Usual causes of inoperative USB ports?
  • berniedd
    • Mar 2007
    • 119
    Just like the title says. All 4 of the rear USB ports in my 5 year old desktop are dead/malfunctioning/intermittent. Yes, they are enabled in BIOS. At first I thought bad OS, so I tried a clean install of Ubuntu and later on, reinstalled win XP, but none of the ports came back to life. Everything else works in both OS installs. Bad caps in and around the USB ports even though they look OK visually?
  • pentium
    • Mar 2006
    • 2778
    Re: Usual causes of inoperative USB ports?
    You sure the connectors themselves are okay? I have seen quite a few mashed up USB ports in my time from stuff fralling off desks to small objects lodging in the port.
    Find Nedry!
    Check the Vending machines!!
    • washu
      • Jul 2009
      • 310
      ICH5 southbridge? Some versions have insufficient ESD protection and can die easily.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        most of the time when i found dead USB ports on the back and they weren't mashed up, the fuse blew.
        happens quite a lot when ppl use external 2.5" Harddrives or other power hungry equipment without the additional powersupply.
        or overloaded cheapo USB Hubs without protection.
        if the front USB ports are dead it can also mean the connector on the board was plugged in the wrong way around..
        • delaware74b
          • Apr 2009
          • 628
          I had a customer's computer (HP/Compaq Evo D510 SFF) start doing the same thing. I opened the computer and it was full of popped caps. This model is almost as bad as Dell's SFF for heat build-up. Since your system is 5-years old, I'd check all caps on the mobo before doing anything else. If you find 1 bad cap, replace all of them.
          Stupidity should be a crime, especially for drivers. I have NO patience for them.
          • berniedd
            • Mar 2007
            • 119
            Well, I guess the big caps are the cause, even though they look OK and none are bulged or leaking. Today the computer would hang just after the POST, before it detects the hard drive and CDROM part. I reset the BIOS but it didn't help.
            • delaware74b
              • Apr 2009
              • 628
              What brand/series caps are on your mobo? Posting your computer system specs can help us in guiding your to fixing your system.
              • berniedd
                • Mar 2007
                • 119
                It's a Socket 754 ECS K8M88-M2 mobo. Sempron 2600+ processor. North Bridge: VIAK8M800. South Bridge: VIA VT8237
                All of the big capacitors are OSTs. None are bulging/leaking but I'm betting they are the problem. There are no beep codes on powering up.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  OST are famous for going bad with no bloating.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    In the case of my NEC USB card, one port quit working because the LM3526 chip blew. Ironically, that chip's job is to protect the USB ports:
                    • ant3202
                      • Jun 2006
                      • 275
                      • Singapore
                      fuse blown
                      static damages
                      usb port corrosion (due to cheap parts in casing) causing shorts / bad contact.
                      capacitor problems
                      shorts in casing
                      power supply (most overlooked components)
                      • kaniki
                        • 514
                        you forgot to add, using too many devices that draw too much power/data that does not blow anything, but knocks the connection for too much requirements and not enough sources. I have seen times where someone will have an AIO printer and try to use it with something like a camera on the same hub. Every time that they tried using both at the same time, they would both get kicked off until they rebooted the PC, then everything would work fine until they tried using both at the same time again.
                        • berniedd
                          • Mar 2007
                          • 119
                          Thanks, everybody. The PSU has been changed but to no avail. There are no devices plugged into any USB ports. I'm going to change the caps, maybe I can still resurrect this mobo yet.
                            Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
                            This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                            09-06-2024, 09:40 AM
