best cheap/free scores 1.1
This is a sticky topic.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: best cheap/free scores 1.1
    Originally posted by stj
    lol
    it looks like it's powered by an onboard 2-stroke engine!!
    Noise-wise, its on par!
    It only took me 3 years to find one of these boards.....me is happy!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Cooler setup looks like someone who wants their daily 5 Ghz or at least close to 4.5 Ghz fix.
      Today's setups also often need hefty VRM cooling.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Remember VRM/chipset heatsinks and fans of the early 2000s?
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Abit IC7 Max 3..... active cooled regulators AND capacitors!
          Team : 49813
          Join in!!
          Team Stats
          • lti
            • May 2011
            • 2548
            Now you get a big block of metal (low surface area) with a plastic cover (blocking airflow) for looks.
            Anyway, that's a nice Xeon system.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Thanks. It came with a pair of 900MHz 2mb L2 CPU's, the fastest supported by this board. Those unfamiliar with Xeons of that era, their L2 caches run @ full speed, unlike their Pentium2 counterparts that only ran @ half speed for the consumer market. Also included was the 1130c raidport controller that the seller said didn't work...but he didn't know the magic trick to these, there's a weird firmware 'marriage' process you have go do before it'll work. Lastly, there is 2gb of ECC memory. I gave very little for this, everything works. It will get recapped, it has a bunch of those phony 'NRSY' caps that SM used back in those days.
              Team : 49813
              Join in!!
              Team Stats
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Originally posted by Topcat
                No retro computer collection is complete without a pentium pro system....
                Picked a junk pile and came out with this:
                New Old Stock...untested, no processors....but there was 2 NIB heatsinks.
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Good luck, most pentium pro's were nuked for digger gold. Pentium II overdrive?
                  sigpic
                  (Insert witty quote here)
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    I found a pair of 200's with 512k L2's for $40....but yea, I'm eyeballing a pair of 333MHz overdrives...but I want to make sure the board is good first... the OD CPU's usually go for ~$100ea.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      today's cheap score was 10 36gb 10k U320 SCA scsi HDD's. Retro builds love these!
                      Team : 49813
                      Join in!!
                      Team Stats
                      • BigTroll
                        • Sep 2010
                        • 1317
                        • LAMBDA SOND
                        #3291
                        picked up a 2003 eMac with 1Ghz G4 and 256 ram will upgrade ram.
                        My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Originally posted by dmill89
                          A Philips DVDR3455H DVD Recorder with 160GB HDD for $3.25 (These regularly sell for $100-$125 on eBay, and sold for $350 back in 2007 when they were new). I got it so cheap because it had a sticky disc tray (sometimes didn't come out when the open button was pressed), but a new belt fixed that and now it is a good as new.
                          It don't even have a 2000s' style PATA ribbon connected to the HDD, even when it looks like it's from 2006! It's apparently got a ribbon that's only UDMA 33 compliant! (The cable looks more like something from 1998, LOL)
                          Arc A770 16 GB
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Today's freebies is a dell dimension 2400....useless as tits on a boar
                            There's a good chance that the PSU has a bulging Elite cap, if not more of those bundles of misery! Elite caps, apparently can't even handle idling at low temps!
                            I made the discovery of a bulging Elite cap in a Dell Dimension PSU of a Dimension 2350 or the like, (probably Bestec, Delta or Lite-On) one day, on July 19, 2012, IIRC. It was a PC that hardly had been used, but was powered on regularly. Mostly idling in Windows or standby, LOL.
                            Arc A770 16 GB
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              #3294
                              (sigh) I just scrapped two shelfs -- 12 drives, each -- of 72GB SCA drives. I've been dumping any SCSI/SCA/FC-AL drives smaller than 146GB, lately, to make room for bigger drives.
                              I'll have to keep my eyes open for any other SCA discards. OTOH, I'm not sure how well drives fare in the mail...
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                They do fine in the mail. I want any/all scsi HDD's in any scsi interface (50-pin, 68-pin, or 80 pin SCA) and any size. retro rigs love 4.3's and 9.1's.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  #3296
                                  How do you pack them? I haven't bought a "mail order" disk in almost 3 decades -- back then, one disk per box, surrounded by a couple of inches of packing material. And, I was never quite sure if I should expect it to work once installed...
                                  I don't think I have any more 50pin drives -- except for 2" drives (which I won't discard any time soon as they are hard to come by). Even the 68pin drives are pretty scarce. I find SCAs in servers, from time to time, but have steadily increased the minimum capacity drive that I'm willing to "pull"...
                                  Even the FC-AL "minimum" is now up to ~300G!
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    antistatic bag and then wrap them a couple times in small bubble wrap, and put them in a box with paper or more bubblewrap. They'll survive.
                                    I'd take 50-pin, but not much demand for them 68-pin and 80 pin sca are the most practical for this era of builds and decent controllers of course. SCA's can be used either with adapters or those dorky 'mobile racks' that were stylish in the 90's..they supported all popular interfaces of the time.
                                    FC.....I havent seen a working fiber channel setup in ages!
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      #3298
                                      But, if shipping 4, 8, 12 of them, this gets pretty bulky. Would you, in that case, treat the "set" as a "megadrive" and pack it as above? Or, would you still treat each drive individually?
                                      My SB2000 uses them. I also see shelfs with them (which is where I pilfer my "spares" from)
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        I just got 10 in a box....it was a little 'girthy', but all was well. wrapped each drive 2 layers of bubble wrap was fine....so stacked, there was technically 4 layers, plus the antistatic bag....packed snug in the box with more bubblewrap so they weren't hitting eachother loosely.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Dan81
                                          SNES-powered
                                          • Oct 2013
                                          • 1866
                                          #3300
                                          Scored this PC. Not bad but definitely not the best either:
                                          ASRock P4V88+ mobo w/ 6 bulged KZGs (recapped)
                                          P4 HT 3GHz Prescott (no wonder why the caps died)
                                          1GB RAM
                                          Radeon 9250 128MB
                                          P&O LC-B400ATX (MAX:400W (yeah right.) gutless wonder
                                          Allied/APEX PC-115 case
                                          Samsung SD-612 DVD-ROM
                                          NEC ND-3540A DVD-RW
                                          Maxtor STM3160215A 160GB 7200RPM.
                                          Windows 7 (italian)
                                          Came with a free Windows 7 DVD as well, but don't know if it's SP1 at all.
                                          Main rig:
                                          Gigabyte B75M-D3H
                                          Core i5-3470 3.60GHz
                                          16GB DDR3-1600
                                          Samsung SH-224AB DVD-RW
                                          Delux MG760 case
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
