Backup advice needed
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    So I have data that I've archived to tape. I have 2 sets of tapes, both containing identical data. However, there's a couple of different ways for how I could split the sets of tapes up. My plan is to delete the now-archived data off of my hard drive once both sets of tapes are into storage.
    Should I have both sets of tapes onsite or have one set onsite and have the other set offsite?
    6
    Both sets of tapes onsite
    0%
    0
    One set of tapes onsite, the other set of tapes offsite
    0%
    6
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Backup advice needed
    If you will be referring to the data, best leave it where it is -- rather than having to "recover/restore" from tape (inconvenient).
    If you don't NEED the space that deleting it would free up, then leave it where it is (even if you don't need to reference it).
    Tape has a nasty habit of "failing to restore"... and, this only turns up when you actually NEED to retrieve something.
    [I've used virtually every "pro grade" tape medium from 9T through LTO's. Friends would look at my media closet and swear that I had personally altered the location of magnetic north!!]
    I rarely keep anything offsite -- despite having a sh*tload of IP archived, here. What I *do* is ensure it is not easy for me to TRY more than one backup volume (i.e., have a problem with one and then TRY the other) until I am positive the problem isn't in the hardware/OS/software.
    E.g., presently, my dual backup copies (all on spinning rust) are located just a few feet from each other. Yeah, if the house catches fire I'm screwed. But, I'll have far bigger problems, at that point, than recovering files!
    [I keep the REALLY important stuff on a "precious" drive and the really REALLY important *paperwork* (financial, etc.) on a thumb dive. The thinking being that I can hopefully remember to grab those two things on my way out the door -- whether for a fire or natural disaster]
    • desert-rat
      • Mar 2014
      • 4103
      I guess if are thinking of fire or theft ,ect . you might want to store your copy some where else. I have my stuff on 1 ,2 , and 5 T bite usb drives , but most of my stuff is torrent files and stuff I got from YouTube .
      • petehall347
        • Jan 2015
        • 4433
        • United Kingdom
        back up the tape to 2 hard drives . tapes are not that reliable .
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          One offsite if you've gone to the trouble.
          That said, I haven't bothered. I have a file server (with the main storage using RAID 10) that weekly backs itself up to a 4TB internal backup drive which keeps a couple weeks of images backlogged.
          sigpic
          (Insert witty quote here)
          • brethin
            • Dec 2008
            • 1907
            I often wonder how critical data is,. If you have to ask it can't be that important. Just make a couple of copies to hard drives and dump the tape. tape backups suck.
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              • Bulgaria
              One set offside guarantees you that even if the building is burned down by fire, you will be able to restore the info.
              Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
              1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                Should've said this a while ago, but I'm gonna keep a copy offsite.
                Mods/admins, this thread can be locked.
                sigpic
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  That assumes you have a spare drive and system (along with the backup/restore software) available "offsite", as well.
                  It's much easier to use a more ubiquitous medium (disk) and a *portable* file system format -- so you can recover the contents using a friend's computer (while the firemen are still putting out the blaze at your home)
                  • cekcons
                    g1 assassin Rev 1 bios dump - main and backup needed
                    by cekcons
                    main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                    thanks
                    01-23-2024, 03:26 AM
                  • Hondaman
                    Windows 11 buying advice needed
                    by Hondaman
                    My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                    She does not want to switch to Linux. And she does not want to use a laptop because...
                    04-14-2025, 11:35 PM
                  • mariukonie
                    SONY VAIO PCG-711911M VPCEH2H1E advice about updating BIOS to UEFI needed please!
                    by mariukonie
                    Hi. I can't upgrade to win11 I think it's because my BIOS is without Secure Boot function. The BIOS version is R0180Z9. Can you please advise if it is possible to upgrade BIOS to UEFI for this laptop. Many thanks....
                    05-04-2025, 03:18 PM
                  • rustinjust
                    Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                    by rustinjust
                    My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                    The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                    It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                    I have to turn the tv off and then on again with...
                    09-28-2023, 12:23 PM
                  • Lobell
                    A1466 i7 2.2 Ghz Upgrade Advice needed
                    by Lobell
                    Dear All,
                    I am trying to breathe new life into my wife's 2015 Macbook Air (1.6 Ghz / 4 GB RAM) by upgrading the logic board to an i7 2.2 Ghz with more RAM.
                    That's when the advert below caught my eye: 16GB on the i7 A1466 - that's double what Apple originally put on.
                    I know that this is technically feasible, but has anyone made experiences with it?
                    Do you know and rate the vendor, Yopolean? I am ignorant and don't know them.
                    How did the performance turn out?
                    I hope this is an appropriate question for this forum.
                    09-14-2024, 05:07 AM
