100% cpu with no processes using it
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    My primary hard drive will not go into DMA mode, just PIO mode.
    I've heard somewhere that it can cause your cpu to shoot up to 100% cpu usage. I've been having this problem lately. The cpu usage will shoot up to 50-60% cpu usage (only uses 1 thread at 100%,) and it seems to only happen when a certain program that sounds similar to uflorrent is running.
    Running Process explorer, it shows that it is the hardware interrupts that are sucking up the cpu when the program that sounds like uflorrent is opened.
    Any Ideas?
  • gg1978
    • Dec 2004
    • 431
    Re: 100% cpu with no processes using it
    If you're stuck in PIO mode, the CPU has to mediate every transfer to/from the hard drive directly.. WHether it's 2kB or 2GB. Then again, windows usually does 64K at a time, but whatever.. I'd try reverting back to the standard MS supplied IDE/SATA driver, whatever it may be, and maybe replace the data cable if that doesn't work.. You're really tanking your performance with that kind of thing going on.. I've got a dying Samsung DVDROM drive that's in PIO mode, but i hardly notice it because i just use my DVD burner instead.. I really need to replace it..
    • NxB
      • Feb 2009
      • 1595
      Your driver is messed up. Hard drive or cable could be going belly up but I'd check this first. I had this problem with the via 4in1 drivers a long long time ago. Torrent does a lot of disk accesses which are horribly slow in PIO mode. Windows in general barely runs in pio mode.
      To cause Windows to attempt to reinitialize the protected-mode IDE driver:
      1. Click Start, click Run, type regedit in the Open box, and then press ENTER.
      2. Locate and click the following registry key:
      HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\IOS
      3. In the right pane, right-click the NOIDE value, and then click Delete.
      4. Quit Registry Editor.
      If XP got rid of the NOIDE key try reinstalling the IDE driver or reverting.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        It is because it is stuck in pio mode.
        I have 2 hard drives on this cable, my old 60gig as the slave, and the 80gig as the master, and the 60gig is running in UDMA4, and the 80gig is running in PIO.
        Do you think it is because of my cable?
        • Wizard
          • Mar 2008
          • 2296
          1. What is this board? Does matter.
          2. Always replace the 80 wire IDE cable to confirm and reset the NOIDE and see if it fixes. If not. Replace both hard drives. 60GB and 80GB are bit old drives now. Did you insure that both drives jumper are set to CS? This is requirement of 80 wire cabling setup.
          3. What is your power supply?
          Cheers, Wizard
          • NxB
            • Feb 2009
            • 1595
            Strangely enough I've been setting my drives to master/slave forever and ever and not had a problem. Only had weird issues when both drives were set to CS. A lot of customers come in with it set up this way though.
            I wouldn't say to replace both drives right away. You could upgrade and be stuck with a 500gb with the same problem.
            Run Hiren's boot cd and test the drives, but before you do that replace the cable. Also try testing the drives together and individually.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Cheers, Wizard
              Following NxB's instructions, the VxD entry wasn't in there for some reason.
              >>What is your power supply?<<
              Delta DPS-700
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Har-Har!!!
                It twas el cable.
                • Wizard
                  • Mar 2008
                  • 2296
                  Mainboard model #?
                  Some are notorious to have issues, some good. Is firmware up to date as well?
                  And what is the hard drives models for 60GB and 80GB?
                  Cheers, Wizard
                  • Toasty
                    • Jul 2007
                    • 4171
                    I didn't think you could (or should) mix modes on one cable. Had this problem with older CD ROM drive on same cable with hard drive. Hard drive was dreadfully slow until I moved CD to the other IDE port.
                    Toast
                    Edit: Good, you got it working! What cable type were you using and what did you replace it with?
                    veritas odium parit
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Supermicro X6DAL-G
                      Its working now, was the cable. Switched to a 80pin, its now running both at UDMA-5.
                      The 60gig is a Hitachi 5400rpm 2mb cache, the 80gig is a Western Digital 7200rpm 8mb cache.
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Toast
                        You can mix devices with different modes on the same channel, but both devices will be limited to the speed of the slowest device. That CD drive was probably ATA/33, which would make the HD run at ATA/33, even if it was capable of ATA/100 or more.
                        Ludicrous gibs!
