What should I do with these?
  • c_hegge
    • Sep 2009
    • 5219
    I was recently given an ageing PC with a faulty motherboard and a few missing components. I decided that the motherboard wasn't worth repairing, so I salvaged some parts off it (nothbridge heatsink, clips, caps, sockets, switches, etc).
    My question is what should I do with the caps? The VRM in has Nichicon HD, VRM out has Ruby MBZ and the small 1000uFs are Ruby YXG. They all have 2001 date codes. Should I re-use them since they are reliable brand or just get rid of them because of their age?
    PS. I don't have an ESR or capacitance meter or much cash to buy one with, so I have no means of testing them.
  • everell
    • Jan 2009
    • 1514
    Re: What should I do with these?
    One of the biggest problems with electronics equipment aging is bad capacitors which have bad chemistry. Like an aging marriage, bad chemistry leads to serious problems!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • i4004
      • Oct 2006
      • 2029
      well, at certain time you'll probbly have esr meter, so keep them, if nothing to see how does aging affect them....
      but chances are these caps are ok.
      and will be ok for some time.
      and when they start going bad just reform them.
      so overall it's a nice experiment once you own the esr meter.
      (you can compare them with new ones of same type etc.)
        • 31291
        or they may have dried up with age - even the best have a lifespan.
        • NxB
          • Feb 2009
          • 1595
          Depends on why the mobo broke. I reuse caps all the time of lower quality. Just don't do it in something you put a warranty on or you will have headaches. Being poor its usually better reusing than spending money on old stuff.
          • i4004
            • Oct 2006
            • 2029
            yeah, but that is probably about 40 years....
            ie, you have vintage gear restorers that just reform some mighty old caps and they work again.
            offcourse, if they fail to reform them prior to using them, they go bang!
            • c_hegge
              • Sep 2009
              • 5219
              I'll keep them in my stash of 2nd hand caps. I've used 2nd hand caps before, but not this old. The problem with the motherboard was that when you press the power button (or short the pins) it would power on, POST and then trun off again. I tried other PSU to no avail.
                EBC-X 8-Channels 18650 Battery Capacity Tester Charge & Discharge 10A Aging Test Modificatio
                This is another battery testing machine that needs to be modified for the cooling fans because these are noisy but not as bad as one of the other battery testing machines that I had modified recently because of it being too noisy
                The battery testing machine is going to get two temperatures controlled cooling fans like one I put in the other battery testing machine I just have to remove the temperature sensor and relocate the temperature sensor to one of the heat sinks and put one on the other heat sink so the fan speed can be controlled by temperature
                https://www.eb...
                05-05-2024, 06:07 PM
              • demoncamber
                See any caps here that I should be concerned about on an aging amp?
                by demoncamber
                Just curious, does anyone see any problem caps on my aging amp that I should keep an eye on, are any of these tantalum? Or ones that could potentially go due to age?
                01-03-2021, 01:34 AM
                no-name Radeon 9600 XT recap and cooler
                by momaka
                I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                This one was actually suggested to me by ChaosLegionnaire....
                11-06-2020, 07:54 PM
              • CoppellTVRepair
                Troubleshooting PFC with SPC1012T not raising output
                by CoppellTVRepair
                It has been a long while since I posted here to ask anything....hope you can help.
                I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                03-09-2025, 10:38 PM
              • TrumanHW
                MacOS: R|W Programmers like CH341x BINs..?
                by TrumanHW
                For years I tried figuring out how to R|W BINs from my CH341x programmer.
                From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
                I'd expect many here figured it out (easily), but in case not ...
                It's one of the few forms of "how-to" remuneration I can GIVE BACK.
                This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
                This may be the easiest means to copy-paste:
                Code:
                SERIAL -to- USB - CH341 ROM (MacOS):
                Install xcode:				xcode-select --install
                Relocate
                04-08-2022, 02:33 PM
