Retrofitting PL/CTCSS into old radios...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I was trying to see how to get CTCSS retrofit into an old 2m radio I got...
    I found a port on the radio that supposedly is used for tone input, so that seems like the best place to inject the tone. The radio supposedly has an internal 1750Hz tone generator but I didn't use that (maybe I should simply change that oscillator's frequency, but will it be accurate enough?). The CTCSS tone seems to be an add on option.
    So I tried my simple DDS signal generator with the radio. The DDS generates a 2.5V offset 2.5V amplitude sine wave, hopefully that won't cause an issue...
    The repeater didn't repeat I probably should stick in a DC blocking capacitor. However I noticed the repeater seemed to trigger when I unkeyed the radio. Oops: *Kerchunk*
    So I tried transmitting to a scanner... I heard the tone and my voice in the scanner just fine!
    Strange, will need to do some more research and experiments...
    • 31087
    Re: Retrofitting PL/CTCSS into old radios...
    there used to be generator pcb's on ebay, not sure about detectors though.
    or how you program them.
    probably best to roll your own with an mcu, and a display.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I guess I don't care about detection at this point, but yeah, that's sort of what I'm doing. I have a homemade audio frequency DDS board using a microcontroller with an R-2R DAC. I use a serial port to program frequency into its EEPROM, and then use it on the radio. (The eeprom is kind of flaky as I don't have brownout protection on the MCU so it self erases once in a while, but it's okay, it transmitted the "default" frequency when it loses its programming just fine, too!)
      I guess it's possible I need to adjust the amplitude though unsure what it needs to be to get it to work. As this is a really crappy DDS I can't adjust the amplitude through software, I'll have to hack up external circuits to adjust it.
        • 31087
        it would be interesting to scope a modern radio to see the level of tone as a percentage of signal.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          And that I might have to do, and luckily I have full schematics to one of the radios I have that has a CTCSS board...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            YES!!! I think I got it finally after a few iterations... I think. My 2m HT now can be used on a repeater!
            The first time I was able to hit the repeater with an experiment, I was ecstatic! Had a hard time hearing on my scanner but someone said they heard me. As an experiment I disconnected the CTCSS tone audio AND IT STILL TRIPPED THE REPEATER! I was completely baffled as to what was going on until I heard someone say that my audio quality was pure awful and with that report, was able to deduce what was going on. It turned out it was drawing so much power that it messed up transmitting... and that was triggering the repeater even without the tone fed into the audio!
            Now this new iteration, at least the tone generator must be hooked into the stream in order for it to work, so that's a good thing I still need someone to report if it sounds any better or worse... I'm still signal cheating too, though I added a control for deviation, it's a pretty awful signal I'm using: hint: odd harmonics galore!
            Hopefully can get someone to comment on it eventually...
            So check off: I finally have a 2m radio that can transmit to a repeater! I still need to figure out how to get my PLL to work so I can get that other 2m radio with its 15W transmitter to transmit on arbitrary frequencies, and likewise it needs the same CTCSS hack to hit a repeater.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Oh stooge, I *knew* something was fishy with a circuit in the radio. Yup, it looks like Kenwood did build in a simple tone generator after all, much like what I had built externally - after seeing a YT video of someone using it, I figured out how to use it, and it seems to work too. It likewise uses a multiturn (?) pot to adjust tone frequency. I just had to flip the switch the other way to use it.
              Oh well, I can still use my hodgepodge on my other radio once the PLL is working Or rather, I should add this functionality into the microcontroller...
              • shelby5041
                clock radio / radio lifespan?
                by shelby5041
                hi
                ive got a modern digital clock radio approx 15yrs old
                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                it uses very little power just a few watts i would imagine that may have something...
                09-14-2024, 03:30 AM
              • UserXP
                Vintage SONY Digital Clock Radio ICF-C12W no audio
                by UserXP
                Dear all,
                I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                My question is, do you know of this brand of capacitors and how bad are...
                07-21-2025, 08:35 AM
              • praveenramavath
                Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                by praveenramavath
                Hello All,
                I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                https://www.hifivision.com/threads/m...-screen.98243/
                Troubleshooting Summary: Majority Internet Radio - Flash Chip
                04-26-2025, 09:08 AM
                HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                09-12-2024, 02:00 PM
              • Omron
                Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                by Omron
                Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                - Tried to unplug radio and plug it back in into power,
                - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                05-23-2024, 01:27 PM
