Need CPU Cooler Advice
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Need CPU Cooler Advice
    couldnt find this on the global (english) scythe website..
    http://translate.google.com/translat...n&hl=&ie=UTF-8
    http://www.google.com/products?hl=en...A-82&scoring=p
    should fit for AM3 too i guess..(?)
    • toastygoodness
      • Jul 2005
      • 813
      well if you want a backplane, i like scythe for that too. or xigmatek, but those are probably too expensive.
        • 31154
        why not mount the fan on the back of the case and fit tubing between the fan & heatsink?
        that way your sucking cold air in, or blowing the hot air out.
        and you dont need to worry about how the fan fits on the sink.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          you mean the old dell method. thats how they cool their units- a rear fan and a duct.
          sigpic
          (Insert witty quote here)
            • 31154
            i wouldnt know, the only dell i ever had was "parts'ed"
            • toastygoodness
              • Jul 2005
              • 813
              also the rackmount server method, ratdude. i see no problem with that. as long as the airflow is all calculated.
              lol dell, "dumbasses enjoying laborious lobotomies" or whatever you want.
              • Maxxarcade
                • Jul 2006
                • 973
                #47
                Well, so far so good
                My CPU is now sitting at 40 degrees with the case at 35.
                The fan did touch the first RAM chip, but all I had to do was slide it up a bit.
                I'm not sure I like the scythe fan that I put in the case though, because it has an annoying hum.
                • Wizard
                  • Mar 2008
                  • 2296
                  #48
                  Maxxarcade,
                  Was this version you got like this? This artic version I was talking about does have 3 lug per side clip design. I'm surprised you found one with one lug version. How come?
                  http://www.canadacomputers.com/index...69&cid=FAN.349
                  Cheers, Wizard
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    #49
                    Originally posted by Wizard
                    Maxxarcade,
                    Cheers, Wizard
                    When I mentioned a single lug per side, I was talking about the retention bracket on my motherboard.
                    • Wizard
                      • Mar 2008
                      • 2296
                      #50
                      10 minute edit ran out so I reposted:
                      Maxxarcade,
                      PS: That new temps is what you should see and less noise. Also I do not buy any "generic" fans. The scythe is one of these as their blade design is not unique and researched properly. The Noctua fans are ones you should look for in fan blade design especially.
                      http://www.acousticpc.com/noctua_fans.html
                      Sunon fan buzz and rattle due to their harsher motor impulses (by design when they converted to their patented wafer style motor) coupled with loose bearing assembly. Which I dropped long ago for this reasons. Thermaltake, coolermaster etc were lottery on whatever to get good fan or junky fans. So I avoided.
                      I prefer: NMB, Sankyo, Delta and Nidec, all are ball bearing and tight, no rattles and they run smoothly and prandon the chiche silky smooth. Arctic heatsinks used decent fan which I was surprised so left it on and recommended this to you.
                      Ah, you can get another retention bracket from looking around on the market/ebay that has 3 lugs instead of one. Also there are heatsinks with bolt on design instead of using the bracket itself.
                      Cheers, Wizard
                      • BleedCap
                        OLD Socket 478 custom bracket + NEW generic cooler
                        by BleedCap
                        I already posted this on vogons.
                        Its a 3d printed custom bracket for socket 478.
                        I used this AM4 bracket as a base design.
                        Its to be use with cheap generic clip based cpu cooler.
                        Reason for doing this is:
                        - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                        - New generic cooler is cheaper and can use bigger fan (less noise)
                        I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                        The processor that I was using is P4 2.4Ghz prescott....
                        11-05-2023, 08:09 PM
                      • zlr8r
                        Advice on newer EC chip programming eg. MEC5107-LJ BGA
                        by zlr8r
                        Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                        i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                        09-16-2025, 09:54 AM
                      • Ede2001
                        I am looking for a wiring diagram or boardview EVGA GTX 780 Ti SC w/ ACX Cooler
                        by Ede2001
                        I am looking for a boardview file or schematic for the EVGA GTX 780 Ti SC w/ ACX Cooler video card.
                        08-26-2025, 03:14 AM
                      • Borse2008
                        Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                        by Borse2008
                        Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                        I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                        • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                        • There’s
                        07-15-2025, 04:55 AM
                      • Green Probe
                        Mosfet Advice
                        by Green Probe
                        Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                        05-22-2025, 10:49 AM
