Eeepc Linux
  • stevo1210
    • Oct 2006
    • 4156
    Eeepc Linux
    As some of you may know, I recently purchased an Asus Eeepc 701 series notebook with a 4GB SSD that runs on Windows XP.
    Well as you can see 4GB of SSD space is clearly not enough... especially after the fact that only 3.70GB of that 4GB is seen by Windows. Now I'm having space constraint issues... so much so that I only have 3MB of HDD space left even after uninstalling all unneccesary garbage.
    So... that leaves me with only two options... use nlite and slim down Windows XP or switch to Linux. Seeing as I am adventurous at the moment, I want to switch to Linux... in particular, that original Linux that the Eeepc is based on... the one that the Eeepc 701 Linux edition comes with. I don't know the name of that Linux but it might be Xandros or GNU?
    I want to know where I can get a copy of that "original" Linux from... any help would be good.
    Thanks.
  • washu
    • Jul 2009
    • 310
    Re: Eeepc Linux
    The orginal version of Linux is Xandros with a custom interface from Asus. I don't know if you can get it from Asus's website or not.
    I'd suggest Ubuntu Netbook Remix if you want Linux on there.
    http://www.canonical.com/projects/ubuntu/unr
    If you want to run XP you don't have to use nLite at all. The most important thing is to make sure you your install disk is slipstreamed with the service pack you want. SP2 or SP3 as you desire. That will make sure you don't have a huge SP uninstall folder and other backup files wasting space. That alone will save you more space than all but the most extremely stripped nLite install will.
    After you install and run Windows Update delete all the patch uninstall folders out of the Windows directory.
    You can also use NTFS compression and save a lot of space that way. Don't blindly compress everything, just stuff like program files that is mainly read only. On a slow SSD like in the 701 it often makes things faster.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Eeepc Linux
      since it is a 700 series, then i recommend one of the following:
      ubuntu/kubuntu netbook remix
      easy peasy
      eeebuntu (pick a variant)
      crunchbang
      eeexubuntu
      pupeee (if you are daring...)
      i use ubuntu 9.10 desktop on my eee... but it is a 1000HEb with a 160gb hd and 1024x600 screen.
      as for xp, it is really a bad choice for netbooks, nlited or not. uses too much cpu, etc to be productive.
      sigpic
      (Insert witty quote here)
        • 31298
        Re: Eeepc Linux
        forum.
        http://forum.eeeuser.com/
        • stevo1210
          • Oct 2006
          • 4156
          Re: Eeepc Linux
          As much as I'd like to run the Ubuntu netbook remix.... I actually can't because the minimum system requirements is an Intel Atom CPU... my 701 only has a 630MHz Celeron.
          • stevo1210
            • Oct 2006
            • 4156
            Re: Eeepc Linux
            Well um... I actually reinstall XP on this 701 using the "Asus restore CD" that they gave me. Was this a good idea? or does this version have bloated junk too? It's XP Home SP2 from what I can recall.
            • washu
              • Jul 2009
              • 310
              Re: Eeepc Linux
              I can't say for certain, but it sounds like it's a full restore CD and not an XP install CD. When you use it do you get all the drivers and a bunch of software or just XP?
              You need a real XP install CD with your desired service pack. If you don't have a real CD you won't be able to slipstream or nlite it.
              I have a relatively clean XP install with just Firefox and a few other apps on one of my laptops and it is only using about 1.6 GB + swapfile (256 MB). I didn't slipstream it to SP3 so the ServicePackFiles dir is over 500 MB. With a slipstreamed disk a 1 GB install isn't out of reach.
              • stevo1210
                • Oct 2006
                • 4156
                Re: Eeepc Linux
                I have an original Windows XP Home install CD with SP1 from a Dell Dimension 4600... will this be ok?
                • kaniki
                  • 514
                  Re: Eeepc Linux
                  I believe that the dell XP CD's are made for dell systems, as there is still no activation, but not sure if it will work. I know most dell XP CD's that i have run across are more toward the regular XP CD (minus registration) then a restore disk as there is usually a separate disk that has the extra drivers and programs so there is not a lot of extra junk pre-installed on the XP disk. I know that i hve used dell XP disks on other dell systems that did not match the same OS exactly (XP Pro disk with system originally having home) and it worked so it is a possibility. I would say, give it a try, you are not out anything for doing so.
                  • washu
                    • Jul 2009
                    • 310
                    Re: Eeepc Linux
                    That CD probably has a Dell SLC and will not work on an Asus without some hacking. It will install but then it won't activate.
