While at my parents house to watch the super bowl, I raided my old stash again and among other things, found a project that never took off involving old parallel printers.
To start, we have a HP JetDirect 500X triple print server:
You know you've gone old school when there's ThinNet BNC connectors and dip switches:
As old as it is, the RJ45 supports 10/100... so actually still usable on modern networks. Also, it does have a primitive java/active-x based web GUI... which I couldn't make IE11 run for the life of me (security issues and the like). The good news is like all JetDirect servers, it does support Telnet for configuration... easy peasy. Beleive it or not it does actually work perfectly on modern windows clients (all 3 ports!); I set it up and connected to a printer using a tablet running 8.1 x64... Old, but very much still a usable bit of hardware!
To go with it I had an even older (?) Laserjet 4L:
The old toner still works (mostly, see below) and I was able to fire it up, print a few test pages (which mostly worked, see below), and even attempted to print a test page from windows 8 (I think I had the wrong postscript driver as it printed but the page layout was dicked). Brought it home, and no bueno, she's not running. See this thread:
https://www.badcaps.net/forum/showthread.php?p=879090
While troubleshooting it, I discovered that it has a genuine AT&T Parallel jack:
Not sure why, but it also streaks up every page:
Assuming I make it work (or come across another old parallel only laser), that takes care of port 1... but what about ports 2 and 3? Well, here's some ideas:
-obtain an old plotter... they practically give them away sometimes.
-Utilize the two Star dot-matrix printers I'll be getting off my parents the next time I'm at their old house. Both are star units- one is a tractor feed monster from the 80's (they've owned it forever), the other is a letter-size unit that came from a dumpster in the late 90's/early 2000's (worked great and for them was an upgrade from the tractor feed beast). Can Star printer ribbons even be obtained? If so, I may put one or more into use... for lols if nothing else.
I know I'm crazy... but other thoughts or ideas (on what to do with the print server)?
