High heat and motherboards
  • brethin
    • Dec 2008
    • 1907
    Im looking for advice, I have a couple of motherboards that need to run in high heat conditions. Room temps of 100F or less and not alot of airflow.
    My question is, are there caps better suited for high temps other than the 105c Elecros that are on the boards now? These are older P4 boards running Prescots so heat is already a issue.
  • c_hegge
    • Sep 2009
    • 5219
    Re: High heat and motherboards
    Polymer (Solid) caps are gennerally more tolerant of the heat than electrolytics, but it's still a bad idea to run a PC at high temperatures with little airflow. Add some extra case fans.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      100F is 37.7C. A 105C cap would do just fine in that situation. If you are really worried about heat, look for the highest life cap you can find. I think it is rubycon that said that for every 10C drop in the temp of a cap, it doubles it's lifespan. So even a short lifespan cap with 2000hr at that temp would be approximately 13,600 hours, and thats at it's full rated voltage and ripple current. On a motherboard, the voltages are usually not over about 2-3 volts. Sometimes as low as about 1.5v.
      • i4004
        • Oct 2006
        • 2029
        that is ambient temp, and those caps around the cpu will be adding heat of cpu(that reaches them) to that...
        depending on the mobo design they can get mighty hot...
        and if that is so, then c_hegge got it.
        solids are more heat resistant.
        he should monitor the caps temp in that ambient, then decide.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          "Every 10C drop in the temp doubles it's lifespan."
          That's universal.
          Nearly every manufacturer mentions that somewhere or other.
          It only applies to Electrolytics though.
          Presumably he means 100F -OUTSIDE- the case.
          Inside the case would probably be 20-30F hotter with poor cooling.
          100F [37.7C] - 13,600 hours = 567 days.
          120F [48.9C] [>10C rise} - <6,800 hours = <283days.
          Unless you want to recap every 8-12 months improve the airflow or switch to polymer.
          Polymer will be expensive because you'll need to do every cap in there including the small ones.
          The lytics in you PSU are of concern too.
          Mann-Made Global Warming.
          - Dr Seuss
          • i4004
            • Oct 2006
            • 2029
            davmax did a good piece on polymers:
            http://www.capsmod.net/forum/viewthread.php?tid=93
