PC case - Hard drive rails
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
    So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
    I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
    Now, the case is a CiT Gaming Case, and according to the badge on the front, is a "Vantage", however, when I was searching for rails, and the case, the Vantage ones I saw were different internally, but a bit more searching and internally it looks identical to the CiT "Vanquish" case. I've attached a photo of the hard drive area for a "Vanquish" that looks identical to mine.
    Anyone know if there is a generic type rail that will fit this case?
  • SluggerB
    • Aug 2020
    • 747
    • US
    Re: PC case - Hard drive rails
    Amazon sells a bunch of hard drive rails
    https://www.amazon.com/hard-drive-ra...rd+drive+rails
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      The drive rails are likely universal between any case that company makes....that said, I've made Enlight drive rails work with all kinds of cases that they were never intended to be used in.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        There used to be a "standard" - the ones that IBM used for its drives in the IBM AT and XT cases - however at this point with all the clones and ATXs they tend to not be compatible with each other. Correct that within a specific brand or OEM they can be compatible but not always, but likely you'll need to search for the brand or OEM with the rail.
        I have an X-Blade case that was missing rails and goes in the side like yours, I ended up 3D printing a few. Be warned however, PLA will soften if you let your hard drives heat up to 60°C ... may need to use ABS or some other plastic.
        • federalhouse
          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
          by federalhouse
          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
          **Background:**
          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
          **What I've Tried So Far:**
          1. I accessed
          08-01-2024, 07:03 PM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • ash91
          Hp pavilion 15 not detect hard drive
          by ash91
          Hello gentelmen .... this is my first post and sorry for my bad english,
          so my proplem is my laptop keep losing hard drive even if i but the
          hard disk in the cady (the box that can replace the dvd rom with hard disk)
          when i turn the laptop on the massage that said no boot media found pop on
          the hard disk is fine and to be sure i try another hard
          i also update my bios to the last update
          the 5 volt is present on the hard connector on the motherboard
          the dvd rom work fine when i but a windows dvd in it
          also when i boot from flash...
          06-07-2023, 01:45 PM
        • karto95
          Repairing a Seagate hard drive with damaged logic board
          by karto95
          I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
          I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
          If anyone has any suggestions or experience with this...
          03-21-2023, 04:05 AM
        • ChaosLegionnaire
          bug of the month: write caching setting for the hard drive in device manager
          by ChaosLegionnaire
          i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
          so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
          10-06-2019, 01:39 PM
