Re: Weird SSD Issue
If the drive is in "frozen" state (ATA command) and sleeping the drive does not unset it then you can try pulling power to the drive for a second or two, that should clear it
(Frozen status is enabled by the PC BIOS during POST).
However if the drive is encrypted then you first need to clear the encryption key, this is done using a PSID revert, tools for this should exist if the drive supports it.
And the password to do so should be printed on the drive itself.
However a quick Google seems to indicate that this SSD does not support encryption, in that case the issue can not be with the encryption key being set...
Weird SSD Issue
Re: Weird SSD Issue
PM sent... but if anything send it back to topcat if you get it to work since it was his to start.Leave a comment:
Re: Weird SSD Issue
Ratdudde drop it in a envelope and send it to me,. If I get it working I'll send it back to you for free. I have a few tools for OCZ I can't share because they are tied to a certain machine but may be able to help you out.Leave a comment:
Re: Weird SSD Issue
Ohh well....was worth a shot. I wonder what caused it...Leave a comment:
Re: Weird SSD Issue
She's bricked... hdparm keeps kicking back "sg_io bad/missing sense data" errors whenever I try to do anything. Tried on several systems to no avail. From what I read this indicates a failed SSD controller... *trashcan*Leave a comment:
Re: Weird SSD Issue
The first I've heard of that....I used dozens of them in the last 10 years, this one was the first casualty....and it was fine until removed. No idea what went wrong. Whatever happened to it, I probably did it...COntroller is fine, it was just an ICH9 onboard a RoG Maximus Formula....the system is hunky dory with the new one that was cloned off this dead one, and there were no issues prior, just upgraded to a larger one. FWIW, it has ran 24/7/365 for 3~4 years....
Re: Weird SSD Issue
Re: Weird SSD Issue
No, it was not working right when I zapped it with dban. I pulled it out of a system, cloned it with 'clonezilla'. Plugged the new larger target drive into the PC, it booted right up. I put this drive into a laptop I was going to use it in.....BIOS saw it, but windows installer was unable to access it. Couldn't format it, add/remove partitions, etc.....downward spiral since. I even put it back in the system it came from, no bueno....Leave a comment:
Re: Weird SSD Issue
Not sure if relevant but just had a standard drive that wouldn't show on 7 pro. A WD mypassport 1tb for mac. Using linux mint 13 maya xfce 4 it seen it and could format it every which way. Windows wouldn't see it until I installed the WD utility and formatted it with it.Leave a comment:
Re: Weird SSD Issue
Re: Weird SSD Issue
From what I'm reading DBAN doesn't "secure erase" using the ATA instruction... and also the methods it does use aren't recommended for SSDs (due to the way SSD's work compared to a rotating HDD- the methods will kill the wear leveling lifespan among other issues). For SSDs I'm reading the best option is the boot utility made by the SSD OEM (in this case, the OCZ utility listed for this model), which will "secure erase" the drive using the built-in "secure erase" function as per the ATA standard. The setting of a temporary password is part of the standard which is to protect against half-erased drives being read after a malicious party kills power during the erase.
Did the drive work at all before you tried to DBAN it? Or was the DBAN an attempt to fix it (which probably froze due to being locked out)? Or did they add an SSD-rated "secure erase" function to DBAN that my research isn't showing? OCZ drives locking themselves like this isn't unheard of but the usual fix of secure erasing from the OCZ utility didn't work for me.Last edited by ratdude747; 01-28-2019, 02:47 PM.Leave a comment:
Re: Weird SSD Issue
From what I'm reading the utility that was used set a temporary password which was never cleared.
Topcat, what utility did you use to issue the secure write instruction? Once I know that I might be able to go somewhere. In the mean time, I'll try some more common "defaults" and see if I can crack it.Leave a comment:
Re: Weird SSD Issue
If interrupting a secure erase causes passwords, it's on me. After dban fought with it for 10 hours and said there was still 8 days to go, I just shut it off....Leave a comment:
Re: Weird SSD Issue
And you can normally set any password, just not too long, I would try 12 characters. (normally without an existing password)
And if it shows "frozen", put the PC to sleep, with the desktop menu, then wake the PC back up.Leave a comment:
Re: Weird SSD Issue
I think HDAT2 or MHDD32 have options to unlock passwords and to reset the drives.Leave a comment:
Re: Weird SSD Issue
Can't... if you don't have the current password, you can't set the new password. If this isn't the case, please give me the command for such, as all the hdparm stuff I found required the existing password and running off a live arch stick I couldn't get anywhere.Leave a comment:
Re: Weird SSD Issue
This is a piece of cake under Linux. With ATA secure erase, you set the password, then let it complete.Leave a comment:
Re: Weird SSD Issue
Well, it's not really a OCZ this drive, but a rebaged Toshiba drive.
So you might need to use Toshiba's tools for it (if such exists).
If not I've had success with Linux hdparm: https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
However please exhaust all other options before you try that.
For example the MS-DOS utility hdderase.exe is a "safer" tool...
Topcat didn't set it... it set itself due to a glitch of some sort?
Bricked?Leave a comment:
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM -
by ugamazingSo, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not... -
by lukkihapsiAsus Vivobook X515JA Laptop
Issue :
Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
Tried :
Cleaned inside for dust, applied fresh thermal paste. No Change!
Removed keyboard, Trackpad, fingerprint sensor. No Change!
Removed Internal SSD. No Change!
Updated BIOS to latest version. No Change!
Removed battery and pressing power button for 1 minute. No Change!
Weird Part :
Upon turning laptop ON, screen lights up - stays black,
I... -
by tommygun26Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
by Spider1211Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
Backstory:
Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
Power supply draw:
Voltage: 19.40V
Amp draw: 0.006 - 0.007A
Amp draw... - Loading...
