A Colossal HDD Failure
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: A Colossal HDD Failure
    Ugh another sick 2TB disk
    Code:
     5 Reallocated_Sector_Ct  0x0033  188  188  140  Pre-fail Always    -    92
    196 Reallocated_Event_Count 0x0032  116  116  000  Old_age  Always    -    84
    197 Current_Pending_Sector 0x0032  200  200  000  Old_age  Always    -    3
    198 Offline_Uncorrectable  0x0030  200  200  000  Old_age  Offline   -    15
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      The saga continues:
      Code:
       5 Reallocated_Sector_Ct  0x0033  051  051  005  Pre-fail Always    -    1050
       9 Power_On_Hours     0x0012  095  095  000  Old_age  Always    -    40489
       12 Power_Cycle_Count    0x0032  100  100  000  Old_age  Always    -    101
      193 Load_Cycle_Count    0x0012  001  001  000  Old_age  Always    -    242918
      196 Reallocated_Event_Count 0x0032  050  050  000  Old_age  Always    -    1075
      192 Power-Off_Retract_Count 0x0032  046  046  000  Old_age  Always    -    65535
      197 Current_Pending_Sector 0x0022  100  100  000  Old_age  Always    -    0
      This is one of three identical disks configured the same way, those load cycles were self imposed, not from power savings...
      The disk is currently *very* slow and is slowing down the RAID5 that it's part of right now. I wonder if I should replace it sooner than later, though if I can find a cheap replacement I should buy one now?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Speeds went back to normal once more...but with a few more bad.
        Code:
         5 Reallocated_Sector_Ct  0x0033  051  051  005  Pre-fail Always    -    1055
         9 Power_On_Hours     0x0012  095  095  000  Old_age  Always    -    40513
        193 Load_Cycle_Count    0x0012  001  001  000  Old_age  Always    -    246393
        196 Reallocated_Event_Count 0x0032  049  049  000  Old_age  Always    -    1080
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Which disk will die first...the above disk or one that has
          Code:
           5 Reallocated_Sector_Ct  0x0033  200  200  140  Pre-fail Always    -    0
           9 Power_On_Hours     0x0032  001  001  000  Old_age  Always    -    75482
           12 Power_Cycle_Count    0x0032  100  100  000  Old_age  Always    -    361
          192 Power-Off_Retract_Count 0x0032  200  200  000  Old_age  Always    -    266
          193 Load_Cycle_Count    0x0032  001  001  000  Old_age  Always    -    628758
          196 Reallocated_Event_Count 0x0032  200  200  000  Old_age  Always    -    0
          197 Current_Pending_Sector 0x0032  200  200  000  Old_age  Always    -    0
          200 Multi_Zone_Error_Rate  0x0008  200  200  000  Old_age  Offline   -    2
          And be d**ned if I have to get a SMR disk because they're cheaper...though I'd think the SMR disk might work fine for the PVR.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Interesting. Seems the flakiness is related to temperature... hmmm....
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              Possible bad connection causing sanity checks to fail?
              Permanently Retired Systems:
              Kooky and Kool Systems
              sigpic
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Seems like it's a specific temperature. Don't know. Also the drive appears to "work" ... just very slow when the ambient temperature is, say, above 70F or so... Below that, it works perfectly.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  BOOTED! Well, normally that's a good thing...except when it got kicked from my disk array! Just noticed my RAID was running degraded.
                  Looks like the disk went to greener pastures. Sort of. It's still "working" (and SMART says "PASSED") alas it's probably time to say goodbye... It only had ~40000 hours on it when it finally got the boot, sigh.
                  I just hotswapped a not-so-great condition WD RE4 for the very sick Toshiba disk (manufactured late 2014) as a stopgap. Currently going through recovery at the moment....I think it will take about 8 hours. The WD RE4 was a RAID1 mirror to another 2TB disk, and that RAID1 was the backup to the current RAID5 - the mirror device was a better lower hour disk and I figure that if I lose the contents of the WD and the main RAID5, I'd still have that younger disk left over as the remaining backup and not gamble whether the WD RE4 was healthy.
                  I still need another disk real soon, and hopefully I can boot off the WD RE4, though probably will need to reinstall grub onto the disk and array...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Bah. I moved that sick Toshiba disk to another machine and ran a nondestructive write badblocks run...
                    Came through clean - no problems reading or writing!
                    Same SMART error log showed up as on the other machine, but the drive worked just fine. Wonder if I should trust using this disk anymore. Currently running it RAID1 with the other array I broke up to put another disk in the main RAID5.
                    • RetroComputingGrotto
                      IBM LTO 7 Tape Drive - Dust Sensors??
                      by RetroComputingGrotto
                      I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                      I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                      09-19-2024, 01:54 AM
                    • puccovelli
                      Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                      by puccovelli
                      Hi all, I hope this is the right place to post.
                      I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                      I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                      1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                      2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                      10-11-2025, 06:30 AM
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      Replaced emmc.
                      Terminal log
                      UART
                      AC_ON
                      E-B
                      FDE enabled
                      06-01-2025, 02:11 AM
                    • ctroxtell
                      Carrier HK50AA063 display controller common failure help
                      by ctroxtell
                      I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                      02-05-2025, 05:31 PM
                    • howardc64
                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                      by howardc64
                      Problem
                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                      Model & Board Pics
                      Conflicting Spec
                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                      https://www.shopjimmy.com/vizio-gj-2k1...
                      10-10-2024, 01:16 PM
