advice on heatsinks
    Re: advice on heatsinks
    That fan on the ebay one is a Delta screamer
    It uses that plug because if you put it on a mainboard it would fry the mosfet since it pulls too much current
    And yea, it's loud as hell!
    Sealing it does not improve performance so much when the fan is blowing, as it is here
    For the Alpha though where they recommend sucking then it makes a big difference
    If you buy it you can of course try it yourself and go with what works best
      Think of the noise like a vacuum cleaner whining in your PC. Eeeee.
      Cheers, Wizard
        On top of the MCX370 there's a 6850RPM Papst 612NHH fan. This fan may spin fast, but it's relatively low powered - Papst rate it at 2.9 watts, and I measured it drawing a bit more than 3W. It's remarkably quiet for its speed - a bit louder than the average 4000RPM-ish fan, but not a hair-dryer whine.
        That was found on a review online.
        (http://www.dansdata.com/coolercomp_p5.htm)
          i like papst fans. they actually move air. i have a bunch of tiny ones that move a lot of air for their size. i might get those, since 2 of them is cheaper than 1 of the alphas in the long run
          sigpic
          (Insert witty quote here)
