Why Lubuntu?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Why Lubuntu?
    Answering "Why Lubuntu"?"
    I need to install Windows 10 to run a tax program. I installed it last week without any network so it let me create a local account.
    Now I see this article.
    I WILL NEVER use any OS that operates like below. My data is my data and it belongs to me locally.
    Microsoft Wants to do Away with Windows 10 Local Accounts
    https://www.bleepingcomputer.com/new...ocal-accounts/
    As time goes on, it is becoming increasingly clear that Microsoft is trying to make local accounts a thing of the past and push all new Windows 10 users to a Microsoft account.
    Historically, when setting up a new Windows 10 computer, users could choose to create a Local Account (Offline account) or a Microsoft Account.
    A Local Account is one that is tied to the computer, cannot be used to login to other computers, is not integrated into Windows 10 cloud services such as OneDrive and the Microsoft Store, and does not require an email address.
    A Microsoft Account, on the other hand, is associated with a user's email address and ties Windows 10 into all of Microsoft's cloud-based services, including Office, Outlook, OneDrive Xbox, etc.
    By using a Microsoft account, Windows 10 will be more feature-rich at the expense of more visibility into your activity.
    Microsoft makes it hard to create a local account
    Since Windows 10 1903, Microsoft quietly changed the Windows Out-of-box Experience (OOBE) or setup experience so that many users are no longer able to create a local account during set up as they could previously.
    Recently, this change also expanded to international users in India and Germany.
    For those affected, the only way to create a local account during setup is to ... disconnect the computer from the Internet.
    Yes, that's right, Microsoft now makes you disconnect the computer from the Internet to create a local account during setup!
    If you don't want to disconnect your network, then you need to first set up Windows with a Microsoft Account and then when done with setup go into the Windows 10 'Family & other users' settings and create a local account.
    Even that is a bit convoluted as you have to first start the process of creating a Microsoft account and finally on the second screen, be given the option that you wish to create a local account.
    Once a local account has been created, you can delete the original Microsoft account you created during setup.
    Microsoft wants you in the cloud
    As Windows 10 evolves, much of its functionality and features are tied to the cloud and your Microsoft Account.
    Whether it be Your Phone, OneDrive, Office integration, Xbox, and the Microsoft Store, without a Microsoft Account Windows 10 is not as feature-rich.
    Due to this, it makes sense for Microsoft to push users towards a Microsoft account rather than a local one to take advantage of all these integrated services.
    Even more important, though, is all the juicy data that Microsoft can collect from a user utilizing all of their cloud-based services.
    By utilizing a Microsoft account, Microsoft has greater visibility into what you are doing, searching for, and using to improve their software and promote new offerings.
    While much of this data collection can be slimmed down, with our data being treated as currency, the more they can get the better.
    --- begin sig file ---
    --- end sig file ---
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8714
      Re: Why Lubuntu?
      I'm still using Gentoo because of its customization and I don't like reinstalling... but it comes at a heavy CPU/RAM/disk cost. Very heavy cost...
      I still am actively using an install I set up over a decade ago. Closing in on 2 decades. The hardware has changed but the software is still pretty much latest. Hardware had to change because it was getting too slow...
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • 24gsm
        MacBook Pro A1708 install macos fail
        by 24gsm
        hi to all
        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
        after enter to recovery and format hdd 1to .
        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
        can help please
        Serial Number: FVFXP0U0HV2J
        Config Code: HV2J
        Find My Mac: OFF
        04-16-2025, 03:57 AM
      • duwane
        A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
        by duwane
        Hi All.
        Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
        The issue:
        Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
        10-26-2022, 07:02 AM
      • tommy97
        ASUS FA507R - BLOD, cannot install windows
        by tommy97
        I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
        I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
        08-22-2025, 07:55 AM
      • TrumanHW
        MacOS: R|W Programmers like CH341x BINs..?
        by TrumanHW
        For years I tried figuring out how to R|W BINs from my CH341x programmer.
        From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
        I'd expect many here figured it out (easily), but in case not ...
        It's one of the few forms of "how-to" remuneration I can GIVE BACK.
        This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
        This may be the easiest means to copy-paste:
        Code:
        SERIAL -to- USB - CH341 ROM (MacOS):
        Install xcode:				xcode-select --install
        Relocate
        04-08-2022, 02:33 PM
