TPM 2.0 is not always standard issue
  • japlytic
    • Oct 2005
    • 2086
    A Gigabyte Z690 motherboard I have recently purchased had a connector for the TPM (Trusted Platform Module) but was not included as standard in the box even though Windows 11 (which requires it) has been released a couple of months ago.
    I've read that the TPM is included as standard for certain regions as well.
    • 31002
    Re: TPM 2.0 is not always standard issue
    TPM is a bad thing that will be used to abuse the user,
    i remove it when i see it in my stuff.
    if you read the user/sevice manuals you will see it is not fitted for some countries because of export restrictions related to encryption systems.
    which is a load of BS given that israeli designed (backdoored like LGBTQP followers and sold to anybody for shekels) chips, fitted on preduction lines in china (reverse engineering experts) is hardly anything to do with the u.s.!
    • lti
      • May 2011
      • 2547
      Enabling Intel Platform Trust Technology will run some kind of software emulation of the TPM for the few people who actually want Windows 11. I would expect it to be enabled by default on a current motherboard.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Same. It's either disabled or removed when I encounter one in my stuff.
        I've encountered a couple Win11 systems that M$ forced 11 upon them, it sucks worse than 10.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          • 31002
          Originally posted by lti
          Enabling Intel Platform Trust Technology will run some kind of software emulation of the TPM.
          i have seen that in a bios recently, it also emulated the secure storage chip that uses a password.
          total fucking scam of course - i'm surprised anybody puts up with it!
          • diif
            • Feb 2014
            • 6978
            • England
            It's not for you, it's a grown up enterprise thing, mainly for keeping the data safe.
            It should be invisible to the end user, with the bitlocker key stored in active directory.
              • 31002
              but the point is, if you emulated a password secured chip using regular serial flash then the security is fake and non-existant
                HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                09-06-2024, 08:30 AM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
              • Simone Vergani
                Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                by Simone Vergani
                I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                To assist with troubleshooting, I'm attaching two power circuit schematics:
                • Power
                03-05-2025, 02:25 PM
