Need CPU Cooler Advice
  • Maxxarcade
    • Jul 2006
    • 973
    I have a Phenom II X4 955, and the stock cooler is too loud for me.
    I have the Noctua NH-U9B SE2 in mind as a replacement, But I don't think it will clear my RAM. My motherboard is a Gigabyte GA-MA790X-UD4P, and I have all 4 slots filled with Mushkin RAM that has heatsinks.
    Any of you guys know of a cooler that would work without too much hacking?
    • 31196
    Re: Need CPU Cooler Advice
    fit a flange and a 120mm fan with higher cfm but lower rpm.
    a lot of modding sites sell 70-80, and 80-120 / 92-120 adapter flanges.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      my ex-friend had a spin q on his phenom II. he was happy with it. it oc'd really well. quiet, too.
      sigpic
      (Insert witty quote here)
      • shadow
        • Feb 2007
        • 732
        You may be lucky with the Noctua...I was! I had roughly 2mm gap between RAM heatsink and CPU cooler.
        • washu
          • Jul 2009
          • 310
          Anything by Scythe should work fine and be much quieter. I have a Kama Angle and my ram has heat sinks and they don't interfere. Make sure you get one with a PWM fan so that it will be quieter while your CPU is idle.
          • Maxxarcade
            • Jul 2006
            • 973
            I would love to do that, but it looks like the fan clips into this heatsink by using a plastic bracket. None of the flanges I found would fit
            • Scenic
              o.O
              • Sep 2007
              • 2642
              i'm kinda happy with my Arctic Freezer 7 Pro (Freezer 64 Pro is the AMD version).
              keeps my overclocked Quadcore (C2Q Q6600 @ 3,2) quite cool for not being as big as a shoebox..
              pretty quiet too (PWM controlled via mainboard)
              the intel version comes with pushpins () but i got that sorted out with the scythe 775 CPU Cooler stabilizer kit (out with the pushpins, in with the backplate and screwed-down cooler )
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                http://www.newegg.com/Product/Produc...82E16835200038
                I know, I know, rosewill, but it's actually pretty good. Mine with a 5000+ stays at 25C idle, 28-29C full blast. Room temp is roughly 25C. Just don't use the supplied thermal paste, it's not that good. They also tell you to use 1/2 of the syringe, and there's a lot more in it than in the picture. It's pretty liquidy. With your motherboard it would either have the fan facing up or down, not towards the rear fan. Most coolers like this will do that though.
                • Maxxarcade
                  • Jul 2006
                  • 973
                  I might give this one a try, since other people have apparently used it on my board. It also appears to be taller, so it shouldn't have any RAM clearance issues.
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    I just noticed something odd. According to the hardware monitor, both my case and CPU temp are about 49 degrees. How could the CPU be anywhere near ambient temp with the stock cooler? It has to be wrong, because the CPU fan slows down when I remove the side cover from the case.
                    I have a hot fanless Geforce 9600GT, which is probably why my case temp is so high.
                    • Wizard
                      • Mar 2008
                      • 2296
                      Maxxarcade,
                      This is normal for all *aluminum* heatsink. Poor conduction. If you have heat pipe with copper bottom heatsink, the temp lowers by 5 to 8C. That can be significent.
                      Back in the day when melting athlon CPUs was the vogue, I had to search hard and long to find alpha heatsinks, paid petty price for them but WORTH the trouble.
                      Cheers, Wizard
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        Looks like his is the smaller heatpipe heatsink AMD provides with their higher end processors.
                        • Maxxarcade
                          • Jul 2006
                          • 973
                          It is indeed a heatpipe. I'm wondering if what I really need is better airflow through the case.
                          The case has 3 120mm fans running at 1000 RPM or so. There are 2 in the front with filters, and one in the back. Hardly any air goes through them, considering the size.
                          • Wizard
                            • Mar 2008
                            • 2296
                            What kind of this heatsink? This size of heatsink as shown does not qualify as good one even with heat pipe, it looked like it has no copper bottom either and blows down on CPU performs poorly. I tend to go for much larger heatsink. Tower actually with number of heatpipes with fins blown thru sideways towards tower case's back. There are good ones that is not so wide yet good cooling and quiet.
                            I even don't have many fans either and I like quiet.
                            Cheers, Wizard
                            • Maxxarcade
                              • Jul 2006
                              • 973
                              Cheers, Wizard
                              Are you referring to the stock cooler, or the Rosewill one?
                              The stock one does have a copper base if I recall, but it is too small and has poor airflow.
                              Do you have any recommendations for something that will fit, and still be able to clear my RAM chips?
                              • Wizard
                                • Mar 2008
                                • 2296
                                Down blown heatsink is Rosewill?
                                Cheers, Wizard
                                • Maxxarcade
                                  • Jul 2006
                                  • 973
                                  Cheers, Wizard
                                  The one in the picture is the stock one, which I am currently using. That is the one I referred to as the down flow.
                                  The Rosewill would blow down towards the video card or up to the PSU, depending on which direction I install it.
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    Prefered tower cooler is blown to the rear towards rear of case. Get another heatsink.
                                    Cheers, Wizard
                                    • Maxxarcade
                                      • Jul 2006
                                      • 973
                                      Cheers, Wizard
                                      I haven't been able to find any AMD ones that blow to the rear. Probably because of how the mounting holes are spaced for the AM2 platform.
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        There are some that have you mount the heatsink while out of case. Keep looking.
                                        Some reqires taking off AM2/AM3 bracket and installed directly thru the holes with reinforced plate on back of mainboard.
                                        Cheers, Wizard
                                        • BleedCap
                                          OLD Socket 478 custom bracket + NEW generic cooler
                                          by BleedCap
                                          I already posted this on vogons.
                                          Its a 3d printed custom bracket for socket 478.
                                          I used this AM4 bracket as a base design.
                                          Its to be use with cheap generic clip based cpu cooler.
                                          Reason for doing this is:
                                          - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                                          - New generic cooler is cheaper and can use bigger fan (less noise)
                                          I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                                          The processor that I was using is P4 2.4Ghz prescott....
                                          11-05-2023, 08:09 PM
                                        • Jidis
                                          Need T-Con Advice (Vizio P602ui-B3)
                                          by Jidis
                                          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                          09-22-2025, 05:10 PM
                                        • zlr8r
                                          Advice on newer EC chip programming eg. MEC5107-LJ BGA
                                          by zlr8r
                                          Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                                          i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                                          09-16-2025, 09:54 AM
                                        • Ede2001
                                          I am looking for a wiring diagram or boardview EVGA GTX 780 Ti SC w/ ACX Cooler
                                          by Ede2001
                                          I am looking for a boardview file or schematic for the EVGA GTX 780 Ti SC w/ ACX Cooler video card.
                                          08-26-2025, 03:14 AM
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
