advice on heatsinks
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    advice on heatsinks
    i need advice on finding good socket a heatsinks for use on a pIII coppermine cpu.
    the case is a sturdy chieftec with 4 80mm fans inside, with a 5th attached onto the ps. i am overclocking the cpu right now from 800 to 826 using the stock cooler:
    but mine has official intel sticker. thats as far as it will go
    i am using an asus cuv4x -e mobo with 1gb ram:
    sigpic
    (Insert witty quote here)
  • gdement
    • Jan 2007
    • 690
    Re: advice on heatsinks
    I have a StarTech FAN370PRO (that's the model)
    which I like. It holds a 60mm fan, which is bigger than most 370 heatsinks.
    It was marketed for Socket 7 and 370. Used it on a P3-866 for a long time. I think I bought it from buy.com but that was a few years ago.
    I've personally never found a socket A heatsink that would fit a 370 without being way too tight. I think they have a different pressure spec but also the clearances might be different. When I tried fitting an AMD stock hsf on a 370 I backed off because it was *extremely* tight. It would have broken the remaining hook on the socket I'm sure, and/or cracked the die.
    edit: Found it at newegg. Surprised it's still available.
    http://www.newegg.com/Product/Produc...82E16835230015
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      i was thinking about one of these:
      http://www.newegg.com/Product/Produc...82E16835150029
      http://www.newegg.com/Product/Produc...82a16835129035
      http://www.newegg.com/Product/Produc...82E16835110009
      sigpic
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        http://www.newegg.com/Product/Produc...82E16835200017
        I have two the thermaltake versions of this. Important to put a good 80mm fan on it, and flip it around so it sucks air though not blow it into it.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          why?
          sigpic
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            oh, and what do you think of the first one? as for the rosewill, it look a bit like overkill- i dont want to oc so much that i have to overvolt it (overvolting kills stuff)
            sigpic
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              I always put my cpu fans pulling air through and not into the heatsink for a couple of reasons:
              Dosen't blow the hot air onto the nb/ram/vrm/caps, more air flow because the fins being so close to the fan cause less air to move through it, blows the hot air into the case so it is more easily exhausted by the rear fan.
              The first one is more meant for small 1 or 2U servers. From the reviews it does pretty good I guess.
              • bgavin
                • Jan 2007
                • 1355
                The Alpha PAL8045 specifically is a sucker, not a blower.
                The point about heat on the VRM caps is well made.
                • gdement
                  • Jan 2007
                  • 690
                  <that's the masscool 5r057b3>
                  This one has a 60x10mm fan... I really don't trust the 10mm thin fans. I've never known of a good one that thin.
                  That StarTech I referred to earlier is a 60x20mm, I expected it to be cheap and die but it still works fine after ~1-2 years of active use.
                  But of course the heatsink is the most important part, as fans can easily be replaced later. The copper on that masscool might be nice to have.
                  broken link
                  <Vantec VA4-7245>
                  Looks like it might be good. I worry about how well it fits on a 370, but they do say it will fit that. Probably optimized for socket A though.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    screw the vantec- soundls louder than hell i heard.
                    370forlife, does the one you mentioned have mounting problems? a review said it bent fins.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      looking at the startech, that one looks small, just my thought
                      sigpic
                      • gdement
                        • Jan 2007
                        • 690
                        It looks smaller to me in the pictures than it really is. It's not huge though. Basically just look at a 60mm fan and you'll know the size.
                        It's probably most comparable to a thunderbird heatsink. It's bigger than my thunderbird heatsink but way smaller than a palomino.
                        Definitely bigger than the intel coppermine heatsinks I've seen. I've never seen a stock tualatin heatsink so can't compare there.
                        The main draw for me was the fan size. Most 370's are only 50mm, and I don't like small fans.
                        Manufacturer claims it will work on any 370 up to 1.4GHz, but I haven't tried it on anything that fast myself so they could be lying. Fastest I've used it on myself was a 1Ghz coppermine, don't remember what the temperature was.
                        I have that rosewill RCX-Z100 on my socket-A machine. I'm surprised if it will fit on a 370 without breaking the hooks off, but I could be wrong.
                        I'd love to find out about a 3-prong 370 heatsink that fits well. I could use one myself.
                        • gdement
                          • Jan 2007
                          • 690
                          Found the startech and measured it.
                          The height is about 1" from base to the fan. The fins on the outside of the fan reach to about 1 3/8". Length/width is basically 60mm (2.36").
                          So yeah, it's fairly small.
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            It was a little tight on a socket 370 1ghz coppermine w/heatspreader, but the heatspreader makes it thicker so that was to be expected.
                            Mine came with the three holed clips, not just one holed clips, so it distributes the tension among the tabs more evenly to reduce clip breaking.
                            But I would bend the clip just a little to make it not-so-tight.
                            **I see the rosewill does come with the same three holed clip that came with my thermaltake verson***
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              370, what mobo, if u remember?
                              sigpic
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                and, if i left the red fan on it, would it still work?
                                sigpic
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3112
                                  That was on a Abit VP6, the fan would work fine, just be better if you got a nice 80mm that would suck air though not blow it through...
                                  Not to mention the fan would be a good one for a case that only has 80mm holes that you want to put a 92mm in.
                                  BTW, does your motherboard still have the stock NB cooler? They didn't have thermal paste on them, just rested up against it basically.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    yes, but with the intel logo. i greased it lightly- just enough to lightly coat the die since more than that insulates the core and makes it overheat
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      hey, what about this one?
                                      http://www.geeks.com/details.asp?invtid=C26&cat=FAN
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        it said:
                                        Socket 370 Intel CPUs up to 2.20 GHz!
                                        damn now THATS overclocking!
                                        sigpic
                                        • AusDuron1000
                                          Asus CUV4X rev 1.03 Schematic Wanted
                                          by AusDuron1000
                                          Hi All,
                                          I'm chasing a circuit schematic for an Asus CUV4x Motherboard.
                                          I purchased the board in 'unknown' condition and it doesn't exhibit any signs of life when testing with known good parts.
                                          The board does not power on - No LED illuminated when ATX power connected. When bridging the PS_ON to Ground at the ATX connector the board will power up however seems to fail early chipset initialization at post code C0
                                          Any help greatly appreciated as I'd love to get this cool 'retro' board back to life to live another 25 years!
                                          06-25-2025, 01:41 AM
                                        • Green Probe
                                          Mosfet Advice
                                          by Green Probe
                                          Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                                          05-22-2025, 10:49 AM
                                        • user234
                                          Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                                          by user234
                                          Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                                          My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                                          I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                                          If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                                          This is...
                                          05-10-2025, 04:25 AM
                                        • artvandalai
                                          Advice on rewiring this stepup transformer?
                                          by artvandalai
                                          I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
                                          01-14-2025, 01:00 AM
                                        • nick122
                                          Chieftec (Delta) GPS-450AA-101 A repair and possible upgrade options?
                                          by nick122
                                          Hi everyone!
                                          I’m trying to diagnose (and perhaps even upgrade) this Chieftec (Delta rebrand) power supply from an old rig
                                          The computer just stopped turning on one day. No explosions, no magic smoke, it just died.
                                          There is no 5vsb, and nothing happens when I try to jump start it, it’s completely dead…
                                          I took it apart and nothing looks out of the ordinary. The fuse isn’t blown and the main cap gets charged (found out the hard way lol)
                                          The caps are mostly ltec with a samxon primary, none of which are bulging
                                          Any ideas what I should look...
                                          01-05-2025, 04:31 PM
