oddball board
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    oddball board
    i have here a PICMC AP-PSL14 board. it is some sort of backplane.
    most of what i found online is for vs 1.3, with ATX. mine is 1.2, with AT only. it also has a different set of slots.
    it has 10 ISA 16bit slots (2 are VLB), and 4 pci slots. it also has an AT keyboard connection, an AT power connection, and LEDs and screw terminals for -5v, -12v, +12v, and VCC. it also has a terminal for ground and an LED for 3.3v. there are also a couple oddball connections.
    it is like this one only w/o the atx and only 2 instead of 3 of the white connectors:
    any idea what it is for? i found it at goodwill ages ago for $1.50, and i took it. my research says it is for some industrial thing.
    is it worth anything? anybody have a use for it?
    sigpic
    (Insert witty quote here)
  • stevo1210
    • Oct 2006
    • 4156
    Re: oddball board
    it's old. thats about all I know. could be a server board but I dunno.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Re: oddball board
      Well, it's surely for some industrial application. The individual terminals for each voltage rail would indicate that. Not sure where the data input is, though.
      Ludicrous gibs!
      • NxB
        • Feb 2009
        • 1595
        Re: oddball board
        http://www.voxtechnologies.com/backplanes/appsl14.htm
        • NxB
          • Feb 2009
          • 1595
          Re: oddball board
          http://www.orbitmicro.com/global/ap-....html?ref=base
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: oddball board
            and so? all that tells me is what i already know. it is a backplane.
            i meant what is it used in?
            sigpic
            • seanc
              • Nov 2008
              • 1319
              Re: oddball board
              Whatever it is, you could maybe sell it for ~$90
                • 31156
                Re: oddball board
                it's for an SBC.
                (single board computer)
                a lot of industrial stuff use a backplane like that and all the other junk is on a big plugin card.
                it's to make repair or upgrade easy.
                you pull your old p2 card, and pit your new whatever based card - job done.
                now i dont know what a backplane is worth, but the cards used to cost a fortune!
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: oddball board
                  You are such an ass.
                  NxB pointed you to the specs for THAT board which matters because many are propriety and so useless junk.
                  Mann-Made Global Warming.
                  - Dr Seuss
