TPM 2.0 is not always standard issue
  • japlytic
    • Oct 2005
    • 2086
    A Gigabyte Z690 motherboard I have recently purchased had a connector for the TPM (Trusted Platform Module) but was not included as standard in the box even though Windows 11 (which requires it) has been released a couple of months ago.
    I've read that the TPM is included as standard for certain regions as well.
    • 31281
    Re: TPM 2.0 is not always standard issue
    TPM is a bad thing that will be used to abuse the user,
    i remove it when i see it in my stuff.
    if you read the user/sevice manuals you will see it is not fitted for some countries because of export restrictions related to encryption systems.
    which is a load of BS given that israeli designed (backdoored like LGBTQP followers and sold to anybody for shekels) chips, fitted on preduction lines in china (reverse engineering experts) is hardly anything to do with the u.s.!
    • lti
      • May 2011
      • 2557
      Enabling Intel Platform Trust Technology will run some kind of software emulation of the TPM for the few people who actually want Windows 11. I would expect it to be enabled by default on a current motherboard.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        Same. It's either disabled or removed when I encounter one in my stuff.
        I've encountered a couple Win11 systems that M$ forced 11 upon them, it sucks worse than 10.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          • 31281
          Originally posted by lti
          Enabling Intel Platform Trust Technology will run some kind of software emulation of the TPM.
          i have seen that in a bios recently, it also emulated the secure storage chip that uses a password.
          total fucking scam of course - i'm surprised anybody puts up with it!
          • diif
            • Feb 2014
            • 6978
            • England
            It's not for you, it's a grown up enterprise thing, mainly for keeping the data safe.
            It should be invisible to the end user, with the bitlocker key stored in active directory.
              • 31281
              but the point is, if you emulated a password secured chip using regular serial flash then the security is fake and non-existant
                HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                09-06-2024, 08:30 AM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • shahnld
                Lenovo legion 5 pro startup issue
                by shahnld
                Good day Experts
                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                08-24-2025, 12:31 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
