See any caps here that I should be concerned about on an aging amp?
  • demoncamber
    • 18
    Just curious, does anyone see any problem caps on my aging amp that I should keep an eye on, are any of these tantalum? Or ones that could potentially go due to age?
  • dmill89
    • Dec 2011
    • 2534
    Re: See any caps here that I should be concerned about on an aging amp?
    The electrolytics all look like "off brand" Taiwanese/Chinese stuff (and 85C rated) that could definitely be suspect. Though audio gear generally isn't too "hard" on caps compared to something like an SMPS so I've seen even "sub par" caps last a long time in audio gear.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Doesn't really look that old. Looks fine to me
      what about the main power board? That is the one you really need to be concerned about. These look like the speaker amps
      • demoncamber
        • 18
        This is an Aragon 2005 THX 5 channel amp from 2003ish era
        No power board just these suckers lol
        Better view of the caps, black ones are Hitano and the blue ones say what seems to be AE
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          Wow. Looks so clean. Is that a linear PSU? Ohh it has a pre-amp and those are the full speaker output amps
          yeah that looks fine. High quality shit there
          • demoncamber
            • 18
            It does sound really good, this is my highest quality amp I've ever owned so I don't really have anything to compare it to sound wise to know how good it is. But it's pretty awesome. It does sound good. It does 200w per channel at 8 ohms 3 channels driven per specs, not sure what it puts out in 5 channel mode, so I was thinking of upgrading the big power caps coming off the toroidal since it's 46000uf right now, looks like 23,000uf goes to each side of amp boards. I was thinking of doing something like 2 45,000uf caps instead of the same brand.
            But even with these caps, if I power off the amp music will keep.playing for 14 seconds before the caps start to fully drain.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I read you can use a bleeder resistor, but have more or less no clue how to implement it on this type of amp. Another solution is to turn off the pre-amp before you turn off the main amp
              • demoncamber
                • 18
                Oh yeah, probably, it doesn't bother me though, I have it in a trigger outlet so it powers down when I shut my AVR off, so you can hear the caps drain and kind of fizzle out softly in the speakers after about 14 seconds. It's not loud enough to be annoying though.
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
