custom/home made gadgets, etc.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    post anything you have made/modified that could be considered a tool or gadget
    note- goldfinger-deviced athlons don't count (not original )
    please post pics
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: custom/home made gadgets, etc.
    to start, this is a modified 20 to 20+4 atx adapter. i added an on/off swiche between green and ground, making it so you can test ps voltages/fans/other devices without a motherboard.
    obviously, it works with 20+4, but also regular 20 (line up green wires)
    sigpic
    • lucky13
      • Aug 2007
      • 412
      Cool.
      I was lazy so I bought one of the el-cheapo tester off ebay. I might fifure out a way to add a switch like you have to do on/off on the p/s good line.
      • KeriJane
        Mac Enthusiast
        • Sep 2008
        • 681
        Well, this was already in the Test Equipment section but I made a home-made gadget....
        The KeriProductions ATX338 Load Tester for ATX Power Supplies.
        It provides a convenient set of fan-cooled resistors to load up a PSU while providing voltage readings and scope outputs. The total load is roughly 338 watts which is enough to cause most PSUs to ramp up the fan speed and more than enough to kill a cheap PSU.
        It works exactly as intended and is a great help for checking Power Supplies.
        The prototype has digital voltmeters. I'm working on an analog version that uses Analog meters and maybe silkscreened markings instead of a stick-on Inkjet label.
        It's not too bad for someone that isn't all that great at electronics, is it?
        Keri
        PS. Thanks to all here for the great advice on how to build and use it, especially Oklahoma Wolf.
        PPS. Oh! I once made a special pliers thing out of a pair of Vise Grips. Well, I did have someone weld it for me but it was my idea. No pics though.
        The More You Learn The Less You Know!
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          me=
          sigpic
          • bgavin
            • Jan 2007
            • 1355
            Is there a special tool to remove those ~!@#$%^ Intel push-pins in Socket 478 brackets?
            Dell uses these to secure the board to their removable metal tray.
            They are a serious bitch to disconnect.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              never seen such pins
              all my socket 478 and 775 uses screws
              sigpic
              • KeriJane
                Mac Enthusiast
                • Sep 2008
                • 681
                Hi Bgavin
                The easiest way to remove the Pins of Pain is to merely push them through from underneath.
                Otherwise, you're left with trying to pry them up from above which is, well, a pain. You might want to modify a really small screwdriver by bending the tip 90°. You probably want to heat the tip first on your stove so it will bend instead of break off.
                Omg! S478..... Don't see too many of those anymore.... except to upgrade.
                Keri
                • Wizard
                  • Mar 2008
                  • 2296
                  that what I do for Pushing these pegs out.
                  Cheers, Wizard
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    yup, another s***-a** intel design
                    like the core2 duo- not until now is releasing the i7... quickpath is SOOOOOO... behind- amd has had hypertransport for... long enough to say intel is lagging behind a bit in the race. in the core 2 days, socket am2+ was rolling baby!
                    intel, get your s*** together
                    sigpic
                    • bgavin
                      • Jan 2007
                      • 1355
                      Yep.
                      This is still a VIGOROUS undertaking.
                      The push-pin is blocked by the end of its outer assembly, so you have to push from an angle.
                      I find these damn things INCREDIBLY tight fitting.
                      Taking a pin punch and hammer to a planar board is so wrong, so many ways.
                      In my earlier life, I was an ASE certified mechanic, so I'm no stranger to building my own tools. A quick pass with the arc-torch provides sufficient heat to bend tools into interesting shapes. I have an old screwdriver bent 90 degrees to function as a lever pry bar. I should cut a slot into the blade so it can grab both sides of the top hat on the pin.
                      S478 retention brackets are ugly, shitty work.
                      If the machine was standard, instead of a Dell, I would replace with a metal screw-down bracket, and Thermalright XP90 cooler. But.. it's a Dell.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        some on the gx270 are very tight.i sometimes put a tiny bit of oil on the center pin from the bottom.let it wick in then push it out.rather not stress the board forcing the pin.
                        i have to watch myself when it comes to force.my friends say i could break an anvil.i break lots of tools too.
                        • bgavin
                          • Jan 2007
                          • 1355
                          KC8, thanks for the tip.
                          I was working a GX270 and found exactly that condition.
                          Ick.
                          Sewing machine oil, or ??
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            better than socket a/370/7/5 where one bad move and the fan clip beaks the socket
                            thats where the socket 478 design comes from. removable clip system allows for better fan support and easier fan removal/installation. if you're lucky, the mobop bracket uses screws not clips... thank god lga775 uses screws without clips
                            sigpic
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              I made a shovel out of a log once. - Power tools weren't allowed.
                              Made my own O-ring extractors out of SS rod.
                              Built a gas furnace out of scrap 1930's furnace parts. Added the safey shut-off and a thermostatic control. [That was back in the '80's. It's still in use.]
                              Made a tool to remove lock ring nuts [big] on power steering gear boxes.
                              I got the bent screwdriver deal too.
                              I made this thing to test model rocket chutes when I was a kid.
                              Cats really don't like being the test weight.
                              Custom made a power steering assembly for a car the never came with PS.
                              [Full power steering with hydraulic cylinders, not 'power assist' like most cars have.]
                              Made my own coil spring compressor. [Automotive / Front End]
                              No one makes one that works for that particular car. Really freakin' BIG springs.
                              I tried the standard tool and snapped two of them [the threaded rod] in half.
