How do you get this Computer to boot from the Sata HDD with out any IDE HDDs?
HP d530 CMT
Re: HP d530 CMT
it should by default. my dad's did that when i used to run sata on it. be sure that sata is enabled in the bios.sigpic
(Insert witty quote here) -
Re: HP d530 CMT
it is it shows up with the ide hard drives but when i put to sata over ide then it bitchs about it and i cant boot the system jusst says none system disk.My Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™Comment
Re: HP d530 CMT
Is the OS on the IDE drive or the SATA drive. If you are booting from the SATA drive the OS has to be on SATA "boot" drive to work. If it isn't on the boot drive then all the PC will see is a empty nonbootable drive at startup."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
"I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
John Paul Jones
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
Rod SerlingComment
Re: HP d530 CMT
Check BIOS settings.Mann-Made Global Warming.
- Dr Seuss
Re: HP d530 CMT
yeah the OS is on the sata drive theres also a OS on the IDE drive as well but i want the system to run without the IDE drives connected.Originally posted by Junk PartsIs the OS on the IDE drive or the SATA drive. If you are booting from the SATA drive the OS has to be on SATA "boot" drive to work. If it isn't on the boot drive then all the PC will see is a empty nonbootable drive at startup.My Computer.
Re: HP d530 CMT
Did that but no matter what i did i cant get it to work the way i want all i get is none system disk msg.Originally posted by PCBONEZCheck BIOS settings.
My Computer.
Re: HP d530 CMT
Windows XP HOMEMy Computer.
Re: HP d530 CMT
Well i seem to have found my answer not completely what i was looking for but good nuth,My Computer.
Re: HP d530 CMT
i bet the master boot record is not active on the SATA. try re-installing (a retail xp home cd will work, find a torrent, or use a linux cd) and then try again. the bootloadr is only on one drive based on your symptoms. re-installing should fix it. be sure to unplug the ide drive first.sigpic
(Insert witty quote here)Comment
Re: HP d530 CMT
idk i got it doing what i want it to do so i thinks i am going to let it be for now i dont feel like reinstalling windows again this week.My Computer.
Re: HP d530 CMT
Had to copy some files from the other hard drive like the boot.ini file an ntdlr files then edited the boot file and left it blank so now when i start the system it just says invalid boot ini and boots from the C;/windows and thats what i want it to do in the first place.My Computer.
Re: HP d530 CMT
Ok copied the boot.ini from my computer now it works like i wanted it to.My Computer.
Re: HP d530 CMT
good. that works too.
at least it wasnt like in linux where you could install the boot loader on an olg 6gb drive to allow booting to a non-bootable drive (a raid array on a non-bootable card). in that case, both drives must be present for it to work. but then again, linux has cds that let you re-install the boot loader only.sigpic
Re: HP d530 CMT
But it still shows up as E and not CMy Computer.
Re: HP d530 CMT
Not sure if this relates to your problem, but if there's multiple drives installed then this explains how the letters get handed out:
http://support.microsoft.com/kb/51978
That article was written for MS-DOS, but in my experience it's also correct for Windows, including default letters assigned by WinNt/2k/XP/etc.
Under NT series, it's possible to change the drive letters post-install from within the OS, but that can cause problems with programs that think stuff is installed on a different letter.Last edited by gdement; 09-24-2009, 10:16 PM.Comment
Re: HP d530 CMT
re-install or ignore it- it will still screw it up. drive letters is a bit dumb when you think of it... unix-like systems dont use them and we dont get this problem...sigpic
Re: HP d530 CMT
lol i cant even begine to understand all that.Originally posted by gdementNot sure if this relates to your problem, but if there's multiple drives installed then this explains how the letters get handed out:
i installed Windows xp when the other 2 ide drives were hooked up and i now i have disconnected is that why it could still be showing up as E?My Computer.
Re: HP d530 CMT
I may try thrawing in my hard drive from my computer to see what the drive letter shows up as.Originally posted by ratdude747re-install or ignore it- it will still screw it up. drive letters is a bit dumb when you think of it... unix-like systems dont use them and we dont get this problem...My Computer.
by clabrNeed help to solve some problems with this laptop.
After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
Before this had happened I observed some other problems:
When I tried replacing original mecanical HDD with a SSD HDD could not get them... -
by privato89Hello everyone,
I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
Let's begin:
Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the... -
by Luke AndersHi everyone,
A few details about the laptop itself:
Name: Lenovo Legion 5
Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
BIOS Version: GKCN60WW
EC Version: GKEC65WW
Serial Number: PF39AQ7Z
Board Model: NM-D562 Rev 3.0
RAM: 16GB Installed, DDR4 (brand new)
NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
I bought this laptop recently from eBay as a faulty device.... -
by hinisaI'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...-
Channel: Troubleshooting & Designing Networks
by NolesFanHello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...2 Photos
- Loading...
