Electrical fire 101
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Electrical fire 101
    Don't know why but the suge protector on the wife PC gave up this morning. The only thing on it that was turned on was a little portable DVD player. It still works fine. It was impressive! First there was lots of white smoke then black smoke. Then there was one loud bang and it was all done with. The board as well as all the componets are burnt black. There is a hole burnt in the center of the board that is the size of a dime. Two disc compasitors as well as a diode were blown clear off the board. I wonder if the PSU in her PC is dead now. It could have taken out her monitor to. Going to have to plug up her junk to and extention cord and find out. The power strip was made in CHINA!
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Electrical fire 101
    generator overrev on you?
    this is why i wont use surge strips in plastic cases!wounded mov's can go white hot and not pull enough to trip the breaker.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Originally posted by kc8adu
      gthis is why i wont use surge strips in plastic cases!wounded mov's can go white hot and not pull enough to trip the breaker.
      This is good to know
      Where can fire proof versions be bought?
      Or you just use a UPS instead?
        • 31058
        nothing to do with china,
        mov's do fail - i'v had them go on the bench - bang-flash!
        put simply, they kill spikes by shorting out for a microsecond or whatever - like an AC version of a zener diode.
        each spike stresses them - eventually they just go boom.
          • 31058
          btw, if you put a couple of layers of thick heatshrink over them they generally dont damage anything other than the pcb around the pins when they blow.
          this used to be common practice in pc psu's
          • RJARRRPCGP
            • Jul 2004
            • 6304
            My living room powerstrip was real close to doing the same thing!
            Because I had a leak on July 10, 2010. Water was dripping right near the powerstrip and cable box!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Since I started this post I've blown up another surge protector. This one was even more dramatic than the first. The whole plastic case melted. You can see the outline of it in the carpet. The carpet all around where it was is now chared black. All you have to do to take one of these thing out is rev the generator some and Kablam its gone. Junk Parts can learn new things like "DON'T REV THE GENERATOR if given enough time.
              Mark Twain
              John Paul Jones
              Rod Serling
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Huh? Then would that mean your TV and PC are F-ed now?
                Arc A770 16 GB
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  Everything is fine. Its the Laptop that gave up and it wasn't plugged in at the time.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • severach
                    • Aug 2007
                    • 1055
                    So what will your next surge strip do? Blacken the entire house? Are you're going to let it?
                    Fireproof surge strips are available at every store and are cheaper than the fire hazard type. I only purchase non surge strips and I opened all the strips I had already and cut or disabled the surge parts. Strips where the surge parts could not be disabled were discarded. Surge suppression at the strip is unsafe and useless.
                    My surge suppression is in the breaker box where it beats down lightning with the greatest of ease. All other unimportant surges are handled by the power supplies which don't need any help from carpet burners.
                    Generators are voltage regulated. Reving it would increase the frequency but shouldn't increase the voltage. I burned out some surge strips with a generator because the neutral damaged allowing more than 120v on some circuits and less than 120v on others.
                    I've seen blackened PSU where the MOVs that didn't go were heat shrink wrapped. The wrap isn't good for much.
                    sig files are for morons
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      it blew because he was horsing the throttle... as long as he leaves it alone, it will be fine... it is an old generator so it might not have been regulated... the frequency change might have been too much for the strip anyway...
                      sigpic
                      (Insert witty quote here)
                        • 31058
                        mov's arent frequency specific.
                        luckily they are only about 50c each - you can parallel a big line of them in a metal case if you wanted.
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          I was Reving the gen-set to clear the carb. This was the original busted junk carb. The unit now has a newer carb off a tecumseh lawn mower on it. The unit starts on the first pull and runs great now.
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • sew333
                            Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                            by sew333
                            Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                            So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                            So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                            I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                            06-14-2024, 07:30 AM
                          • Asxetos21
                            Dell Latitude 5511 audible electrical noise
                            by Asxetos21
                            I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
                            The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
                            Any advise on how to narrow it down?
                            The schematic is available here:
                            Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
                            03-03-2025, 09:53 AM
                          • jczarniak
                            JVC Fire TV or any other Android based firmware
                            by jczarniak
                            Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
                            I have got JVC LT-50CF810 Fire TV with firmware not working properly.
                            Thank you very much for any support.
                            Regards.
                            10-18-2023, 01:43 AM
                          • Bubbsy 2002
                            Kiddie smoke alarm (120v with 9v battery backup) experienced 180v power surge (Newfoundland Power company).
                            by Bubbsy 2002
                            Hi to all, I was diagnosing 2 smoke detectors that experienced power surge. I opened one up and found a weird fuse/resistor, which now has open circuit. I can't find this part.
                            Forgot to mention they both light up and I believe the test function works, but when I put smoke to them no alarm!
                            Any help in this regard would be greatly appreciated.
                            Thanks,...
                            01-02-2024, 09:11 AM
                          • spleenharvester
                            GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                            by spleenharvester
                            I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                            07-08-2025, 06:02 PM