                              Made my own bushing press. [Also for suspension work.]
                              Made a bug catcher. Used a box with holes and a light bulb inside.
                              BIG fan in one end blowing into a nylon stocking for the 'collection' area.
                              I also cross pollinated Indian corn and pop corn to get multi-colored pop corn.
                              That takes two growing seasons to get the end product.
                              When I worked in a factory situation I made this clamp that would pinch off 100 PSI air hoses without cutting them so localized air leaks could be fixed without shutting the whole line down. A lot of machines there used air cylinders so there was always some hose somewhere coming apart at the end. [Whoever set that place up didn't believe in marking isolation valves.]
                              Too many to list really.
                              Mann-Made Global Warming.
                              - Dr Seuss
                              • celica
                                • Jul 2009
                                • 12
                                hello all , i m new in the forum , i nnedd to know if the psu checker can to test psu more than 1000 w , thank you very much
                                Keri
                                hello all , i m new in the forum , i need to know if the psu checker can to test psu more than 1000 w , thank you very much
                                • lucky13
                                  • Aug 2007
                                  • 412
                                  That would be the KeriProductions ATX1000. No release date yet....
                                  Maybe KeriJane will come in and let us know...
                                  have you looked at the pictures she posted of her design? You probably just need to add more power resistor so it can sink 1KW.
                                  • celica
                                    • Jul 2009
                                    • 12
                                    hello
                                    look like very good project , i want to know how to making that ...
                                    keri come on
                                    • KeriJane
                                      Mac Enthusiast
                                      • Sep 2008
                                      • 681
                                      Hello.
                                      My little tester is nothing more than a convenient box full of load resistors that are cooled by fans. The important testing is done by Oscilloscope.
                                      I picked the 300 watt range because I felt this to be a good compromise.
                                      300w is adequate to fully load and even overload most Power Supplies used in HP, Dell, Gateway computers.
                                      Even at "only" 330w one must be careful to avoid damaging the power supply. For example, 196w (16A) can be drawn on 12v circuits alone and while not sounding like much this can (and has) kill a PSU.
                                      It also represents the maximum amount of power that any normal single video card computer is likely to draw, so even if a PSU is rated for 500, 700 or even 1,000w it can approximate the most current that is likely to be drawn from it and thus simulate a running system.
                                      Likewise, putting a 330w load upon a 500w PSU may not test it to capacity but will probably stress it enough to give a fair assessment of its condition.
                                      THere is space in the prototype's housing for two more resistors that could put it in the 400w range.
                                      More load would require a larger housing and more powerful fans.
                                      If you would like to build your own, you need to determine what size and type of power resistors to use and how to cool them. Adequate cooling is essential both to prevent dangerous overheating and to reduce the temperature - related de-rating that will reduce the load after the resistors warm up.
                                      Here's a handy site for determining how much power your system uses.... not as much as you would think!
                                      http://extreme.outervision.com/PSUEngine
                                      Have fun,
                                      Keri
                                      PS. In an emergency, the KeriProductions load tester series can be used as a convenient room heater or hair dryer! (or doorstop/paperweight)
                                      • celica
                                        • Jul 2009
                                        • 12
                                        yes i going to bluilt one because i think it is very important now to have a good psu for the computer , and psu are very expensive ... to put in the dustbin lol
                                        i find this link this guy making the same thing like your tester but manage with computer very interressting
                                        so http://www.bearblain.com/psu_test_2.htm
                                        i going to make one but to monotoring all 12v1 , 12v2, 12v3, 5v and 3.3 v
                                        thank you for the idea Keri ...
                                        i m to making little lab for testing all stuff pc
                                          MEDION AKOYA P15645 + MS Office Home&Student 2019 Notebook Specification for Upgrade or Repair
                                          This specification for the MEDION AKOYA P15645 + MS Office Home&Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P15645 + MS Office Home&Student 2019 boardview and P15645 + MS Office Home&Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 05:00 PM
                                          ASUS ZenBook UX3410UF-GV180T + MS Office Home & Student 2019 Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX3410UF-GV180T + MS Office Home & Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX3410UF-GV180T + MS Office Home & Student 2019 boardview and UX3410UF-GV180T + MS Office Home & Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          09-06-2024, 03:21 PM
                                          ASUS VivoBook S330UA-EY033T + MS Office Home & Student 2019 Notebook S13 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook S330UA-EY033T + MS Office Home & Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S330UA-EY033T + MS Office Home & Student 2019 boardview and S330UA-EY033T + MS Office Home & Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...
                                          ASUS VivoBook S406UA-BM013T + MS Office Home & Student 2019 Notebook S14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook S406UA-BM013T + MS Office Home & Student 2019 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S406UA-BM013T + MS Office Home & Student 2019 boardview and S406UA-BM013T + MS Office Home & Student 2019 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...
                                        • ivtec
                                          Home made audio amp help
                                          by ivtec
                                          Hi folks i need some help from the electronics pros on a small audio amp for my old lcd tv that sound is too low on the speakers despite to be on the max volume, i know the issue is on the main board , the only solution is to buy a new board but i don't want to shell out 50 bucks for a board . I have seen in Utube some home made audio amps but i'm weary about those projects, i 've seen a audio buit with an STK audio amp ,. I don't have STK4142, i have STK4273, my question if this is not fake and works can i do it with STK4273 instead of STK4142? thanks https://www.youtube.com/watch?v=BcTZS5Y...
                                          02-04-2024, 10:42 AM
