Magnavox 32MF369B/F7 volume stuck
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    #81
    Re: Magnavox 32MF369B/F7 volume stuck
    Can you use your meter set to ohms and with the set powered off and measure across the solder pads as shown in the photo.
    First connect across Volume Up Button and take a reading without pressing the button and then another reading when pressing the the button.
    Repeat with the Volume Down button.
    Volume Up Not Pressed = xx Volume Up Pressed = yy
    Volume Down Not Pressed = zz Volume Down Pressed = zz
    • hairywbush
      • Dec 2015
      • 88
      This forum is not notifying me of responses anymore!! Sorry about that.
      I used my other multimeter. Looks like it's doing what it's supposed to...
      At your exact points, I got infinite for volume unpressed, and 1.1 for volume up pressed, volume down measured infinite for volume not pressed, and 1.1 for pressed.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #83
        I'll assume that the 1.1 measured is ohms. If so then the buttons are working as they should.
        • hairywbush
          • Dec 2015
          • 88
          yes ohms...and yea that's what I'm saying so what now?
          • dskall
            • Oct 2016
            • 2905
            • usa
            #85
            Have you tried firmware update or reset?
            • hairywbush
              • Dec 2015
              • 88
              how do you do either? and does the reset procedure work with all makes and models?
              • bman4
                • Jul 2015
                • 210
                • canada
                #87
                i think you can turn tv on then disconnect buttons and if it stops get some lubricating crc contact cleaner.
                button might be shot from many hard pressed so i actaully recommend just buying a new button board.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5038
                  • New Zealand
                  #88
                  Considering how many dodgy tactile buttons I have replaced, I'd replace the lot just to see what happens. They don't always test out obviously bad on a multimeter either.
                  Also, it looks like this board uses analogue voltage sensing with the buttons and resistors all in a "ladder" arrangement.
                  This means it's entirely possible for some of the other buttons to go faulty, and cause a completely different button to seem bad, because the IC does not address the buttons individually as it would if they were read digitally.
                  -David VanHorn
                  • hairywbush
                    • Dec 2015
                    • 88
                    was wanting to do this initially, however they are soldered. I think that's where I might be headed real soon though
                    are you saying it might not be the button board? because I get your trickle down effect scenario. how would I know
                    also I'm interested in taking one of the simplest steps such as this reset or update that was mentioned. anyone want to add to that?
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5038
                      • New Zealand
                      #90
                      I'm saying it would not surprise me if the buttons on the button board were faulty.
                      You can buy new switches very cheap to replace them with.
                      -David VanHorn
                      • hairywbush
                        • Dec 2015
                        • 88
                        update
                        I turned the tv on to try something and noticed the volume wasn't showing 100% like it was. I was able to access the menu without it going crazy, however I could not easily access the options 100%. something was still off. So, I went to try and program this universal remote. I got the remote to turn it off but not on so I had to do something else...well anyway, I turned the tv on and it's back to its old self, showing 100 volume and menu going whacky.
                        • hairywbush
                          • Dec 2015
                          • 88
                          bump
                          I want to buy a new button board, but this is the closest I've found https://encompass.com/item/8088635/P...ction_Assembly
                          the site has this listed under my model, but it has extra boards attached.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5038
                            • New Zealand
                            #93
                            There's no need to, just replace the switches with brand new ones and check that the resistors on there haven't failed. If that doesn't fix it, then the problem is something else...
                            If you don't feel confident about the soldering, send it to someone who is. Lots of people on this forum, I'm sure you could find someone to help you out!
                            -David VanHorn
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #94
                              i have now had a few older ccfl tvs where as you say the switch tests fine but set still plays up i replaced all the tactile buttons and cleaned pcb with cleaner to remove all flux etc and set 100% fine afterwards i think ive done 3 now with this type of fault volume always high or low or menu stuck on screen etc
                              • hairywbush
                                • Dec 2015
                                • 88
                                when you say switches, do you mean the buttons, and do you mean all of them?
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5038
                                  • New Zealand
                                  #96
                                  Yeah, it's pretty weird. I've seen it mostly on LCD monitors and even on a cheap CRT TV - and you're right - electrical tests don't usually show anything wrong, either, except for just one button which had (on testing) a very intermittent ~30 Ohm short.
                                  My theory is that they go electrically leaky (for whatever reason - contamination\wear\defect\tin whiskers(?)) just enough to upset the high-impedance inputs or confuse the ADC on the microcontroller.
                                  I also wonder if these buttons expect to be self-cleaning, and if the current through them in these applications is too small to do it.
