Large Monitor Computer Hardware Requirements
  • bigbeark
    • Jan 2010
    • 661
    My son hooked his old AMD Socket 462 machine with 1400Mhz processor to his 42 inch LCD TV.
    I supplied a 258MB ATI x700 8x AGP video card and 768MB Ram.
    This works but video lags.
    What is the minimum required processor speed/RAM/Video memory to give reasonable performance.
    I have various socket 462, 754, 478 and 775 boards on hand that I would prefer to reuse. I have two socket 775s one using DDR1, the other DDR2.
    Any thoughts?
  • yyonline
    • Jul 2009
    • 692
    Re: Large Monitor Computer Hardware Requirements
    What resolution are you sending out to the TV? A 1080p TV will need more power than a 720p TV.
    Also, some large LCDs have inherent lag in them due to the design. See if the TV has a "game mode" or similar that turns off some of the TVs image processing to reduce the lag time.
    What are you doing with it? 3D gaming will use more resources than playing DVDs, which will use more resources than browsing the internet. So, with some more info, we may be able to give you some recommendations.
    • toastygoodness
      • Jul 2005
      • 813
      if it is 1080p, at least a dual-core atom 1.6ghz and nvidia ion. just for video.
      for gaming, dual-core Athlon II with 2gb ram and a radeon hd 4600 or higher (5500 or higher for the 5000 series) will be sufficient. (those are your most inexpensive options, you can go intel/nvidia or intel/ati but intel's much more expensive).
      if you have a pci express slot, you can try just adding a radeon hd 4600 or higher.
        • 30979
        you need to find your tv's native resolution and frequency.
        frequency is usually 60hz but not always.
        then in your settings on the pc, set that resolution & frequency and enable locking the framerate to vsync to prevent "tearing"
        if you do all this, the image will be the best it can be,
        if you have any other settings the tv's scaler circuits are gonna make a mess of the image making it fit the screen.
          Fintek F71868A Super I/O and Hardware Monitor Datasheet
          The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
          Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
          10-23-2024, 02:26 AM
          by momaka
          03-15-2023, 10:17 PM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
        • Rick_1234
          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
          by Rick_1234
          Good evening, gentlemen.
          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
          https://drive.google.com/file/d/1L6S...ew?usp=sharing
          Things I tried
          - Bought a new AC adapter thinking that was the problem but the problem...
          06-22-2024, 04:44 PM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
