Topcat's Budget Telephone System- Panasonic KX-TA624 Conquest
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Topcat's Budget Telephone System- Panasonic KX-TA624 Conquest
    Originally posted by Topcat
    It was one of the first things I tried long before I dug this POTS system out of the attic. After a few calls on it, the quality made me not pursue it any further.
    Odd. I never noticed any call quality issues. Maybe I'm lucky for once?
    No worries.....we all know your bark is a lot worse than your bite!
    That's the kind of day I've had... but that's for another thread. Or a PM.
    sigpic
    (Insert witty quote here)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      ...or email, whichever you prefer...
      I was up in the attic and found a spool with probably 200ft of cat5 cable on it...
      Originally posted by Curious.George
      Do yourself as favor and make a crib-sheet regarding how to program various features. Most of these systems (esp older ones) are incredibly cryptic about what to do and how to do it -- in addition to knowing the proper lingo ("Camp ON", "Call Group Pickup", "Line Queuing", DID, DLA, "Forced Line Disconnect", "Tandem Calling", etc.)
      Yea, as I mentioned earlier in the thread, programming this thing is a bit complicated....and the manual may as well be written in japanese.... The basic stuff wasn't too bad....but setting up ring groups and other more advance settings seems a bit more obscure to find clear directions for.... For example, an incoming call rings every extension....which right now is fine....but down the road, I'd like it to only ring at a couple extensions and the rest remain silent. Turning the ringers off isn't an option, since I'd like them to ring for the intercom (communication between my shop & house)....but once I figure it all out, some layman's cribnotes are a definite!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        The docs I found for my PBX (Meisei MK440CT) were sparse (mainly "feature lists" published by PBX vendors). I ended up disassembling the code in the microprocessor to figure out what the commands were and their formats, etc. WAY too much work!
        I think a newer "all digital" PBX might be easier to comprehend as mine had hard-wired signal paths (digitally controlled analog) that imposed constraints on what could and couldn't be done -- so (without schematics), a lot of effort went into understanding why THIS worked but not THAT...
        Many alarm systems are equally cryptic. Stupid when you consider how easy it is to add a serial port (or, BT interface!).
        I'm developing a "digital attendant" that interacts with callers to determine if I "need" to be contacted. E.g., because the machine can "listen in" on any conversation, it can learn various callers' speech characteristics -- so, can identify them when they call at a future time. Couple this with rules regarding who/what/when I am willing to be "bothered" and I get the advantage of privacy with "ring through" based on genuine "need" (e.g., if my other half phones, I want the phone to ring regardless of time of day or where I might be at the time. OTOH, if a friend/colleague calls at an inopportune time, just "take a message" -- and don't let the phone ring!).
        I've taken to doing this for every piece of kit that I have to "set up". As I don't expect to be doing that again any time soon, I'm reasonably sure that I will remember some (many?) details that will eat my lunch at that future date!
        (E.g., how to bypass the registration screens on various phones, ebook readers, etc. I've got an iPhone that I'll have to sort that out for, RSN)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          What a crappy, cold, rainy & drab fall day.....so I wasted it snaking the shittiest cable of all through the wall from my office to the wire closet.....
          The crappy part over, and phone working.
          Those awesome 3 monitors, just to make someone get all excited....
          Wall jack.....install clean or don't install at all.
          Now for the workroom. This jack originally was 2x RJ45 connectors with cat5e to each. I 'borrowed' one of the cat5e lines and pulled the RJ45 jack and replaced it with an RJ11 (the wall plate works with either)....and of course pulled the other end in the wiring closet from the LAN switch and patched it into the telco switchboard.
          I wired this back in 2010 when I finished out this room. At some point, I may run an additional/dedicated telco wire, but for now this was the easy way. There's already 4 LAN connections in this room, plus the wifi.....one of the LAN drops could be spared.
          ...and done with this for today!
          So far so good!
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16955
            Some research revealed that there's a Panasonic cordless phoine compatible with this system...I found a used one for 22 bucks.....Ni Cad battery won't hold a charge....but that's fixable.
            Team : 49813
            Join in!!
            Team Stats
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16955
              Just a FWIW, this has been in operation since the creation of the thread.....but I did finally get motivated to clean up the rats nest of wires and tidy everything up.
              Shelves.... That TVS-50 voice system is basically a voicemail system....that I never could seem to get programmed right....so I said fruck it, I'll use the one built into the cellular line.
              ...but atleast the UPS isn't sitting on top of a junk PC case because the wires weren't long enough!
              Brains for the cordless extension.
              PBX all tidied up.
              Even inside this building, that box always has 3 of 4 bars. Never had an issue with it.
              I didn't show the before pics....out of embarrassment.... Not so bad now.
              It was never all that bad inside the cabinet....it's just packed a little tighter with telephone connections in it now.
              ...and that's that!
              Team : 49813
              Join in!!
              Team Stats
              • CapLeaker
                Leaking Member
                • 8000
                the Nortel stuff I have to play with once in a while is older and bigger. I still do have a Nortel NT5B01 and phones kicking around here. In those there are no coin cell batteries. They have Panasonic 1.5F supercaps in there.
                The new Avaya stuff is best programmed via software / laptop and so far haven't had much problems with it, besides programming bugs.
                The old Nortel gear mostly breaks because there is something wrong with the power supply. Easy fixes.
                • SluggerB
                  Help with trying to fix phone that is not charging (Pics inside)
                  by SluggerB
                  I have two TCL A30 phones.
                  Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                  New Phone: Works fine, bought as a donor board to try and repair Old Phone
                  My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                  08-12-2024, 08:11 AM
                • keeney123
                  new OS on a Sonim XP5s phone
                  by keeney123
                  To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                  I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                  05-13-2022, 07:19 PM
                • Nick Nougat
                  Siemens Gigaset DA810A landline telephone with answering machine resets every minute
                  by Nick Nougat
                  I'm posting this here since there does not seem to be a more fitting category.
                  The Device
                  The Gigaset DA810A is a landline telephone with an LCD screen, an answering machine and integrated telephone book. I have the version for the European (i.e. German) market.
                  It has two separate modules that can operate independently of each other: One is the basic telephony part that always works and is powered by the DC voltage coming through the telephone wire. It relies the TEA1110A telephone transmission and dialler chip for that.
                  The 'smart' part of the phone with the answering...
                  04-01-2024, 04:00 PM
                • mikey5791
                  Help with Samsung Galaxy J7 Prime phone
                  by mikey5791
                  Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
                  Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
                  Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
                  Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
                  If tested the...
                  09-15-2021, 07:54 PM
                • Dannyx
                  Cisco IP phone F-up
                  by Dannyx
                  Good day folks. I had a little f-up over at my new shop today and it made me pretty angry, but at the same time it determined me to try and figure out what could've happened there. This is only going to be a speculative discussion since I don't know the exact layout of our network, hence I don't know what's going on past our room. So:
                  The repair shop where I sit is situated in a remote building down the street from the main building. There's a Cisco IP phone in this room, a 7911, like the rest of the company uses. There's obviously some sort of networking going on between the two...
                  11-27-2018, 12:39 PM