                        • Wizard
                          • Mar 2008
                          • 2296
                          Yeah, what was old cable?
                          Good thing you tried the cable.
                          Cheers, Wizard
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            Cheers, Wizard
                            It was some generic 40pin ide cable from a old compaq, but it was braided.
                            • Wizard
                              • Mar 2008
                              • 2296
                              40 wire cable is PIOx only. 80 wire is *required* when running UDMA and above.
                              This is reasons why I have not run into this issue with this policy.
                              Cheers, Wizard
                              • jpdoe
                                • May 2007
                                • 237
                                message erased.
                                • gdement
                                  • Jan 2007
                                  • 690
                                  Cheers, Wizard
                                  It's not required for ATA33, so that should have worked if the cable was in good shape.
                                  • severach
                                    • Aug 2007
                                    • 1055
                                    The 40 wire cable is suitable for several non-Ultra DMA modes which are plenty fast for most purposes and noticeably better than any PIO mode. The 80 wire cable is only required for the Ultra DMA modes.
                                    http://en.kioskea.net/contents/pc/ide-ata.php3
                                    sig files are for morons
                                    • NxB
                                      • Feb 2009
                                      • 1595
                                      I try to stay away from 40 wire cables. A working 40 is better than a screwed up 80 tho.
                                      • Nama
                                        • May 2009
                                        • 127
                                        I may be completely off here but "System Idle Processes" is supposed to keep your pcu at 99%.
                                        ^Learning to walk on rice paper without leaving a trace,
                                        • kuba2102
                                          Medion Erazer beast x25 freezes and resets only at low CPU usage
                                          by kuba2102
                                          Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
                                          Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...
                                          01-06-2025, 09:14 PM
                                        • ADATA_C008/16GB
                                          10-character number and 4-characters string on USB Standard-A, "male" plug? Meaning and usage?
                                          by ADATA_C008/16GB
                                          I bought "ADATA C008 / 16GB" USB Flash Drive yesterday, and I'm curious about meaning and usage of this 10-characters number and 4-charatcer string on USB Standard-A, "male" plug.
                                          11-10-2024, 11:47 AM
                                        • CapLeaker
                                          TCL 65S450F no logo, bleeping sounds?
                                          by CapLeaker
                                          Got a brand spankin' new TCL 65S450F here. Plugged the TV in and it booted up and wanted a firmware update right away. O.k. I guess it did that or not... I got no forking clue. Came back in 10 mins later and the screen is black, backlights on. The Standby light is blinking and every 10 to 15 seconds makes bleeping noises. That's all she does. Tried a factory reset and that must work as I can adjust the volume of the bleeping and it returns to factory volume afterwards. Also tried big black button with the circle right button on the remote and no go.
                                          EDIT: No bootloop the bleeping...
                                          08-08-2024, 01:37 PM
                                        • howardc64
                                          Samsung UN65NU6950 edge lit TV LED bar after 10k usage hours
                                          by howardc64
                                          Edge lit LED TV has 1/4 section backlight out. Replaced the LED bars and sharing the findings on the original 10k hour LED bar.
                                          These are 6V LEDS (reads ~5.4+ on my LED tester) New bars read about 147V per 1/2 of each bar. Clearly original LED bar has some problems
                                          • One section is 153v with a dead LED so clearly built up resistance
                                          • One section flickers but magically fixed itself after driving individual LEDs. All done with an LED tester so don't know if would work driven by PSU backlight circuit and how long it would last
                                          • Connector pin to test pad resistance is nearly 0 ohms.
                                          07-07-2025, 12:18 PM
                                        • proxneo
                                          Bose Wave I AWRCC1 - intermittent to no sound output - loud popping & crackle sounds
                                          by proxneo
                                          Dear reader
                                          I have been asked to check out a faulty Bose Wave system belonging to a relative. The faulty unit produces loud intermittent pops and crackles. Sometimes there is speaker audio output (FM/AM, CD etc.), most of the time there isn't. This behaviour degraded over time fairly quickly, to the current situation where no sound is put out at all. Gently messing and wiggling wires, connectors or heatsink has no effect in force-replicating the problem. I have little experience in audio repair when it comes to (main)board electronic component faults. Bose repair WAS about 140$ (most...
                                          12-02-2023, 09:27 AM
