Dell 3008wfp faulty power supply
  • Maxidud2000
    • Nov 2012
    • 3
    • Malta
    #221
    Re: Dell 3008wfp faulty power supply
    Hi Guys,
    Today I got a Dell 3008wfp without a picture but the Blue power LED still lights up and therefore I dont think that it is power related problem. I read all the 11 pages of contribution about this thread and am happy that there were several who managed to repair their TV's. Unfortunately I did not come across anyone having my problem that is power ok (Blue LED on) but without any picture. Can anyone pls give me an indication what to chk or maybe D22 could still be the faulty component ?
    Many thanks and keep up this excellent site.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #222
      First test would be connect it up to a known working source - pc with a vivid picture.
      Can you see a very dark image on screen perhaps check with a flashlight at different angles.
      Does the panel flash on for even a second when you first switch it on.?
      Can you switch it off with the power button?
      Check out the thread for instructions on how to dismantle the set - it appears to be rather difficult. Then post pictures
      Welcome to the forum-
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      https://www.badcaps.net/forum/attach...7&d=1280167246
      It will be useful if you can say a bit about yourself - skills tools etc.
      • layte
        • Oct 2012
        • 1
        My 3008 died a couple of months ago, but thanks to a combination of this thread and another forum it was brought back to life yesterday. So I would just like to give a huge thanks to everyone involved.
        Surely with the number of monitors dying (just outside of the 3 year warranty....) with the exact same problem (the D22) Dell should be offering to repair them as they obviously used parts that were not of sufficient quality for the job.
        • Maxidud2000
          • Nov 2012
          • 3
          • Malta
          #224
          Hi thanks for your reply.
          A brief about myself: Im a computer tech with years of experience in repairs. Component level trouble shooting with very good soldering experience even on SMD's.
          The Dell 3008 has only the Blue LED that comes on when inserting the mains plug but otherwise no flicker on the screen with or without an input source. It does not seem to be a back-light problem either. At present I'm not near the monitor but if I'm not mistaken the blue power LED won't switch off when the power button is pressed.
          The unit is still dismantled and it was not an easy task especially to remove the plastic front trim. I will try and upload images later. In the mean time I would like to know if another other one had suffered the same problem on this unit. ie: Blue power LED 'on' with no picture.
          Thanks to ALL.....
          • jetadm123
            • 2169
            #225
            Maxidud2000- sounds like you're at least getting voltage to the logic board. with your monitor hooked up to a computer in a darkened room, try shining a bright light at an angle against the screen to see if you can see an image of the Windows desktop. If yes, then try checking the fuse and voltage (at the fuse) of the inverter board.
            • Maxidud2000
              • Nov 2012
              • 3
              • Malta
              #226
              jetadmin, thank you for your feedback but as explained above I dont think its an inverter problem. Fuse checked and found ok. I will try to monitor any DC voltages present and will let you know. Again I would like to ask if any other person experienced this type of fault on the Dell 3008, with a power LED on but still no pic. Help greatly appreciated. Thanks
                For the backlights to work, it needs 24vdc for power from power supply and BL_ON (Backlights ON) signal from the main board, so you need to verify if you have both of them.
                • Threat007
                  • Nov 2012
                  • 1
                  • usa
                  #228
                  Same exact issue as Maxidud2000 here. No signal coming to monitor including from on-screen menus. Back light is fully lit and obviously on (can light up a dark room). I will be doing the power fix d22 diode anyway as it is a know issue. I am not convinced that is the whole issue in this scenario though. Ideas?
                    If you have backlights but no pictures, then it can be that the main baord is not sending either 5VDC or 12VDC to power the T-CON board or the T-CON may have failed due to blow surface mounted fuse or regulator, that will be the next thng to check.
                    • kazkasneaiskaus
                      • Nov 2012
                      • 8
                      • Lithuania
                      #230
                      The same problem as Maxidud2000. The power led is on ant background lights on but no picture, even menu. Please share how did you solve this problem.
                      Threat007 did you change diode? Did it help?
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #231
                        kazkasneaiskaus
                        Please can you update your profile with country and mains voltage
                        • kazkasneaiskaus
                          • Nov 2012
                          • 8
                          • Lithuania
                          #232
                          I took out D22 diode and checked it. Seems it works properly. The resistance to one direction to both diodes are about 300 ohm to another infinite.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #233
                            Thanks for updating - Yes D22 looks ok. Have you tried t find the fuses on the Panel Board (Tcon) If you can post a picture ( may have to be 3 to get it all.
                            • kazkasneaiskaus
                              • Nov 2012
                              • 8
                              • Lithuania
                              #234
                              I dont't really know where these fuses are... are they smd parts? Do you have a picture where are they located?
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #235
                                They will be smd - that is why I was asking you for a picture and I can mark them on it - Do you not have a camera.
                                • kazkasneaiskaus
                                  • Nov 2012
                                  • 8
                                  • Lithuania
                                  #236
                                  These fuses? I checked F1 and it seems to be bad.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #237
                                    Yes - thats the sort you are looking for. To test set meter on to Ohms
                                    and touch the probes together - should read 0.00 ohms or very near.
                                    Then with no power to the board touch probes to each end of the fuse and post the result. Should be the same or very close to touching the probes together.
                                    • kazkasneaiskaus
                                      • Nov 2012
                                      • 8
                                      • Lithuania
                                      #238
                                      I am an electronic engineer and I know how to check fuses how ever thank you for a help.
                                      F1 - 183 kohm
                                      F2 - 0,5 ohm
                                      Obvious that F1 damaged.
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #239
                                        Ok - I think the "N" signifies that is is a 2 amp fuse although all manufacturers do not use the same coding
                                        • kazkasneaiskaus
                                          • Nov 2012
                                          • 8
                                          • Lithuania
                                          #240
                                          It is 2A and 63v it's written under it.
                                          However I noticed another big problem. The cable wich connects the main bord to video imputs board is totally broken. It looks like all wires isolation is crubled. How could it happen? Heat? Sometimes when you search for small things you do't note an obvious things.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Hi everyone,
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • master3112
                                            Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                            by master3112
                                            I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                            Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                            The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                            Yesterday, 01:55 PM
