What causes Northbridge chips to overheat?
  • jacobean
    • Apr 2009
    On desktop P4 computers aged anywhere from 2-5 years old. I've opened up the case to find the motherboad in perfect conditon, free of dust etc but the mini-heatsink on the board (Northbridge chip I think?) would be extremely hot.
    The systems would freeze continually because of this.
    What causes these "mini-heatsinks" to malfunction and is there any solution?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: What causes Northbridge chips to overheat?
    They need a fan.
    • jacobean
      • Apr 2009
      ok thanks for suggestion but what is the root cause of problem?
      • i4004
        • Oct 2006
        • 2029
        you should of looked at the psus of those machines...you would probably find crappy supply which causes high ripple, and that causes more heat...
        • jacobean
          • Apr 2009
          Thanks i4004.
          But what is the root-cause of this problem?
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            many board mfrs. ASSume that airflow from the hsf will cool the nb.
            often its just a bad design.
            • stevo1210
              • Oct 2006
              • 4156
              Usually I think that the main idea of that Northbridge heatsink is to be passively cooled by the CPU can blowing onto it, but in some cases that doesn't go very well. Though I do suggest you check the PSU in case of ripple and voltage fluctuations. Now if that doesn't help then get a fan for the NB chipset heatsink.
              • i4004
                • Oct 2006
                • 2029
                well, THAT is the root cause if you had cool heatsink when machine was bought, and then hot after 2-5 years...
                then again you probably don't know what was it like when new etc.
                also, i dunno how is northbridge supplied; if it's supplied in a same way as cpu, then badcaps on mobo can cause this overheating and all other sorts of problems...
                another thing to mention is what kc says; bad design...smetimes they just put too small heatsink on the chip...AND yet another thing is that some chips just get warmer than others...
                to solve the issue i would first check psu, then caps on mobo(even if they're not bulging) and then put small fan on chipset sink if the psu and caps are ok...
                • acstech
                  GrumpyModerator
                  • Jul 2007
                  • 1432
                  KC8 is right. Often times it's just bad design. I ran into this many times with Nforce 4 / 570 Asus boards. Often they'll design them so they can use the smallest heatsink possible where it will still function. Problem is, that heat degrades IC's. A temperature that may have worked when it was new may no longer work. The process is called degradation, and it happens to all IC's. It is accelerated by increased voltage (ripple being transient, usually high, voltage) and temperature.
                  You fix this problem in two ways. First, put a bigger heatsink on it, possibly with a fan. That alone might correct the problem. Second, as said above, look at your motherboard caps, specifically around the northbridge chip. If they're a bad brand (see bad caps list) they're suspect. Third, check the caps in your PSU.
                  If you're really ambitious, you can check ripple directly with an oscilliscope.
                  Good luck!
                  A man convinced against his will is of the same opinion still.
                  • NxB
                    • Feb 2009
                    • 1595
                    Nobody has mentioned how most of the heat sinks are attached with crappy sticky tape. After 2 - 5 years i doubt it works well. Pulling it off and applying the thermal grease can damage the bga connection. I've done that (successfully) AND put fans on them before. I think in the scheme of things its planned obsolescence.
                    • i4004
                      • Oct 2006
                      • 2029
                      http://en.wikipedia.org/wiki/Electromigration
                      • acstech
                        GrumpyModerator
                        • Jul 2007
                        • 1432
                        I've heard both. Yes, that is the more correct term in this case.
                        • Wizard
                          • Mar 2008
                          • 2296
                          1. On the northbridges using plastic BGA package with or without round thermal contact molded into it, I often find no heatsink paste or using non-thermal double sided stickers. (Most common on cheap generic boards including MSI and VIA chipset based boards).
                          2. The design of heatsink do matter. Where does air is blown towards? Retail intel heatsink for P4 and L775 blows air in all directions works very well. The ones that only blows in two directions that is not directed at chipsets is a issue.
                          Since when Intel and AMD now have cool running CPUs, I'm using their retail heatsinks and been buying up retail copper core heatsinks that was used on high watt CPUs on other CPUs too with slower fan speed.
                          Cheers, Wizard
                          • bgavin
                            • Jan 2007
                            • 1355
                            Side draft coolers are another problem source.
                            The original VRM was designed for down draft cooling.
                            I use the Rocket V Cooler in my machines.
                            It is cheap, runs quietly, and offers excellent cooling for NB and passive video cards.
                            • ugamazing
                              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                              by ugamazing
                              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                              08-31-2022, 07:34 AM
                            • feherhollo
                              WSON8 NEW Bios Chips READ, ERROR, ETC.
                              by feherhollo
                              I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                              I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                              For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                              11-26-2023, 09:33 AM
                            • piernov
                              NVidia bumpgate
                              by piernov
                              Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                              Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                              May complete this post at a later date with more details.
                              Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                              03-27-2021, 10:34 AM
                            • Prott
                              [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                              by Prott
                              Hello dear badcappers!
                              The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                              Backstory:
                              After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                              If there is a way to narrow down which memory module is faulty it would make my life much...
                              06-03-2024, 12:05 PM
                            • LukeDavis
                              Is there a list of known dodgy ATI Radeon chips?
                              by LukeDavis
                              Hello again! (People are likely going to get tired of seeing posts from me lol)
                              I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                              While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                              1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                              2. ATI Mobility Radeon X1600 and the...
                              02-16-2024, 04:34 PM
