Topcat's Acer Dual Slot 1 Server? - The Acer Altos 1100
  • Topcat
    replied
    Re: Topcat's Acer Dual Slot 1 Server? - The Acer Altos 1100
    I didn't count....but I'm guessing about ~30 rivets just got drilled out....
    Widened out the power button hole.....pic is blurry, I guess the camera was focusing on the background...
    The reason, I didn't like the original power button, it was a flimsy microswitch....and I had plenty of clearance, it won't interfere with the door....I already checked...so enter in an aviation-grade momentary. These are engine starter switches from a larger twin piston engine aircraft (cessna 414/421).
    The system never had a reset....it does now.
    Next will be corrosion removal & paint prep.
    Until later...
  • Topcat
    replied
    ...and let the fun begin!!
    Case internals stripped out.
    The drive rails appear to be some primitive Enlight. I have 3 sets that came with it. I have some Antec solo rails that will fit if I need more.
    Rusty bottom & case floor....looks like it probably was sitting in a leaky basement or maybe a dirt floor barn....no telling over the last 22 years.
    Very little yellowing on the front, that is with the flash on. It won't need the bromine offgassing soup, just a good cleaning.
    Now time to remove the top/side panel.
    Butt shot...
    Feet, fans, and other random hardware....
    Now for the first mod.... The IO plate area was ~1/16th" narrow along the top edge, and the corners were rounded. No way the IO shield would fit. The original was a screw-in that fit internally....so the rear opening size didn't matter if using that....but this is me...
    This was too thin of a margin for the big tools....I had to carve it down with a rough file and squared out the corners....and shazam! Fits now and everything lines up internally and externally.
    The next step is drilling out rivets; further disassembling the case.
  • Topcat
    replied
    Poked through all the found TIF's.... Apparently this machine was owned by a printing/advertising company....nothing but a lot of templates for perhaps business cards, flyers, and stuff like that...nothing exciting and no naked ladies.
  • Topcat
    replied
    Sure do. As long as GPU prices stay obscene, I'm still winning!
    As soon as they're not, I'm dead meat...
    You'll keep your title for quite a while it seems....prices are still batshit crazy and going strong!
    FWIW, lumber has been coming down a bit lately!
  • ratdude747
    replied
    Originally posted by Topcat
    I've got a plan floating around in my head for this.... RD probably has an idea of the core hardware....but that's only part of this build.... Envision very 90's looking on the outside, but internally a bit more modern in more ways than just the core hardware. This will require a full disassembly of the case, every pop rivet drilled out and some serious resto work done.... This case is definitely deserving of something a bit more unusual...
  • Topcat
    replied
  • RJARRRPCGP
    replied
    No, I said DC. Goes through a bridge rectifier on that main board then DC feeds regulators on the second. Its input read 107VDC.
    I don't know, but at least it there's something going to the bridge rectifier.
    I guess I was thinking AC, because of the input before the bridge rectifier, out of a habit, whoops!
  • Topcat
    replied
    107 VAC? That looks very low, if that's not a custom voltage by Delta.
  • RJARRRPCGP
    replied
  • Topcat
    replied
    I had to move this off my bench to work on other things....but poking around the 36gb array, I did find a folder with 11gb worth of TIF's in it. NT doesn't know what to do with them, so I didn't get to see what they are....I'll dump them off when I get some work done and find out.
  • ratdude747
    replied
    Glad you're enjoying...
  • Topcat
    replied
    Many power supplies have written text on the PCB showing what the wires are for, did you check for that?
    That would have been too easy.... Nothing of the sort on this one.
  • Per Hansson
    replied
    There is no voltages present on any of the PSU output pins.... Nothing was jumping out at me as being faulty. Logic tells me that the green wires in the smaller ATX connector would/should have a +5v STBY voltage, as that's the color code for this voltage on a normal ATX PSU, however there's nothing present.
  • eccerr0r
    replied
    the BX board I have does not like "AMD" 256M or 512M SDRAMs that I've started to collect... so they get dumped into 3-slot VIA S370 board, alas this is only 1.5G. Would be nice to put all my 512M SDRAMs into the 4-slot 440BX board. *sigh*
    BTW Linux had a cow when I had a P2-233 and a Celeron-500 in this BX board. It booted but lots of stuff failed spectacularly.
