Windows 10 reinstall error
  • Fast Alpha
    • Feb 2013
    • 245
    I refreshed then reset Windows 10 home edition. Then this appeared.
    How do i fixit, this keeps popping up.
    RuntimeBroker,exe
    The group or resource is not in the correct state to perform the requested operation.
    http://www.hse.gov.uk/pubns/indg305.pdf
    • 31214
    Re: Windows 10 reinstall error
    lol
    almost as useless as 7656465688755456001-error.
    gotta hand it to those assholes, 4gig of o.s. and they still cant find time for decent error messages.
    • petehall347
      • Jan 2015
      • 4440
      google search saying it happens a lot . couldn't find a solid fix .. its apparently not even needed . but no straight forward way to disable . .
      • diif
        • Feb 2014
        • 6978
        • England
        I'd make a guess at some part of windows update not working, I've seen it quite a bit.
        Download and run the .bat file from here. https://www.tenforums.com/tutorials/...dows-10-a.html
          master hoarder
          • May 2008
          • 12175
          Am I the only one that can't see the (off-site) attached image?
          Oh well, that's why I discourage people from using off-site image hosting. :\
            • 31214
            no, your not the only one.
            i'm usually the first to complain, but this time i didnt even notice there was supposed to be one!
            • Fast Alpha
              • Feb 2013
              • 245
              I wiped the SSD then reinstalled the OS. Fingers crossed.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Well, as far as I can see there is no image attached or linked
                  master hoarder
                  • May 2008
                  • 12175
                  LOL, I guess I am that stupid.
                  Still, the way the first post is written and the way there is a double-space just had me convinced there must have been an image there. As I have a pretty aggressive HOSTs file, it's not the first time I get an image blocked from from ImageHack or other similar crap websites, so I thought this was the case here as well.
                  • japlytic
                    DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                    by japlytic
                    In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                    Tried (only with keyboard/mouse connected):
                    • BIOS + database update
                    • Using latest Windows 11 image built with official image creation tool
                    • Previous setup version for Windows 11 installer
                    • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                    • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                    • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                    06-19-2025, 04:59 PM
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    Replaced emmc.
                    Terminal log
                    UART
                    AC_ON
                    E-B
                    FDE enabled
                    06-01-2025, 02:11 AM
                  • sushilachuthan
                    APC UPS error P13
                    by sushilachuthan
                    one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                    the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                    The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                    We replaced the SCR with new device,, but the device is not power on as expected.
                    Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                    09-26-2025, 09:00 AM
                  • angel35
                    Fujitsu D3445-K11 Random BSOD ACPI BIOS ERROR in Windows 10
                    by angel35
                    An skylake (H110) Fujitsu PC mothardboard (D3445-K11) somethimes can't start...Appear BSOD ACPI BIOS ERROR in Windows 10
                    (like below picture)
                    What can cause somethimes ok, somethimes not good ACPI state? Really strange
                    If ACPI not good the Bios missing information from SMbus like FAN speed Voltages etc
                    Wong Bios IC? Power problem?
                    Wrong status:
                    Good status somethimes:
                    07-27-2024, 04:04 PM
                  • AppleLover123
                    Acer Aspire A515-52G-53PU crashing during windows installation
                    by AppleLover123
                    Hello Guys,
                    got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
                    I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
                    The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
                    when i install windows 10 it goes trough until the restart and at "getting devices ready" it...
                    03-08-2025, 05:05 AM
