Funny hibernation problem
    On my new build with a Gigabyte EP45-UD3P motherboard and the famous 550W AcBel, under Windows 7 64-bit, if I hibernate my machine it will turn itself back on in a few hours. I'll hibernate it at night when I go to bed only to find it on in the morning. I'll hibernate it before I go to work and it'll be on when I come back, same thing if I pop online to check my email before school...
    I'll do some snooping around with a multimeter later, but it almost seems as if it's not fully entering S5, which it should because hibernation=save RAM contents to disk and then regular (S5) shutdown. Anybody have any ideas/suggestions? It only happens when I hibernate it, not when I just click "shut down".
    Re: Funny hibernation problem
    get into a elevated command prompt type in
    Code:
    powercfg -requests
    see what's waking it up. i have mine set to sleep/hybrid sleep for media center... maybe you have a psychic computer? lol "ready for use sir"
      Odd - it says an audio stream is currently in use for Realtek HD audio. Is it possible for the integrated sound to somehow be causing this?
        Get out your credit card.
        1-800-CALL-BILL
        I'm not surprised you have a hibernation problem with a new operating system.
        This is not a decent answer, but you are braving a brand new OS, and this is what happens.
          does it list the process responsible for the stream?
          does the same thing happen in standby?
          "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
            Check in device manager for your Realtek HD Audio. In the Power Management tab see if there is an option for "Allow this device to wake the computer". Uncheck it if it's there.
              That and also look at your settings under advanced power settings for your power plan. Also disable windows media player network sharing, that was a big one on my machine that caused my audigy to act up. you should also see if there is something that is using sound besides windows, go to the mixer and it will tell you
                my audigy does this too, usually there is a process using sound that forgot to close. if nothing is running the stream should not be in use.
