AC on DC side of PSU?
  • neiro
    • May 2010
    • 3
    Hello. The other day I was testing some led's that I intended to use on a new (hopefully) fashionable lid for my computer case. I tested one of them using a resistor and a power supply. But I hadn't even attached the led when I noticed something odd.
    When my powersupply is switched off (but plugged into the wall socket), there's an AC current running between me and the ground wire of the power supply - and between me and the 12v wire I meant to use as well in fact.
    I tried this with two different power supplies I had laying about (an antec 380w and a modular 620w corsair). The current varies appearently, but it's somewhere between 54 and 110 volts, and as voltage goes down so do herz count. I've seen anything from 25 to 7 hz. Between the two wires, there's less than 0.1v but still enough to detect a 50hz frequency.
    When I switch the unit on the voltage becomes half of whatever it was before, and the herz rating changes to 26-27.
    There's even enough current to have the diode light up enough that I can tell the colors apart (3 diodes in one housing sharing a common ground) when I use myself as 'plus' and the ground from the psu as ground.
    Why? Why do I detect ac current on my power supply?
    When the unit is turned on I'm measuring very close to zero voltage ac between ground and +12v, but I still have a 50hz reading on the multimeter. Switching from raw dc reading (of 12.08v on the antec) to ac+dc I notice the voltage reading changing, but the herz is still @ 50.
    I'm just a simple enthusiast. I would've always claimed there's no ac on the dc side of a power supply - but appearently that's not so.
    Why?
    background:
    System's in denmark. Means 230v @ 50hz from the wall socket.
    multimeter is an mx53 (http://www.aemc.com/products/html/mi...bname=products)
    Power supply is turned on by shorting green and a ground on the atx plug using wire from another atx plug that I had cut to pieces a while ago.
    I already asked toms hardware some days ago, but the only answer I got was to ask an electrician (which I had done, but to no avail) or try posting here.
  • neiro
    • May 2010
    • 3
    Re: AC on DC side of PSU?
    Addon - in case it's important, I might want to mention that there is no earth in the socket. It's not the newest house.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      not safe.
      hence why we are getting the house we just bought upgraded.
      sigpic
      (Insert witty quote here)
      • mur
        • 21
        I think this is leakage current through Y filter caps in psu's input filter. Y caps are connected between line and ground and neutral and ground. If you would have your house grounded, this leaking current would go into the ground. The current is very small and I think it's nothing to worry about (except your not grounded house ).
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Get an alligator clip and connect your computer chassis to something grounded, like your house heating radiator for example, I bet you the AC voltage will be gone then
            • 31084
            what mur said.
            i see this a lot in modern unearthed junk like tv's and set-top boxes.
            i almost got thrown off a ladder once by an unearthed satellite receiver that was putting about 380v onto the earth side of the LNB cable via the tuner-can.
            • neiro
              • May 2010
              • 3
              I took my multimeter with me to work and tested a normal hp psu from one of the hundreds of computers here.
              First I tested with no ground wire, and it was outputting 46 volts at a fairly high 38hz. Then I changed to a grounded outlet, and it completely vanished!
              So you guys are right. It's the missing grounding. Maybe this is something I should do something about. If it can make a led glow, it can also break stuff.
              • delaware74b
                • Apr 2009
                • 628
                I know this isn't computer-related, but grounding related. I was in the process of bench testing a 1000-watt metal halide parking lot light assembly without a ground attached. Although I didn't touch it, my DMM was reading over 300 volts to ground. I double-checked all the connections and found nothing wrong. After a ground wire to the frame, the voltage issue went away. The ballast in it was a common core-and-coil. Fluorescent fixtures, especially those with electronic ballasts (a SMPS!) can be dangerous if not grounded properly.
                Stupidity should be a crime, especially for drivers. I have NO patience for them.
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • flibidy
                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                  by flibidy
                  I have here a Magnum IA.100 which belongs to my parents.
                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                  What Ive done........
                  01-01-2025, 01:26 PM
                • yayayee
                  ASUS GU502GV not powering on - 1285A hot
                  by yayayee
                  I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
                  So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
                  I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
                  01-08-2024, 11:04 PM
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • bouny56
                  Lenovo E15 Nm-c421 usb-c work only in one side
                  by bouny56
                  ​Hello
                  Laptop E15 I5 10gen
                  Mb nm-c421
                  I have a problem with the usb-c power dc.
                  The motherboard start only in one side of the usb-c
                  Replace the usb-c port 2 times same problem
                  With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                  Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                  Can the pd controler be the fault ? Or something else maybe ?
                  Thx
                  02-11-2025, 03:15 AM
