I'd like your opinions on this...
  • Roadkill203
    • Oct 2008
    • 68
    Okay, here's the back story:
    I got a great deal on a socket A motherboard a few months ago. It's an Abit NF7-S2. I got it on Ebay for 99 cents and paid 8 Dollars for shipping! It came with the original box, an Athlon XP 2500 processor, 1 gig of ram (two 500s), and a Thermaltake heatsink - not bad for $8.99!
    Of course when it finally did arrive I hooked up a power supply and a video card to test it out; it didn't start up. Upon further inspection I saw that it had some blown caps right by the processor (my eyes are old - I had to get the magnifying glass out!). I ordered the caps from here and when they came in I re-capped it. After the recap job I installed my Athlon XP 3200 (with the Barton core), the Thermaltake, two 1 gig stcks of ram and 1 of the original 500 sticks (for some strange reason it won't recognize more than 2.5 gigs of PC 3200 ram, even if I manually set the frequency from 400 Mhz to 333 Mhz), and VIOLA! It started right up! I loaded Windows XP and this has been my main rig for the past few months, replacing my Epox 8RDA+6 board that went dead a few months back. The NF7-S2 has been working flawlessly for the past three months, not a burp, not a hiccup. It shuts down and starts up without a problem, except for yesterday.
    Flash foward to yesterday - There was a fan going bad on the northbrige heatsink so I ordered a new fan. It came in yesterday. I shut down the rig last night, pulled the side cover off, did some minor dust cleanup with my vacuum cleaner, then I swapped out the bad fan for the good one. I put the cover back on, then attached all of the cables in the back and started the rig up again.
    It booted up all the way to the Windows logo, then the screen went blank. I pressed the 'reset' button, there was nothing. No blinking LED on the front to show activity (but both LEDs were lit), no beeps. WTF???
    Okay, I took out the ram one at a time, starting at slot 3 (furthest from the processor), still nothing, no boot. I replaced the last stick of ram with a known good 500 stick, still nothing. I left the known good ram stick in there and replaced the XP 3200 processor with a known good XP 1700 processor - it started up! Now that I knew the processor died I started reinstalling the ram that I originally took out, one at a time:
    First one (the 500 that was in slot 3) - nothing, no beeps, no activity, both front LEDs on solid.
    Second one (the 1 gig that was in slot 2) - nothing, no beeps, no activity, both front LEDs on solid.
    Third one (the 1 gig that was in slot 1) - three quick beeps but still no boot or no activity. SHIT!!!
    What could cause the processor and three sticks of ram to fry at the same time?
    More bad caps? I replaced all of the caps that line up by the side of the processor and all of the caps that go kind of parallel to the ones by the processor.
    Bad power supply? The power supply IS an 800W Cooler Master, but I bought it new from New Egg about three years ago. Is it possible that the power supply took out both the Epox AND the Abit?
    Hardware problem other than caps on the motherboard? I don't have much experience with that kind of problem.
    Your thought are greatly appreciated. I have some electronics skills but you guys are the GODS of electronics compared to what I know! I'm always willing to learn though, and I learn ALLOT on this forum... Thanks in advance for all of your thoughts.
    BTW, the computer has been running since midnight last night. I re-booted it once this morning, just to see. It re-booted fine.
  • AudioCraZ
    • Sep 2009
    • 147
    Re: I'd like your opinions on this...
    Check the voltages on the power supply with a voltage meter... That would be my first step.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      agreed on the psu check... there might be more bad caps... hence why we recommend replacing all questionable caps
      sigpic
      (Insert witty quote here)
      • yyonline
        • Jul 2009
        • 692
        I'd also recommend reseating all the other hardware (video card, sound card, etc.) It's not uncommon for them to get nudged when cleaning out the computer. Did you try resetting the bios using the clear cmos jumper? It's possible moving the memory around "confused" it. Not sure of the technical term for that, but it's worked for me before when a system won't post. Cooler master power supplies can be kinda hit or miss quality wise. Wouldn't hurt to open that up and check for bad caps or other signs of trouble as well. Make sure it's been unplugged long enough for any residual power to drain as some of them have heatsinks and the like that are live. Most of the dead Nforce2 boards I see have fried southbridges - look for discoloration and see if the southbridge chip quickly gets really hot when you try to power the computer on.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          I would also after measuring the PSU voltages with a multimeter (don't forget about +5VSB when the system is both off and on)
          Next I would measure the CPU VCORE, the easiest place to do this is usually if there is some exposed solder on the component side of the PCB where the coils for the CPU are, measure from there to any ground
          And then do the same for the memory, you can even measure directly on the DIMM slots to ground, but of course it requires good eyes and a steady hand so you don't slip and short something out when the system is running!
          • kaniki
            • 514
            check the board for warping too. maybe the board warped a little and makes it so that maybe one of the components are not making a good connection. I have actually seen a board do this that warped the whole ram slot. I had to put something under the board to push it back up (i used rubber) and then screwed the motherboard back down on top of it. that straightened the board out enough to get the ram to make a connection again. It may or may not be the RAM, it may be another part but is a possibility.
            • ktmmotocross
              Old hp compaq nc6320 weird beeps after low bios battery
              by ktmmotocross
              Hello.
              Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
              i attach record of beeps...
              04-27-2025, 12:48 AM
              HP Pro 3405 MT Pro 3405 E2-3200 Specification for Upgrade or Repair
              This specification for the HP Pro 3405 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro 3405 MT boardview and Pro 3405 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Pro 3405...
              09-12-2024, 03:30 PM
              HP Pro LH133EA Pro 3405 E2-3200 Specification for Upgrade or Repair
              This specification for the HP Pro LH133EA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro LH133EA boardview and Pro LH133EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Pro LH133EA...
            • KappaDev
              HP ENVY x360 15m-dr0011dx 8 Beeps
              by KappaDev
              I have an HP Envy x360 15m-dr laptop which sometimes beeps 8 times on startup and sometimes gets no beeps at all (both with no picture).
              Power button light comes on, fans spin and stop after a few seconds, then screen stays black with no picture. If the machine decides to beep 8 times, it shuts off immediately after. According to what I could find, 8 beeps was corrupted BIOS.
              Made backup of original BIOS (attached). Attempted to flash BIOS with extracted bin file from HP BIOS update. Screen showed "Updating boot block", rebooted and immediately back to 8 beeps and...
              01-09-2023, 11:18 AM
            • tahirkhan1983
              Hp prodesk 400 g5 3 long beeps and 2 short beeps
              by tahirkhan1983
              My Hp prodest 400 g5 having no display with or without ram 3 long beeps and 2 short beeps. many bios tried but the problem is same. please help thanks in advance.
              07-26-2023, 06:43 AM
