100% cpu with no processes using it
+ More Options
Posts
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: 100% cpu with no processes using it
    Right, but when it is your cpu usage should be at 0-1%. This was running at about 50% cpu usage (this cpu has HT so it was only using one thread.)
    • kuba2102
      Medion Erazer beast x25 freezes and resets only at low CPU usage
      by kuba2102
      Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
      Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...
      01-06-2025, 09:14 PM
    • ADATA_C008/16GB
      10-character number and 4-characters string on USB Standard-A, "male" plug? Meaning and usage?
      by ADATA_C008/16GB
      I bought "ADATA C008 / 16GB" USB Flash Drive yesterday, and I'm curious about meaning and usage of this 10-characters number and 4-charatcer string on USB Standard-A, "male" plug.
      11-10-2024, 11:47 AM
    • CapLeaker
      TCL 65S450F no logo, bleeping sounds?
      by CapLeaker
      Got a brand spankin' new TCL 65S450F here. Plugged the TV in and it booted up and wanted a firmware update right away. O.k. I guess it did that or not... I got no forking clue. Came back in 10 mins later and the screen is black, backlights on. The Standby light is blinking and every 10 to 15 seconds makes bleeping noises. That's all she does. Tried a factory reset and that must work as I can adjust the volume of the bleeping and it returns to factory volume afterwards. Also tried big black button with the circle right button on the remote and no go.
      EDIT: No bootloop the bleeping...
      08-08-2024, 01:37 PM
    • proxneo
      Bose Wave I AWRCC1 - intermittent to no sound output - loud popping & crackle sounds
      by proxneo
      Dear reader
      I have been asked to check out a faulty Bose Wave system belonging to a relative. The faulty unit produces loud intermittent pops and crackles. Sometimes there is speaker audio output (FM/AM, CD etc.), most of the time there isn't. This behaviour degraded over time fairly quickly, to the current situation where no sound is put out at all. Gently messing and wiggling wires, connectors or heatsink has no effect in force-replicating the problem. I have little experience in audio repair when it comes to (main)board electronic component faults. Bose repair WAS about 140$ (most...
      12-02-2023, 09:27 AM
    • classicandy
      Dell Inspiron 15 3541, strange CPU usage
      by classicandy
      I have this Dell Inspiron 15 3541 (AMD) with strange CPU (System) usage. I have changed HDD and windows, yet still same. Nothing else has been installed apart from the Windows OS.
      CPU: AMD E1-6010U @1350MHz
      Please Check the images attached...
      04-22-2021, 08:42 AM
