Motherboard no powerup, no post, fan not moving, no response everywhere
  • corliq
    • Aug 2009
    • 11
    Last night my friend told me he heard a spark from the PSU when he pressed the switch of the power strip. Then he switched it off immediately. He inspected his computer and found out the PSU had burnt (not in big scale).
    Today I bought a new PSU for him but the motherboard had no response (no fan, no beep, no response at all.) The new PSU should have no problem as it had been tested on another computer. I measured the 5VSB and the multimeter showed that 5V was everywhere on the motherboard.
    Would anyone please tell me if the motherboard was completely malfunction or still repairable? If it could be fixed then what should I do? THe motherboard is a socket 478 Asus and all of the capacitors are either Rubycon or KZE/YXG. No bulge or leaking from the capacitors. All MOSFETs and SMD looks good.
    Thanks in advanced!
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Motherboard no powerup, no post, fan not moving, no response everywhere
    It is entirely possible that the psu took out the motherboard when it blew, what brand was it?
    • corliq
      • Aug 2009
      • 11
      The burnt PSU was GTR, a lot of bulged J.J. and Jackcon cap.
      The motherboard is Asus P4SC-EA. It is a barebone system.
      • NxB
        • Feb 2009
        • 1595
        Mini fuses on mobo?
        • corliq
          • Aug 2009
          • 11
          Where does it usually located and how does it look?
            master hoarder
            • May 2008
            • 12164
            • Bulgaria
            What's the brand of the new PSU? Just because it was tested in another computer doesn't mean much. It could still be another crappy brand waiting to blow up.
            Have you tried:
            - removing the RAM and powering the system without it? (some boards will beep, which means they are posting)
            - resetting the CMOS?
            Also, I'm guessing that this motherboard has a 4-pin 12v CPU connector. If there is one, make sure this is connected to the PSU.
            If the motherboard has on-board VGA, try that first. If not try again with a different video card.
            When everything is plugged in but computer still turned off, does the south-bridge chip on the motherboard feel hot? (normally, it should only feel warm).
            As for fuses, they should be marked with F### (where ### is a number). Should be located either near the ATX connector, CPU connector, or near the CPU capacitors. I doubt those fuses would blow, though (if there are any at all).
            • glovecaps
              Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
              by glovecaps
              I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
              My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
              The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
              11-25-2024, 04:23 PM
            • Docus
              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
              by Docus
              Hi everyone 😀,
              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
              1. I already own the exact same model, but its plastic chassis is badly damaged.
              06-10-2025, 04:24 PM
            • Andreasbest
              HP 400 G2 Power no motherboard but no response from power button.
              by Andreasbest
              Hello.
              I received a HP 400 G2 that receives power on motherboard (the green LED is steady on) but nothing happens when i press the power button, neither if i remove any component (cpu, ram, speaker).
              I have reflashed BIOS with working dumps, tried to reset CMOS and i also eplaced the DC Jack (was a bit loosy) but no luck.
              There are no schematics for DINO motherboard so i guess i'm going against the odds.
              Any help?
              Thanks in advance!
              01-03-2024, 03:11 AM
            • Archimedes
              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
              by Archimedes
              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
              Fans are spinning. Blindly could install windows11 and got the device manager...
              07-30-2024, 05:14 PM
              ASUS P5GC-MX motherboard recap
              by momaka
              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
              So here is what the motherboard looked like with its original caps:
              CPU VRM area up close…...
              01-27-2021, 11:59 PM
