Capcitor voltage question
  • Prowler
    • Oct 2005
    • 5
    Hello everyone this has been a great site!!
    I work at a retail computer store and have been dealing with faulty cap'd boards for several years.
    The question I have is about capacitors themselves. The voltage written on the cap itself, is it a maximum or a running voltage? I guess or other?
    Main reason I am asking is I have an old PC CHIPS board, but it has 1 blown cap on it (I guess for now). So i wanted to experiment on it.
    Can I replace it will a higher voltage cap say 16 volt off another board I know is dead?
    Also does this site sell individual Caps? I have a power supply by Aspire/Turbo that developed one, I believe it is hindering my 12V rating.
    Wayne
  • Rainbow
    • Aug 2005
    • 1371
    Re: Capcitor voltage question
    That's maximum voltage which should be never be exceeded or even reached.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      the voltage on the cap is the rated voltage, it is a maximum value. Do not use replacement caps with less voltage. It is ok to use more voltage and more capacitance than the caps already on the board.
      it is not recommended to use old caps. you dont know the condition of them. also it is more difficult to work with them because of the small length of the leads.
      i guess Topcat will sell you one cap but its gonna make that cap expensive because of the shipping cost. better to buy a whole kit. anyway pm him from the forum.
      • Prowler
        • Oct 2005
        • 5
        Thanks guys that is great info.
        Diameter? does it matter as well?
        Can't believe how many boards have come back to our shop with blown caps.
        Some people have been amazed with my ability to find them. basically I check any board that comes in with integrated sound that had a joystick port.
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          The voltage on the can is its maximum voltage for continuous operation. IOW, don't use a 10V cap on the +12V rail. However, if you look at the cap specs, you'll see that there is a higher "Surge Voltage" rating, possibly with the duration and frequency of the surges specified. Think of that as a "don't go there rating". In the world of mil-spec components, it used to be (may still be) that the US military required that caps be operated at </= 50% of the rated voltage.
          Diameter and Height are usually just a mechanical fit issues. However, shorter, larger diameter caps are often slightly higher impedance than taller, smaller diameter caps of the same series, capacitance, and voltage rating.
          PeteS in CA
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            it is very difficult to find replacement caps at the same sizes as originally on the board. I know Topcat does his best to supply the best width replacements.
            for instance i source my caps from a european mail order company so if i was looking to replace a 1000uf 6.3v that was 8mm width i would only be able to order one at 10mm width. when you have two caps close together or a row of caps you have to angle some of the new caps to get it all to fit. looks bad but works fine. same problem with height sometimes, so you can bend the leads and lay caps lying down if they will interfere with the pci or agp cards etc.
            i dont see what at all integrated sound has to do with bad caps. any board is a candidate for badcaps
            • Prowler
              • Oct 2005
              • 5
              Integrated sound cards were an indication of the age of the motherboard. Most newer motherboards don't come with a joystick port integrated, it is often a header connection.
              PeteS in CA & willawake thank you both for the info. It is very helpful. I'll have to look in to how much it is for a kit to be shippe to Canada.
              • PeteS in CA
                • Aug 2005
                • 3579
                Look into Digi-Key and Newark Electronics, Prowler. They should be able to ship to Canada, and may have warehouses there, too. Future Electronics is a Distie that is based in Canada, possibly near you, but I don't know what their minimum quantities, if any, might be. Digi-Key sells Nichicon and Panasonic. Other posters have mentioned buying UCC from Newark. Future sells Rubycon, Nichicon, and Panasonic, IIRC.
                Given the age of the MB, you probably have a cap exhibiting end-of-life wear-out. Chances are, that same value-voltage part may be in a smaller case size now.
                PeteS in CA
                • Prowler
                  • Oct 2005
                  • 5
                  on Digi-key's website, I can't find anything 3300uf 6.3V 10mm Diameter, 5 mm post difference?
                  Is there any there that are recommended? I notice most of the are 12.5 diameter.
                  Any suggestions?
                  Wayne
                  • linuxguru
                    • Apr 2005
                    • 1564
                    It depends - check the layout of the caps on the motherboard. You can sometimes substitute a 12.5mm in place of a 10mm, but the leads may need to be bent and it may not sit flush on the
                    motherboard.
                    • rddube
                      Lenovo L490 Ram voltage circuit malfunction
                      by rddube
                      Hello friends,
                      Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                      I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                      07-15-2025, 04:41 PM
                    • Fernon@Repair
                      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                      by Fernon@Repair
                      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                      VCCIO voltage ok
                      VCCSA Voltage OK
                      VCCPLL Voltage OK
                      Ram Voltage ok
                      RamVTT OK
                      VPP 2.5 OK
                      But No Core Voltage
                      and i want to this vrm ic datasheet or pinout (ISL69269)
                      anyone have this ic pinout voltages?...
                      06-25-2025, 07:19 AM
                    • electron_jj
                      Panasonic TH-L42D25A checking the PSU output voltage
                      by electron_jj
                      Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                      I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                      08-29-2021, 08:13 AM
                      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                      by sam_sam_sam
                      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                      Now...
                      06-09-2024, 10:57 AM
                      ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                      3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                      Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                      core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                      configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                      serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                      Based on Intersil's Robust Ripple Regulator...
                      11-05-2024, 03:24 PM
