How modern Rubycon MCZs look like?
  • Wizard
    • Mar 2008
    • 2296
    Re: How modern Rubycon MCZs look like?
    And, WHY had to be rubycon MCZ series? Panasonic and Samxon have suitable specs you can use to replace the MCZ series.
    By the way, is there room for 10mm capacitors?
    Cheers, Wizard
    • long_double
      • Jul 2007
      • 10
      I prefer MCZs, because they're universal and work for almost everything. If I buy a lower grade, I'd have to check every time if lower grade can be used or not.
      Could you, please, provide names? I've got lost in endless comparison tables on this site
      Too small batches and too expensive. I'd alredy look for a 100 at a time, otherwise capacitors run out too quickly.
      Originally posted by stj
      yeah, pannies are just as good.
      So, are they good or not?
      • Wizard
        • Mar 2008
        • 2296
        Pansonic and Samxon (from Pope which I have bought over 300 caps in 3 seperate orders) are good as long as you are buying from suppliers and cut out the ebay.
        Google the rubycon MCZ pdf data sheet and then compare this to Panasonic and Samxon. Most I see like Pansonic's FC series.
        I use Samxon GD, GC (both low ESR) and GT for long life (10,000 hours at slight expense of ESR and size (very tall!) especially if power supply is extremely crowded and closed up which generic stuff is famous for and Apple are no exception).
        The KEY info you want is ESR and ripple current (most important match or exceed by some percentage) and low ESR design, 105C.
        Info is out there on 'net.
        Cheers, Wizard
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          those are the most obvious fakes i have seen!
          Originally posted by long_double
          It's me again. Here are the photos of the caps in question.
          Is there a FAQ on how to identify fake Rubycons?
          Does anybody know if MCZs can be grey (as on my photos) or they should always be gold-colored?
          I measured capacitance rating of these fake-MCZs and on most of them it is around 1480uF (nominal is 1800uF). But on some it is 2200 or sometimes 2400.
          • kikkoman
            • Jul 2007
            • 691
            judging from the pictures, you've already seen this one... anyway, their caps are genuine, prices are good.
            http://stores.ebay.com/AudJade-compo...Q_fsubZ3471909
            "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
            • Scenic
              o.O
              • Sep 2007
              • 2642
              to kikkoman:
              from what i understand, audjade is where he got those MCZ fakes from.. (post #8 & 11)
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Well, I buy on eBay, because I could not find anyone in Germany, who could deliver what I want in 50 pcs batches.
                Maybe someone could suggest a good reseller?
                Umm, www.badcaps.net
                I ship to Germany all the time.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • sofTest
                  • Aug 2008
                  • 361
                  #28
                  Originally posted by Scenic
                  to kikkoman:
                  No, I have to agree with kikkoman, in post 11, he just wanted an opinion on the caps from AudJade.
                  Be a mensch
                  • long_double
                    • Jul 2007
                    • 10
                    #29
                    Originally posted by sofTest
                    No, I have to agree with kikkoman, in post 11, he just wanted an opinion on the caps from AudJade.No, I have to agree with kikkoman, in post 11, he just wanted an opinion on the caps from AudJade.
                    Yes, I just wanted an opinion on AudJade.
                    I am going to buy about 400 caps from them, so if anybody already did and can share their thoughts about the quality of a purchase, I'd really appreciate it.
                    • Wizard
                      • Mar 2008
                      • 2296
                      #30
                      Once again, restate who sold this fakes in your post #8 and who sold these "genuine caps" in post #11?
                      And again please look at buying from either here or Pope for samxon capacitors or everywhere else for Panasonic if you still have issues with obtaining or fake rubycon capacitors. BTW, both Pope and badcap.net ships Samxon capacitors everywhere. Pope is friendly authorized distributor of Samxon capacitors also is more closer to you (Hong Kong).
                      First, do a test buy of small quantity from that ebay you are inquiring about.
                      Second, photos is usually copied from another so this is reason I'm very wary of ebay.
                      Cheers, Wizard
                      • long_double
                        • Jul 2007
                        • 10
                        #31
                        Well, I've received capacitors from http://myworld.ebay.com/audjade_chn here are the photos:
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          possible fakes... pics pf the bungs (bottoms wit the leads sticking out? it seems that the amount of sleeving on the vents is a bit too much...
                          sigpic
                          (Insert witty quote here)
                          • Shodan486
                            • Nov 2009
                            • 203
                            #33
                            You got me with this one, Top!
                            Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
                            • severach
                              • Aug 2007
                              • 1055
                              I have some Rubycon MCZ purchased as a Mac G5 kit from eBay that look counterfeit. White on black with a cross vent. Included are some real Rubycon MCZ Black/Gold for comparison. The counterfeits do not have the aluminum shine that the used real ones have. The fakes cost as much as real ones so someone is making good money.
                              sig files are for morons
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                #35
                                would be nice to see the bungs too but we all know they are fakes already.
                                btw badcaps.net has that kit and the parts will be genuine!
                                • severach
                                  • Aug 2007
                                  • 1055
                                  The bung picture was a bit too large the first time.
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6301
                                    The ones with the X vent definitely look fake! O_O
                                    ASRock B550 PG Velocita
                                    Ryzen 9 "Vermeer" 5900X
                                    Arc A770 16 GB
                                    eVGA Supernova G3 750W
                                    Alienware AW3423DWF OLED
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      i think we have seen those before.
                                      https://www.badcaps.net/forum/showthread.php?t=9890
                                      exact same fakes... same vent and fake text.
                                      i would not trust ANY of those caps, they all are suspect.
                                      sigpic
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        I say overvolt or burn them and watch them explode!
                                          MSI Modern MODERN 14 C12M-651IT Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 C12M-651IT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 C12M-651IT boardview and MODERN 14 C12M-651IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          MSI Modern Modern 14 B10MW-640 Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern Modern 14 B10MW-640 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Modern 14 B10MW-640 boardview and Modern 14 B10MW-640 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 02:20 AM
                                          MSI Modern MODERN 14 B11MOU-480CA Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 B11MOU-480CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 B11MOU-480CA boardview and MODERN 14 B11MOU-480CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 02:00 AM
                                          MSI Modern MODERN 14 B11MOU-481CA Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 B11MOU-481CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 B11MOU-481CA boardview and MODERN 14 B11MOU-481CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Modern MODERN 14 B11MOU-479CA Notebook 14 Specification for Upgrade or Repair
                                          This specification for the MSI Modern MODERN 14 B11MOU-479CA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MODERN 14 B11MOU-479CA boardview and MODERN 14 B11MOU-479CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