                                  Yes and likely yes. In my experience, if one has gone bad, the rest often follow suit in quick order. So if you're going to the trouble to replace one, you might as well replace all of them at the same time, and avoid the hassle of having to go back in and replace another a month later. (Lesson I learned from the first time I encountered this problem)
                                  The other problem is, that it's hard to find out which one is actually the problem. Like vinceroger69 also experienced - electrical tests don't typically show any symptoms of a fault, and with the analog resistor ladder\divider types (like yours here) the control which *seems* stuck may not correspond to the actual bad button, because the ADC in the microcontroller doesn't actually know which button it's reading, it just measures the voltage coming out of the string.
                                  When you have several buttons all chained on a 5v or 3.3v supply, the voltage difference to distinguish between each one is pretty small. If a button or buttons is leaky, it throws off the voltage reference and the ADC reads the voltage output as the wrong button.
                                  Therefore I find it much more time-efficient and a way to provide insurance against repeat faults to just replace the whole lot at once.
                                  Of course, the problem might.. MIGHT.. be a bad resistor, maybe one that's gone high in value, but that's pretty unlikely. You could easily verify those with a multimeter though. You'd still have a bad button somewhere though, as a resistor by itself wouldn't cause the control to be stuck, just get read incorrectly.
                                  -David VanHorn
                                  • hairywbush
                                    • Dec 2015
                                    • 88
                                    ok I see what I have to do now. I just have to measure the buttons because there's several different sizes
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5038
                                      • New Zealand
                                      #98
                                      Yes, make sure the actuator (the white plastic bit) is about the same length as the originals. Some slight difference might be OK depending on the tolerance of the case\panel.
                                      The actual button housing is a fairly standard form factor, but check you get the right version (right angle)
                                      Also, bear in mind that stock photos of products are not always accurate, check the datasheet or description to be sure.
                                      -David VanHorn
                                        LCD LED TV Service Menu Codes
                                        ALL LCD LED TV SERVICE MENU CODES
                                        Service Menu Code with Board Name
                                        China Universal Board / Jumper Board Service Menu Code
                                        Changhong Ruba Service Menu Code
                                        Ecostar LED TV Service Menu Code
                                        Orient LED TV Service Menu Code
                                        Haier LED TV Service Menu Code
                                        TCL LED TV Service Menu Code
                                        Samsung LED TV Service Menu Code
                                        LG LED TV Service Menu Code
                                        Videocon LED TV Service Menu Code
                                        Supra LED TV Service Menu Code
                                        Toshiba LED TV Service Menu Code
                                        Symphony LED TV Service Menu Code
                                        Veste/ LED TV Service Menu Code...
                                        10-31-2024, 03:58 AM
                                      • B83C
                                        HP elitebook x360 1040 G5 Stuck at 'Entering setup menu...'
                                        by B83C
                                        Received a faulty HP elitebook from my friend that does not boot up properly. The internal display is broken, so the only way to view the display output is via hdmi. However, when booted up the screen get stuck with 'Entering setup menu...' when esc is pressed upon booting. HP logo isn't displayed on bootup, only black screen, but an underscore cursor appear on top left corner of the screen. Has anyone any idea what could be the culprit here? I have flashed both the EC and BIOS flash but to no avail. The serial number is 5CG9377GCT, and below is the original flash content:
                                        Also the...
                                        02-03-2025, 08:28 PM
                                      • cstout
                                        DeLonghi AC Remote only accepts 3V
                                        by cstout
                                        Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                        The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                        I can't find any schematics...
                                        06-03-2024, 03:53 PM
                                      • notallbad
                                        LG 55LM6200-TA country group/Area option
                                        by notallbad
                                        This is a 2012 LG TV so aware full functionality of the smart functions/apps will be limited however currently unable to get the LG Smart Store.
                                        Youtube, Netflix and LG Smart store icons briefly appear in the apps list but then automatically disappear after doing 'Initialisation of Premium' via the standard menu, I'm guessing this is due to the Country/Area group its set to is wrong for the UK.
                                        Unable to change the country group, Area option can be changed which alters the country group but none make any difference. So believe its the country group that needs changing....
                                        10-20-2024, 11:16 AM
                                      • netgearnetgear
                                        JVC 40" LED TV (LT-40KC385) - Turning ON sometimes (stuck on loading, menu etc.)
                                        by netgearnetgear
                                        Hello esteem members,
                                        I have a JVC Television that fails to turn ON sometimes. The stand-by red light is always on. When the TV turns on the the JVC logo displays then the TV attempts to scan for local channels...it then freezes. If I unplug it, then it refuses to turn on - stand by light on. The power supply input voltages are present - 12V, with the backlight 0.32V when the TV refuses to turn on. Backlight voltage is 2.98V when TV does turns ON. All regulator chip has 3.3V on pin 8. Processor voltage - 1.02V, Ram - 1.5V. I am thinking about reflowing the on-board RAM. When the TV was...
                                        10-28-2023, 06:59 PM
