advice on heatsinks
  • shadow
    • Feb 2007
    • 732
    Re: advice on heatsinks
    Yer that is one nice looking heatsink too! Rated for Athlon XP's upto 3000+. I think that will be ample for a 800Mhz P3.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      What the...
      I have those masscool's also, don't get them, they are major junk. The bottoms are poorly machined (they will slice up your die, HUGE think endmill marks) and have a super tight clip. (CRUSH)
      Those are the coolers I bought before I bought the rosewill/thermaltake's. I bought two, and RMA'd them to newegg and they just refunded me and told me not to send them back. At least I got two fans out of the deal.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        i found a good one at my local electronis shop. i didnt buy them now, 20 bucks a pop. they are these:
        http://www.speeze.com/main/fcc_v2.asp?ProdID=245
        they are speeze LightOwl II "™ EEA86B4 fans. no leds in fan on theirs.
        found them when buying a new solder sucker : all aluminum spring powered compact solder sucker. i had to sand a few sharp edges and wd40 the seal, but as long as you regularly clean out the tip after a sucking a large blob, it works like a million bucks.
        sigpic
        (Insert witty quote here)
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by 370forlife
          What the...
          i bought mine a few years back. no problems. no marks on bottom other than from getting thrown into a spare bin. the marks were nowhere close to my core. so forget the all coper thin fan is masscool is bad.
          sigpic
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Speeze is masscool. Check the bottom if you can, it should be smooth. My masscool's I got (same as both the previous you have posted) had very poorly machined bottoms, with deep endmill marks. Not only was this poor for surface area, but it would put big lines and gashes in your die of the cpu.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              they had smooth, mirror bottoms
              sigpic
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Thats what it looked like in the picture, I think the ones newegg got were a bad or early batch or something.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  i do have a speeze s478 with deep cuts. but these seemed better. i don't have the money for that this week (my mom likes to limit how much i spend at the electronics shop)
                  is it a good or bad buy for $20?
                  sigpic
                  • Wizard
                    • Mar 2008
                    • 2296
                    #49
                    I don't like pressed in copper slug like I explained before with this type of heatsink. The heat conduction is limited to 2/8" thick edge around the plug and goes long way around the aluminum heatsink and up the fins.
                    The retail intel heatsink slug is most of the height of the heatsink and radiates to the fins evenly.
                    Other heatsink I like is forged heatsink with large area copper on base with fins aluminum on top.
                    I need to get picture up later.
                    BTW, don't pay 20 bucks for those typical heatsinks, invest around 40-50. This gets you good fan and quality heatsink.
                    Best thing is save up your allowances.
                    Cheers, Wizard
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Dropping 40-50 on a p3 heatsink seams like a waste, if you are going to go that route just save up your money and get a nice p4 or A64 board for cheap and a 3ghz p4 or 3200+ or so are pretty cheap, also.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        they had an all copper one for 32 bucks. but it was a microfin.
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          is there a way to mount an am2 hs on a 370 socket. they looked similar.
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            so, wizard, i wasted my money by buying a replacement p3 board. i should have saved up for 5 years so i can get an appropriately sized one , the size ofman engine block.
                            really, i dont get an allowance exactly. i get things here and there. right now i dont get too much. i dont know how all of you afford fancy water cooled 2000 dollar sytems in this economy, but i certainly cant. i cant get a job because there are no openings. i know i could be a petter repair tech than some of the current ones, but i am still in high school so no dice.
                            take that in consideration with the advice please.
                            sigpic
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3112
                              No one is saying you wasted your money on your p3. They are stable, still pretty fast, cheap, and don't use up nearly as much power.
                              I was just saying if you are going to drop 40-50 on a heatsink just for a p3 (btw i have never seen a $50 p3 heatsink,) they you might as well start saving up for a p4 era computer, you can always get a decent one for about 100-150 dollars.
                              • Wizard
                                • Mar 2008
                                • 2296
                                #55
                                I agree but for now try to find these on ebay.
                                Left to right:
                                Intel retail P3 heatsink, middle is forged heatsink with copper compressed in there (cold weld), right is IBM Netvista PC (this one have nickel-plated copper thick plate glued to the heatsink).
                                Alpha heatsinks do turn up from time to time on ebay and it was only option back then when people needed a GOOD one when K6 and faster socket P3 started to come out, and during athlon era due to rising watts and fans were so bad, heatsinks even worse. Even the thermaltake was no better than Intel's with dual ball bearing fans are not bad and thermaltake only serves to empty your pockets, fan on these were poor.
                                Delta produced good fans as well, NMB, Nidec and few others. Look for these.
                                This forged heatsink I have is what other competitor made that Alpha made for heatsinks.
