HP d530 CMT
  • Phaihn
    • Jan 2009
    • 842
    HP d530 CMT
    How do you get this Computer to boot from the Sata HDD with out any IDE HDDs?
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: HP d530 CMT
    it should by default. my dad's did that when i used to run sata on it. be sure that sata is enabled in the bios.
    sigpic
    (Insert witty quote here)
    • Phaihn
      • Jan 2009
      • 842
      Re: HP d530 CMT
      it is it shows up with the ide hard drives but when i put to sata over ide then it bitchs about it and i cant boot the system jusst says none system disk.
      My Computer.
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Re: HP d530 CMT
        Is the OS on the IDE drive or the SATA drive. If you are booting from the SATA drive the OS has to be on SATA "boot" drive to work. If it isn't on the boot drive then all the PC will see is a empty nonbootable drive at startup.
        Mark Twain
        John Paul Jones
        Rod Serling
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: HP d530 CMT
          Check BIOS settings.
          Mann-Made Global Warming.
          - Dr Seuss
          • Phaihn
            • Jan 2009
            • 842
            Re: HP d530 CMT
            yeah the OS is on the sata drive theres also a OS on the IDE drive as well but i want the system to run without the IDE drives connected.
            My Computer.
            • Phaihn
              • Jan 2009
              • 842
              Re: HP d530 CMT
              Did that but no matter what i did i cant get it to work the way i want all i get is none system disk msg.
              My Computer.
              • lucky13
                • Aug 2007
                • 412
                Re: HP d530 CMT
                What OS are on these drives?
                If Vista, you might have to do a boot repair using your vista boot disk.
                • Phaihn
                  • Jan 2009
                  • 842
                  Re: HP d530 CMT
                  Windows XP HOME
                  My Computer.
                  • Phaihn
                    • Jan 2009
                    • 842
                    Re: HP d530 CMT
                    Well i seem to have found my answer not completely what i was looking for but good nuth,
                    My Computer.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Re: HP d530 CMT
                      i bet the master boot record is not active on the SATA. try re-installing (a retail xp home cd will work, find a torrent, or use a linux cd) and then try again. the bootloadr is only on one drive based on your symptoms. re-installing should fix it. be sure to unplug the ide drive first.
                      sigpic
                      • Phaihn
                        • Jan 2009
                        • 842
                        Re: HP d530 CMT
                        idk i got it doing what i want it to do so i thinks i am going to let it be for now i dont feel like reinstalling windows again this week.
                        My Computer.
                        • Phaihn
                          • Jan 2009
                          • 842
                          Re: HP d530 CMT
                          Had to copy some files from the other hard drive like the boot.ini file an ntdlr files then edited the boot file and left it blank so now when i start the system it just says invalid boot ini and boots from the C;/windows and thats what i want it to do in the first place.
                          My Computer.
                          • Phaihn
                            • Jan 2009
                            • 842
                            Re: HP d530 CMT
                            Ok copied the boot.ini from my computer now it works like i wanted it to.
                            My Computer.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Re: HP d530 CMT
                              good. that works too.
                              at least it wasnt like in linux where you could install the boot loader on an olg 6gb drive to allow booting to a non-bootable drive (a raid array on a non-bootable card). in that case, both drives must be present for it to work. but then again, linux has cds that let you re-install the boot loader only.
                              sigpic
                              • Phaihn
                                • Jan 2009
                                • 842
                                Re: HP d530 CMT
                                But it still shows up as E and not C
                                My Computer.
                                • gdement
                                  • Jan 2007
                                  • 690
                                  Re: HP d530 CMT
                                  Not sure if this relates to your problem, but if there's multiple drives installed then this explains how the letters get handed out:
                                  http://support.microsoft.com/kb/51978
                                  That article was written for MS-DOS, but in my experience it's also correct for Windows, including default letters assigned by WinNt/2k/XP/etc.
                                  Under NT series, it's possible to change the drive letters post-install from within the OS, but that can cause problems with programs that think stuff is installed on a different letter.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Re: HP d530 CMT
                                    re-install or ignore it- it will still screw it up. drive letters is a bit dumb when you think of it... unix-like systems dont use them and we dont get this problem...
                                    sigpic
                                    • Phaihn
                                      • Jan 2009
                                      • 842
                                      Re: HP d530 CMT
                                      lol i cant even begine to understand all that.
                                      i installed Windows xp when the other 2 ide drives were hooked up and i now i have disconnected is that why it could still be showing up as E?
                                      My Computer.
                                      • Phaihn
                                        • Jan 2009
                                        • 842
                                        Re: HP d530 CMT
                                        I may try thrawing in my hard drive from my computer to see what the drive letter shows up as.
                                        My Computer.
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • Stefan Steff
                                          HP Elitebook 840 G5 strange behaviour, need ideas...
                                          by Stefan Steff
                                          I finished my work for this year, so I'm free until January 6th.
                                          My last task it's unresolved and I'm looking for ideas for the return in January.
                                          So what's about...
                                          This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
                                          My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
                                          No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
                                          The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
                                          12-24-2024, 05:50 AM
                                        • eltano4i20
                                          [HELP] SAMSUNG NP270E4E-K01AR
                                          by eltano4i20
                                          1) Error trying to enter the BIOS
                                          --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                          Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                          BOOT PRIORITY ORDER (img-05)
                                          1- Windows Boot Manager
                                          2- SATA HDD
                                          3- NETWORK
                                          4- Debian
                                          2) Error trying to access the BOOT MENU
                                          --> I restarted the notebook and pressed [F10] but the BOOT...
                                          07-04-2025, 12:39 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • reformatt
                                          Intel iMacs, 3rd party SSD failures and Fusion setups
                                          by reformatt
                                          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                          12-18-2024, 10:34 PM