  • Uranium-235
    replied
    see if there is anything juicy scans that were stored. For all you know this might have stored SSN's or belonged to a porn publishing business
  • Topcat
    replied
    Originally posted by eccerr0r
    wish there was an easy way to shoehorn in extra refresh lines so my 440BX dual slot-1 could deal with 512M SDRAMs...
    The P6DGU is a GX chipset (there's a P6DBU that's a BX); which supports 2gb RAM....but is otherwise the same as the BX....it was intended for the P2/P3 Xeon, but Supermicro was being rebellious and built a model that would run the normal P2/P3's.
  • eccerr0r
    replied
  • Topcat
    replied
    I'm still not 100% sure the motherboard is bad. The power supply powers up, has voltage in the primary (AT side is fed by DC voltage from the ATX side; read 107vdc)...but information on this PSU (Delta DPS-280bb Rev 2) is pretty much nill; such as pinouts, standby voltages, schematics, etc..... I have no idea what triggers it, it may be the issue, not the motherboard. I fired the board with an AT power supply, it did power up but did not POST, which is what led me to conclude the board was bad....but that may not be correct.
    Here's a few pics of the PSU inside:
    There is no voltages present on any of the PSU output pins.... Nothing was jumping out at me as being faulty. Logic tells me that the green wires in the smaller ATX connector would/should have a +5v STBY voltage, as that's the color code for this voltage on a normal ATX PSU, however there's nothing present. Yes, I did try it with a good CMOS battery in it; there were some systems from the days of yore that the CMOS battery provided the startup voltage until the PSU fired off and took over....but it wasn't the case here...so odds are this PSU is the issue and the board is good....
  • Topcat
    replied
    Originally posted by Uranium-235
    ah it's not raid, at least hardware. You could probably just hook it up and see the data. Might be something interesting on there
    More fun to boot from it, and here we go!
    The original board on the left and a Supermicro P6DGU on the right....nearly identical core hardware.
    These boards have the same mount points are are the same size.
    The weird proprietary PSU removed.
    A freshly recapped PSU that a local shop gave me...
    Dropped the board in.
    This is a good start!
    All the drives showed up.
    ...and here goes NT4 SP6
    Well fudge....password.
    I rebooted it off another media and cleared the password. Of course a plethora of errors & unreachable network drive paths.
    Reconfig'd everything. The old motherboard has an onboard NIC, this one doesn't....so I added one.
    A few reboots later.....no more errors, in true color, and LAN working.
    ...and like Al Capone's vault, there really wasn't anything to see. This thing was apparently a scan/print server. All data that it handled was stored on one of the network drives, there's nothing really on this machine except the software for some old world legacy scanner.
    So I tossed FF2.0.0.2 on it and yay, BCN!
    The upside, all the drives were checked & verified good, 2x 18gb and 1x 9gb. The 2x 18gb HDD's are in some kind of software RAID, NT shows it as a 36gb volume in disk manager; as a stripe array. Not sure how that was accomplished; as the controller doesn't support any kind of RAID functions whatsoever....so if NT4 supported soft RAID's, I never knew that....so I suppose I did learn something.
    I still haven't solidified what I'll do with this thing.....but this case is screaming out to be a mega sleeper system!
  • Uranium-235
    replied
    Originally posted by Dan81
    All this stuff is really making me want to whip out my P2B and make a nice build out of it.
    careful about whipping anything out here
  • omega
    Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
    by omega
    Hello all,
    as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
    Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
    02-09-2024, 03:34 PM
    by momaka
    03-12-2025, 03:42 PM
    HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
    This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
    09-06-2024, 11:39 AM
  • harp
    Comparing FreeNAS, FTP server, SMB server, multimedia server...
    by harp
    I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
    I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
    Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
    What is general difference between this products, and what be most useful...
    01-04-2024, 02:44 PM
  • Fireballcz
    Windows 2016 server L2TP/IPsec VPN - two subnets
    by Fireballcz
    Hello, please how to properly configure VPN in this environment?
    I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
    Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
    2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
    I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
    I have no problems with VPN connection...
    07-29-2022, 03:20 AM