                                Here's photo of 3 heatsinks:
                                Links of alpha heatsinks back then:
                                http://www.overclockersonline.net/?page=articles&num=46
                                http://www.overclockersonline.net/?page=articles&num=43
                                This will get yoiu started for search for good heatsinks, there are other makers of good heatsinks out there.
                                Cheers, Wizard
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  i already have an emachines with a p4. presscot. replaced the power supply because it had a burned up bestec 250w. charred wires and such. replaced with a modded delta 350. 1.5gb ram. 250gb sata hd
                                  i upgraded the cpu in it from a 3.0ghz 533fsb no ht to a 2.8ghz 800fsb with ht. the heatsink is a massive with thickish fins with plenty of space for between. pwm fan with a duct attached to feed a side case vent. i took the ductoff and flipped the fan. it is all aluminum cooler master.
                                  i like the p3 because it has a video expansion slot (above did not, onboard only), takes ram i already had, and runs ubuntu decently. i dont have 100 bucks for a new computer. there is a reason why i only use crt monitors at my house. there is a reason why the computer above is the fastest thing in the house. also second newest, my eee pc is #1.
                                  so the question is will those speeze fans work or not. im not asking how much to spend or whether i need a new system.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    and the first one doe not match my retai heatsink:
                                    thats my retail one., but mine has the 3rd wire
                                    sigpic
                                    • Wizard
                                      • Mar 2008
                                      • 2296
                                      #58
                                      This black retail heatsink one is very old retail heatsink (had one and not sufficient for PIII 700 and up) and it was used with socket celeron 333-400-500 fsb 66, socket PIII 450-600 or so fsb 100. The later ones is much larger and bare aluminum color.
                                      Cheers, Wizard
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        but will the speeze work or not? for 20 bucks is it a good deal?
                                        sigpic
                                        • 370forlife
                                          Large Marge
                                          • Aug 2008
                                          • 3112
                                          People always get confused with forged heatsinks.
                                          No heatsinks are forged, forging is the process of heating up a piece of steel and essentially banging into the shape desired. No way a machine can forge in the fins, the metal on the bottom in between the fins would be incredibly dense. They are extruded, where they take aluminum stock and force it through a heatsinks shaped die to make a long string of heatsink that are then cut into the appropriate length.
                                          http://en.wikipedia.org/wiki/Extrusion
                                          "Aluminum is the most commonly extruded material. Aluminum can be hot or cold extruded. If it is hot extruded it is heated to 575 to 1100 °F (300 to 600 °C). Examples of products include profiles for tracks, frames, rails, mullions, and heat sinks."
                                          That masscool may be ok,
                                          http://cgi.ebay.com/Athlon-Duron-Pentium-III-socket-A-370-CPU-Heatsink-Fan_W0QQitemZ250461723524QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a50ae9b84&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1234|293%3A1|294%3A50
                                          That looks promising
                                          • AusDuron1000
                                            Asus CUV4X rev 1.03 Schematic Wanted
                                            by AusDuron1000
                                            Hi All,
                                            I'm chasing a circuit schematic for an Asus CUV4x Motherboard.
                                            I purchased the board in 'unknown' condition and it doesn't exhibit any signs of life when testing with known good parts.
                                            The board does not power on - No LED illuminated when ATX power connected. When bridging the PS_ON to Ground at the ATX connector the board will power up however seems to fail early chipset initialization at post code C0
                                            Any help greatly appreciated as I'd love to get this cool 'retro' board back to life to live another 25 years!
                                            06-25-2025, 01:41 AM
                                          • Green Probe
                                            Mosfet Advice
                                            by Green Probe
                                            Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                                            05-22-2025, 10:49 AM
                                          • user234
                                            Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                                            by user234
                                            Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                                            My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                                            I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                                            If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                                            This is...
                                            05-10-2025, 04:25 AM
                                          • artvandalai
                                            Advice on rewiring this stepup transformer?
                                            by artvandalai
                                            I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
                                            01-14-2025, 01:00 AM
                                          • nick122
                                            Chieftec (Delta) GPS-450AA-101 A repair and possible upgrade options?
                                            by nick122
                                            Hi everyone!
                                            I’m trying to diagnose (and perhaps even upgrade) this Chieftec (Delta rebrand) power supply from an old rig
                                            The computer just stopped turning on one day. No explosions, no magic smoke, it just died.
                                            There is no 5vsb, and nothing happens when I try to jump start it, it’s completely dead…
                                            I took it apart and nothing looks out of the ordinary. The fuse isn’t blown and the main cap gets charged (found out the hard way lol)
                                            The caps are mostly ltec with a samxon primary, none of which are bulging
                                            Any ideas what I should look...
                                            01-05-2025, 04:31 PM
