  • 151
                                  • Pakistan
                                  How to check those signals? Can u explain me????
                                  Actually i'm really tired to check this one. But i've to solve it because this one is 3rd machine which has a same problem. . . .
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3607
                                    • slovakia
                                    measure its voltage to ground, with attached charger
                                    • sonunigam
                                      • Aug 2013
                                      • 151
                                      • Pakistan
                                      i do't know what r u saying? If u send me any pic to check signal it would be great great support to me. . . .
                                      Thanks a lot
                                      • dycc
                                        Vision
                                        • Nov 2011
                                        • 625
                                        • Côte d'Ivoire
                                        Remove pq47 and plug laptop. If it turn on change pq47 . This mosfet have sometime something that i call gate issue . As it share the gate line (batdis_g) with pq42 it may block it.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Mita99
                                          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                          by Mita99
                                          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                          04-27-2025, 07:20 PM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • DenK
                                          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                          by DenK
                                          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                          12-06-2024, 01:29 AM
