2 Nanometer Transistors
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    IBM, having recently (within the last two years I believe) broken the size barrier and can now manufacture transistors that are 2 nanometers in size, which is roughly 4 to 10 times the size of an atom, they claim they can get 50 BILLION transistors on a wafer the size of a fingernail ... it makes me wonder ...
    How on Earth does a schematic that large even get designed in the first place? Is CPU Engineering nothing more than a set of algorithms that place the transistors onto the schematic? No human being could possibly design something at that scale and keep track of whats going on in the circuit.
    Anyone out there have any idea how these things are designed?
    sigpic
    • 31300
    Re: 2 Nanometer Transistors
    it's probably like lego
    take a cache, stitch it to a core and so-on
    lots of pre-designed modules.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Remember the old joke about flying spy devices the size of a fly? Doesn't seem like a joke anymore...
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8715
        vast majority of transistors is used for memory, so not like it's hard to make a very regular structure of transistors over and over again...
        I also doubt the validity of the "announcement" ... people have been making announcements fast and loose for a long time now. Also, though they may really have made something small, when things get that small, it's hard to make them always work properly.
        50 billion transistors is barely enough to make 1GB SRAM, would you like 1GB cache with your CPU?
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          I don't know how much cache do they put on CPUs these days? Been a long time since I cared enough about it to keep up ... but the 2-nanometer thing is impressive if it's correct. I thought they said something about quantum physics breaking down in this application at anything smaller than 5 nanometers ... which is still damn impressive given that it's only been what ... 30 or so years that we've been making CPUs? Are these transistors made from traditional PN material or is it some other magic compound that some propeller head invented?
          sigpic
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            I think most people would flip the hell out if they knew what Uncle Sam had in terms of personally invasive tech ... Though when you think about the "fly on the wall" spy tech ... it would still take a considerable amount of energy to move that little thing through the air ... Im not sure it could be done without some kind of biochemical energy that can be refreshed "on the fly" somehow - lol
            sigpic
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • dragometin
              Hitachi 40HYC42
              by dragometin
              TV Model: Hitachi 40HYC42
              Power Supply: 17IPS71
              MainBoard: 17MB95M
              Panel: VES400UNDS-2D-NO3
              When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
              I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
              Is there any variants on 17IPS71 power supply's?
              UART output pins 10 and 12 on scart connector:
              Code:
              12:24:04.595
              08-08-2024, 05:53 AM
            • Francesc V.
              Onkyo A8200 - Not the right voltages in some transistors
              by Francesc V.
              Hi:
              I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
              With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
              Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
              Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
              I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
              04-19-2025, 07:17 AM
            • Bob Wong
              MSI Crosshair 15 A11UEK. Need help with Transistors!!!
              by Bob Wong
              Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
              In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
              P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
              03-15-2025, 02:02 PM
