LPT1 POrt to USB
  • Michael L. Butts
    • May 2009
    LPT1 POrt to USB
    I have a Dell Optiplex GX270 I am trying to connect to a HP Office Jet 6310 All-In-One Printer via a Belkin A,B,C,D Data Switch. I am coming off of the GX270 from the LPT1 port to the switch's LPT1 B side and from the I/O (LPT1) port on the switch to the printer with a LPT1 to USB cable to a USB A to B transgender adaptor. I cannot seem to get the GX270's LPT1 port to recognize the USB device to make it functional. Any suggestions will be greatly appreciated.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: LPT1 POrt to USB
    Um, the 6310 has an ethernet port. I'd sooner set that up than fiddle around with the lpt to usb thing.
    Just a suggestion.
    A man convinced against his will is of the same opinion still.
    • kikkoman
      • Jul 2007
      • 691
      i doubt this will work. i've never heard of LPT to USB adapters, so i guess that adapter of yours is a USB to LPT adapter (emulates a printer port on USB).
      why not use its ethernet port?
      err... late.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • Michael L. Butts
        • May 2009
        My ethernet port is connected to DSL for fax use. But thank you! I have an Intel Pentium Dual CPU connected to the A port and I had to get it to recognize USB devices before it would work, but it is LPT to LPT. I cannot locate a command that would allow the LPT to recognize USB on the Dell.
        • NxB
          • Feb 2009
          • 1595
          Re: LPT1 p0rt to USB
          Another nic is probably cheaper than a USB>lpt adapter.
          You could probably get a USB device that emulates a parallel port. I don't think you can have parallel emulate USB without a LOT of work. The communication method is different (parallel vs serial) and the bandwidth isn't there.
          The cable you have is probably flipped. The usb end is supposed to go into your computer and the parallel end to a device. Thats why you had to use the adapter. If you have a parallel switch and a USB printer they will not connect to each other period.
          • acstech
            GrumpyModerator
            • Jul 2007
            • 1432
            So get a hub / switch.