                      • 31298
                      Re: Eeepc Linux
                      how did this thread transform from installing Linux to re-bloating the EE with xp?
                      • washu
                        • Jul 2009
                        • 310
                        Re: Eeepc Linux
                        stevo1210 said his reason for wanting Linux was space issues with XP, something that can be fixed. I gave him advice on both and he continued to ask for assistance with XP. If he asks for further help with Linux then I will help him with Linux.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: Eeepc Linux
                          stj- you're on eeeuser forums? me too!
                          and i agree, xp will not helP him with his problem. xp is bad enough on my dualbooted 1000heb.
                          sigpic
                            • 31298
                            Re: Eeepc Linux
                            no, i'm not on those forums,
                            i dont own an eee - wish i did.
                            i know about the forum because i'v looked at eee's for friends.
                            • weirdlookinguy
                              • Sep 2007
                              • 1638
                              Re: Eeepc Linux
                              I use the Dell OEM XP CD's all the time when wiping client's machines. If it's not being installed on a Dell machine, it will ask you to activate after the install same as an actual (non-dell) XP CD. Since it's the OEM version, it will allow you to use the COA key on whatever OEM machine you are installing it on.
                              • NxB
                                • Feb 2009
                                • 1595
                                Re: Eeepc Linux
                                3.7 with just XP? I used NLITE and pro took up a little over a GB with sp3 and firefox and the drivers.
                                • Maxxarcade
                                  • Jul 2006
                                  • 973
                                  Re: Eeepc Linux
                                  I think Ubuntu Netbook Remix will run on other hardware too. I was able to run it on my Athlon 64 system at work with no issues. Wouldn't hurt to try it.
                                  • kaniki
                                    • 514
                                    Re: Eeepc Linux
                                    I see what you mean by space.. if you dont do updates, then you are fine. i just re-installed a computer with XP Pro w SP3 slip streamed, flash, shockwave, java, latest directx, drivers, .net framework, IE7, and media player 11, updates from microsoft update and avast antivirus.
                                    space used is 5.21 gigs with 2 gigs in pagefile, 300 MB backup in windows folder for patch updates, and 43 MB in the temp folder. with a 512 MB pagefile, removing backups and restore info, and temp folder stuff, that would bring you down to about 3.4 GB used disk space.
                                    That does not leave much to play with and if you use something like norton or McAfee or security suite's instead of Avast then you would use even more. But if you do not do all updates, use home instead of Pro then you use less.
                                    • stevo1210
                                      • Oct 2006
                                      • 4156
                                      Re: Eeepc Linux
                                      In terms of free antivirus... which one has the least space constraints? I use AVG for the eeepc but I have a feeling that takes up too much room?
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Re: Eeepc Linux
                                        comodo is fast... idk the space though.
                                        sigpic
                                          Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook 16 Specification for Upgrade or Repair
                                          This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 05:20 AM
                                        • tsavpyn
                                          Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                          by tsavpyn
                                          Dear all,
                                          I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                          Now I have a problem that I am unable to dump my BIOS into bin file.
                                          My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                          I searched for FPT but there is no Linux version and none of them work.
                                          I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                          I would really appreciate it if anyone...
                                          05-28-2024, 11:18 PM
                                        • mr.malcom
                                          HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                          by mr.malcom
                                          this is a very strange Problem:
                                          Notebook hang instantly on Boot. BIOS is accesable.
                                          Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                          Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                          i have tried:
                                          - only one RAM Stick, another working RAM, both RAM channel
                                          - BIOS Flash to newest Version F.50, BIOS Reset
                                          - Memtest86 hang instant at Test 2
                                          - HP UEFI Diagnostic wont find...
                                          02-26-2022, 05:19 AM
                                        • mkdj
                                          Acer Swift won't boot after a Linux install
                                          by mkdj
                                          Dear all,
                                          I have an issue with an Acer Swift laptop which won't boot (Acer Swift SF113-31-C7UK)
                                          History and symptoms:
                                          A friend of mine tried to install Linux on this laptop. After the installation, the PC did not reboot. When pressing the power button, backlight is working, capslock is working. But screen stays black.
                                          What I have done so far:
                                          As I suspected a BIOS issue, I tried to clean the TXE region, following the winraid guide for CSE TXE 3.1. I managed to do all the steps, including the steps involving the signing process with OpenSSH. The...
                                          10-30-2025, 04:31 AM
                                        • Hondaman
                                          Japanese language -- Win7 or Linux Mint?
                                          by Hondaman
                                          I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
                                          Does anyone have experience...
                                          09-12-2025, 04:32 AM
