HP DV6-3141se wont power up with charger
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: HP DV6-3141se wont power up with charger
    https://www.badcaps.net/forum/showthread.php?t=44806
    • sonunigam
      • Aug 2013
      • 151
      • Pakistan
      Hello Dycc,
      I did it but not successful. I removed PQ47 and plug the charger but no voltages on PQ4's Pin # 3. But as i mentioned already when i remove the resistor PR12 (100 Ohms). The Supply everywhere, VIN voltages present but not turning on Laptop. . I've also changed PQ3, PQ4 but all was vain. Now, i'm very tired with this motherboard and gonna return back to the customer.
      If anyone will face this problem and have a solution please let me know. I'll be grateful to him.....
      Thanks guys for your precious time....
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        normally if ACIN signal is low computer will not turn on even if you have 19v at pq42 pin 3 .
        so check if you have 19v at PU5's pin 1 (DCIN) and
        ACIN (PU5's pin 9)= 3v
        • Attif
          Attif
          • 49
          • pakistan
          my dear brother first u connect the d.c charger in d.c pin. check near power FET ( near the d.c jack ) in and out voltage coming or not?? if the power FET not give out put 19v ,change it,if u have no power FET u can jump this 19v FET. take care have a nice day
          • diegotrex
            • Apr 2018
            • Italy
            Hi from a new member
            I'm trying to repair my HP Pavillion DV6,it has a similar fault with a small difference:
            I have 19v at PU5's pin 1 (DCIN) but ACIN (PU5's pin 9)= 0v
            Does this has any meaning?I'm using appropriate power supply,but the situation is the same if i use a bench power supply,the current absorption is 0 mA
            The 19 is present in many points of the board ande the 3 connections of the power jack look good.
            Any hint?Thanks
            • pyry
              • Dec 2015
              • 37
              • Mexico
              #26
              Follow the arrows
              • ronelex
                • Oct 2016
                • 195
                • Philippines
                #27
                Originally posted by pyry
                Follow the arrows
                Ive got same issue which is Missing ACIN
                I manage to have a good board and the difference on voltage reading on my defective one
                AD_AIR- 0.846V Bad / 2.6V ok
                AD_TYPE/ID - 0.746V bad/ normal 1.156V ok
                I got problem on finding the voltage divider for the AD_air because of the lack of boardview of this unit
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • Mita99
                  Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                  by Mita99
                  Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                  Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                  Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                  04-27-2025, 07:20 PM
                • Capacitorial
                  Powersupply has all the voltages - Monitor still no power
                  by Capacitorial
                  Hello guys,
                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                  The weird thing is, that the Power LED is powered over the TCON board.
                  On The TCON...
                  12-28-2024, 02:12 PM
                  03-31-2024, 02:12 PM
                • DenK
                  Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                  by DenK
                  Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                  1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                  12-06-2024, 01:29 AM
