Issues with Lexmark driver lead to total inability to print
    Up to this moment I never had a problem with Lexmark printer drivers.
    A few days ago I needed to install drivers for MS415 on several computers.
    Downloaded from the official Lexmark site
    I tried to install them via the installer, using the inf and etc.
    On Windows7 they totally bug out.
    On WindowsXP the install of the driver leads to total inability to print, after the install fails with Operation cannot be completed not only this printer would not work, but if you select properties of any other already installed printer it says something like "Driver cannot be found".
    After this deleting registry keys and driver files from System32 is required to get any printer to work at all.
    With Windows7 it the install either fails or it shows 2 printers, one of which show status = not working properly and the other just will not print.
    Never had such issues with Lexmark printer drivers before. Installing a network printer on multiple computers could totally brick the printing function, not only this printer wont install, but printing using any already installed printer will not work too.
    Is there anyone here that had such an issue and is there anyone that could copy original Lexmark MS415 driver disk?
    It is interesting that MS/MX310 and MS/MX510 install without any problems.
    It's a problem that I encountered just with MS/MX4xx series, more specifically MS415.
    It is one thing to be unable to install the driver, but it's completely different when trying to install it can completely brick Windows printing.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    Re: Issues with Lexmark driver lead to total inability to print
    I always download the latest driver. If the latest installer still refuses to work, use 7zip or another program to decompress the drivers. Try to add it manually, use the network name of the printer, and use the extracted drivers
      There are problems with the latest driver. I tried to install it using the inf file. It doesnt matter how you install it, something with the latest drivers is wrong. Usually the drivers on the install cd are stable.
        All I can think is to do a Google search for previous versions
          Did you try the 2017-version on the Lexmark site?
          https://www.lexmark.com/en_us/printe...S415dn#drivers
          https://www.lexmark.com/content/iss/...RI0012134.html
          https://www.lexmark.com/content/iss/...RI0012135.html
          Be a mensch
            Originally posted by sofTest View Post
            Be a mensch
            not a Schmendrick
              Originally posted by Uranium-235 View Post
              not a Schmendrick
              Yea, sure, that solves the problem for the OP, and all others with Lexmark driver problem. Your solution should be made a sticky.
              Be a mensch
