Compaq presario cq71 won't boot to windows 10
  • Motherfinboard
    • May 2020
    • 68
    • United Kingdom
    This is my personal laptop that I did to defrag,cleanup etc. It will now not boot to windows with 2 errors I keep getting. I tried to repair with a ios image from vista,but I pressed install then quickly cancelled it,since then had these to errors and tried lots of recovery programs with no joy. File not found anywhere I have tried.
    Error: file: \boot\bcd with error 0xc000000f
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Compaq presario cq71 won't boot to windows 10
    Download Windows 10 and create a USB stick https://www.microsoft.com/en-gb/soft...load/windows10
    The instructions are here on how to repair the BCD. https://www.ghacks.net/2018/02/05/ho...n-windows-pcs/
    You can't fix Windows 10 with Vista.
    • Motherfinboard
      • May 2020
      • 68
      • United Kingdom
      BCD will not repair. I keep getting access denied with win 10 on usb in CMD.
        • 31047
        • Motherfinboard
          • May 2020
          • 68
          • United Kingdom
          Originally posted by stj
          Is your smiling emoji mean your happy about the failure or did you hack me
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            You should specify the drive to run the command against.
            It is probably trying to run it on the virtual X:\ drive now...
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              LOL...I didn't think Windows10 could be 'fixed' at all....
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
                • 31047
                i'm happy that you now have the opertunity to UPgrade to win7 or Linux
                • Motherfinboard
                  • May 2020
                  • 68
                  • United Kingdom
                  Upgrade to win7 is 10 that bad?. I was on 7 it was the free upgrade to 10 I was using. What about security issues in win7 if no longer supported.
                  X drive was the only option opening in CMD,any idea how to boot to C drive to fix mbr
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    You just switch drive, i.e. by typing C:
                    You can check the available disk letters in diskpart with the command "list volume"
                    And you should because it is very likely to be different from what you expect in the regular Windows environment.
                    • Motherfinboard
                      • May 2020
                      • 68
                      • United Kingdom
                      Will take a look at that tomorrow thanks. I'm sure I got access denied there too in c drive
                      • Motherfinboard
                        • May 2020
                        • 68
                        • United Kingdom
                        Still access denied in drive C: I did find a command to fix boot without access denied,but once pc reboot same issue again.
                        Also the other error now showing is winload.exe and also cannot seem to repair this either.
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3264
                          • Singapore
                          i think it looks like the hard drive may be failing and causing all sorts of errors. hope u backed up all of your data before this...
                          • Motherfinboard
                            • May 2020
                            • 68
                            • United Kingdom
                            Unfortunately no,photos yes, but will loose programs and some files that are not that important. Will try getting some data back once I remove it and fit the new SSD drive.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Check RAM and/or possibly try running PC with a different stick of RAM or maybe even just one stick at a time.
                              I've seen Windows not load and get stuck with "XYZ file not found" because of bad RAM.
                              Faulty HDD is another possibility, though if you've over-written the file and still get the same error, then the HDD is probably not the issue here.
                              • Motherfinboard
                                • May 2020
                                • 68
                                • United Kingdom
                                It all started after a disk cleanup/ defrag. I pulled the battery out half way through the cleanup as I left it over night,so not as to constantly charge it and just left it on DC power. Wouldn't boot next morning and mistakenly thought vista repair would correct the boot,it didn't and I then hit install on vista and quickly stopped it. Never been able to get it back on since. Before this the HDD was tested in crystal disk and gave warnings it was failing,hence me getting a SSD drive to fit.
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  • United Kingdom
                                  looks like defrag killed it to me . you might be able to save the files .
                                  • Motherfinboard
                                    • May 2020
                                    • 68
                                    • United Kingdom
                                    Yeah I think so to. Will try get some files back once I remove it from laptop.
                                      • 31047
                                      maybe your "vista fix" overwrote some system files with older ones from vista!
                                      i know the m$ repair disks (DaRT) do that, they update/overwrite a bunch of system files incase of corruption.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        There seem to be a lot of variables to what could have killed the installation.
                                        I think it's time for a fresh install and transfer of old files (if possible.)
                                        Don't feel bad, though. What TC said is probably right: Win10 can't be fixed anyways.
                                        At least that seemed to be the norm when I was a return stock tech at a computer store here a few years back. If Win10 misbehaved, just reinstall it.
                                        Not like XP and 2K, where I've literally taken files from other installations, copied them over, and BAM, working OS again, lol.
                                        • Pandemic
                                          HP Compaq Presario CQ71 only black light, capslock blinking.
                                          by Pandemic
                                          Hi all, I have HP Compaq Presario CQ71 that only lights up black light on the screen, capslock button blinking when pressed. Its motherboard is "da00p6mb6d0 rev d op67". what do you people suggest I do? I am also having hard time locating the BIOS chip because there are many chips that is similar to BIOS chip around the CMOS battery. Can anybody please provide me the BIOS file and the location of the BIOS chip?
                                          06-23-2024, 01:58 PM
                                        • mr.malcom
                                          HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                          by mr.malcom
                                          this is a very strange Problem:
                                          Notebook hang instantly on Boot. BIOS is accesable.
                                          Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                          Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                          i have tried:
                                          - only one RAM Stick, another working RAM, both RAM channel
                                          - BIOS Flash to newest Version F.50, BIOS Reset
                                          - Memtest86 hang instant at Test 2
                                          - HP UEFI Diagnostic wont find...
                                          02-26-2022, 05:19 AM
                                        • Edson ja
                                          Compaq Presario CQ71 BIOS
                                          by Edson ja
                                          Can someone help me.
                                          I need the HP Compaq BIOS file
                                          Product: Presario CQ71
                                          Model: CQ71-306EI
                                          09-21-2020, 04:53 AM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • eltano4i20
                                          [HELP] SAMSUNG NP270E4E-K01AR
                                          by eltano4i20
                                          1) Error trying to enter the BIOS
                                          --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                          Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                          BOOT PRIORITY ORDER (img-05)
                                          1- Windows Boot Manager
                                          2- SATA HDD
                                          3- NETWORK
                                          4- Debian
                                          2) Error trying to access the BOOT MENU
                                          --> I restarted the notebook and pressed [F10] but the BOOT...
                                          07-04-2025, 12:39 AM
