VIZIO E500i-A0 No Picture With Sound
  • carpenter183
    • Jan 2015
    • 15
    My issue is no picture. When turning on the TV, the screen will show the VIZIO logo on the screen, but will immediately go black. The LED back light seems to die suddenly. I tried the flashlight trick, but no picture is being shown that I could see. I have sound, the led indicator light on the front is working. I took the back off and looked for bulging caps or burn marks, but there are no signs of damaged parts. I have not checked any voltages from the power supply yet, but I intend too when I get time. I believe the LED Driver board is built into the power supply, so could that be the culprit? Any help and advice is welcome. Thanks
  • carpenter183
    • Jan 2015
    • 15
    Re: VIZIO E500i-A0 No Picture With Sound
    I checked all the voltages on the power supply connector to the main logic board and all were good. I believe the back light LEDs are powered by the power supply (led driver), so could that be the issue?
    • carpenter183
      • Jan 2015
      • 15
      Bump. Anybody got some suggestions?
      • MagicSmoke
        • Feb 2011
        • 275
        If one or more of the led's failed, then PSU will sense problem and shut down B/light circuit. Or a short in the wiring.
        I'm working on a Westinghouse that has three bad led's on one strip. PSU shuts down B/light circuit but not the other voltages. So it still has sound and pic, just cant see it.
        Edit I've tried the flashlight trick, didn't seem to work for me. Now I use a 250 watt halogen lamp if it's got a picture then I can see it.
          Check the DC Voltages on the LED+ pins of that 4-pin connector when you first turn on the TV to see if there is any LED drive Voltage on the pins.
          That section of the board looks like it got hot.
          There are two large electrolytics caps (c??4), what are their Voltage ratings? I believe they are the filter caps for the boosted voltage power supply for the LEDs.
          • carpenter183
            • Jan 2015
            • 15
            I will get right on it budm. I will post results.
            • carpenter183
              • Jan 2015
              • 15
              Led1- : 10.5v
              Led1+ : 66.7v
              Led2- : 4.6v
              Led2+ : 66.7
              The led+ readings started much higher like 100+ volts but started to decrease and settle at 66.7v.
              • carpenter183
                • Jan 2015
                • 15
                The caps are C304 and C404 both 200v 47uf. I noticed the TV seems to shut off after about 10 minutes.
                  That sounds like you have open LEDs that is why the Voltage went up high (no load due to open LED) and then it goes into protection mode.
                  • carpenter183
                    • Jan 2015
                    • 15
                    Here is a close-up.
                    • carpenter183
                      • Jan 2015
                      • 15
                      So, what you are saying is I need to replace the string of LEDs in the panel? Or find the open and repair it? What level of difficulty is this?
                        It depends on how the panel is put together, definitely not for beginner.
                        Once you get to the LED assemblies then you will test one by one or you may be able to see the bad one that has sign of over heating.
                        Failed LEDs are very common for these LED backlghts TV, it is so sad that they do want to build something that last any more.
                        • carpenter183
                          • Jan 2015
                          • 15
                          This TV is only 2 years old. Manufactured in 2013. Sam's club special, but no warranty still valid. I feel duped.
                          • MagicSmoke
                            • Feb 2011
                            • 275
                            Taking the panel apart and then reassembling it requires a lot of patience, otherwise it will crack.
                            Some like the westinghouse I just fixed use the front bezel to hold the panel to the chassis. If I had not looked and been cautious then the panel would have slid out and cracked. The 39" panel was all I wanted to handle by myself, I would not try a 50" without good help.
                            Some hold in with plastic strips, I'm sure there are a lot of variations.
                            The 2nd main thing is to be careful of the tabs bonded to the panel, any damage or dislocation renders panel inoperative.
                            It can be done, replacing individual led's on the strips is not easy, it is much simpler just to replace the bad strip/s.
                            And it's not just the bargain TV's doing it, some of the high end Samsungs, Vizio's and others have similar problems.
                            It looks like you can try to jumper the PS-on and BL-on to 5v Stby to see if B/light will stay on or still shuts off. If it stays on then might be eeprom related but if it shuts off then led's are bad or similar fault.
                            • carpenter183
                              • Jan 2015
                              • 15
                              For some reason, the backlight has quit all together. At first, the backlight would show a picture (the VIZIO emblem) for a quick couple of seconds, then disappear. Now no backlight at all.
                              • zukdj
                                • Jun 2012
                                • 104
                                I have a similar problem on the same model E500i-A0 except my backlights strobe every 2 or so seconds, has anyone seen the strobing issue before? I also get no picture that I can see
                                • zukdj
                                  • Jun 2012
                                  • 104
                                  bump!!!
                                  • zukdj
                                    • Jun 2012
                                    • 104
                                    With my TV plugged in and powered on I get a rolling 120-130volts at both LED+, if I unplug the backlights the voltage doesn't change so I can only assume the backlights are shot, any input? with the backlights plugged in they strobe every 2 seconds or so.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Looks like another case of Led failure from what you say.
                                      • zukdj
                                        • Jun 2012
                                        • 104
                                        I just checked negative (-) and I get minimal rolling power there as well, LED1 - 50-42, and LED2 50-29 rolling, definitely think it needs new LEDS. any idea where I can get the LEDS reasonable for my make and model screen LG LC500DUG-JFR1?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • jord4231
                                          Toshiba 37AV500A Regza TV good power supply no sound no picture
                                          by jord4231
                                          Hi Everyone,
                                          I'm working on a Toshiba 37AV500A Regza TV.
                                          The issue:
                                          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
                                          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
                                          I checked the PSU voltages and everything looked good.
                                          No bulging caps or signs of heat.
                                          24v aud = 24.41v
                                          12v = 11.98v
                                          5v = 5.062
                                          p_o/f = Goes high...
                                          03-29-2022, 09:21 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
