Dell charging issues
  • stevo1210
    • Oct 2006
    • 4156
    I've seen a rash of these recently, usually on Inspiron 1100, 5150 models and I think I also saw one on a Latitude D430. The laptops would function properly off the battery (when the battery still had power) but plugging the AC adaptor did nothing, no charge and no power whatsoever.
    Now this sounds stupid but I want to buy these "dead" Dells with the charging issue and try to fix them for myself, so would this be an easy fix? or should I forget about it? I did search on the net and this does seem to be a common issue with these units, but specifically why and how to fix them, I don't know.
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • severach
    • Aug 2007
    • 1055
    Re: Dell charging issues
    I've fixed some of these by resoldering the chip that gets damaged by the memory cover.
    sig files are for morons
    • stevo1210
      • Oct 2006
      • 4156
      So which chip is this? Oh, and I'm planning to buy an Inspiron 1150 with these issues, but the owner has a spare Inspiron 1100 motherboard lying around, will this board fit in a 1150 chassis? I believe the PSU required is different though? But If I can get the 1150 board running again that would be nice as I'm not very fond of chaninging boards, especially in this case I haven't even got a decent PSU required the 1100 motherboard.
      Thanks.
      • Wizard
        • Mar 2008
        • 2296
        The socket. Fix is replace it or replace mainboard.
        Also check fuses.
        Cheers, Wizard
        • severach
          • Aug 2007
          • 1055
          Dell inspiron 1150 Power problems
          • stevo1210
            • Oct 2006
            • 4156
            Sounds like a big job.... I think I should just forget about it and buy a decent working Dell.
            Anyway, thanks everyone.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              My HP pavilion zd7020us had the same problem where you plug in the charger and it dosen't charge.
              The center pin in the charging port is the problem. It gets pushed back a little every time you plug in the charger, eventually the piece of metal that connects it to the mainboard snaps. I did a cheap fix and just pushed the piece of metal back in with a screw driver, and it found a piece of plastic to wedge up against so it is connected pretty good for not even being soldered. Been working for about 6 months now.
              • lmcancu
                • Oct 2009
                • 158
                would this fix a DELL Inspiron 6000 as well? Did you push the pin in the motherboard socket or on the Charger itself? Do you have a picture of what you did?
                "I've fixed some of these by resoldering the chip that gets damaged by the memory cover."
                Can you show a picture of this. I changed the memory on the 6000. Could I have damaged this chip in the process?
                • yyonline
                  • Jul 2009
                  • 692
                  My bet is on the DC jack. Its very common for these to break, especially in older dells. I usually fix a few of these a month in Dells and other brands of PCs. They're a pain to desolder, so make sure your iron is up to the task.
                  For Dell, there are two styles of jack - the round barrel ones, and the older square-ish ones. A few Dells have been known to use different jacks, however, but those are the two main ones. New jacks of both styles are readily available new on eBay and are fairly cheap. I've found the Foxconn jacks to be more reliable than the Tyco jacks, so keep that in mind when sourcing replacements. I've never found another source for them aside from eBay as they seem to be proprietary to Dell.
                  If its not the jack, it's something in the charging circuitry. However, the fact that it won't even run on power at all strongly points to the DC jack as the culprit. If the charging circuitry is busted, it will usually run on AC power, but won't charge the battery.
                  As for the 5150 - there is a small chip under the bottom cover labeled "C". The C-cover has two plastic tabs on either side. If you push on the C-cover, the plastic tab puts pressure on a chip. This breaks the solder connections, or the chip. Sometimes resoldering brings them back to life, sometimes not. If it comes back to life, break off the plastic tab that puts pressure on the chip to prevent this from recurring. The cover is screwed in place, so the missing tab should not affect the sturdiness of the laptop in any meaningful way.
                  • lmcancu
                    • Oct 2009
                    • 158
                    In my case the laptop (Dell Inspiron 6000) runs off the charger ok, but does not charge the battery properly. The battery is brand new and the laptop is able to run off of it. (It currently has a charge of 45%). In the BIOS, I see the message: "Adaptor unknown" or something like that but the battery doesn't charge although the laptop runs fine off of the charger. Researching this, it could be the DC jack (center pin disconnected from motherboard) or the chip ID in the charger has gone bad.
                    • yyonline
                      • Jul 2009
                      • 692
                      Yep. You have the two primary causes down.
                      I have also seen cases of a bent center pin in the power supply cord, or a disconnected center pin in the cord as a result of repeated flexing. So, the only ways to know for sure if its the jack or power supply is to try another power supply or open the laptop and visually inspect the jack. The visual inspection will catch obvious problems, but it's not a conclusive test. I suppose you can multimeter it too if you can find a leak small enough to fit where the center pin would go.
                      There was one case where I fixed it by cleaning the jack with some isopropyl alcohol.
                      As far as the other cases, it's about 50/50 jack/power supply, so I can't even say one is more likely than the other to be your issue.
                      • smason
                        • 1652
                        I have done power connectors on 2 D800s and an Inspiron 5somethingerother
                        Replacing the part is really easy. Getting to it can be "interesting".
                        The D800 was the worst. Finally got down to the motherboard, and there was an assembly (I forget what) blocking the solder pads of the connector.
                        • Wizard
                          • Mar 2008
                          • 2296
                          Round fat plug is 3 contacts. Center pin is for telling notebook what kind of power brick is.
                          Cheers, Wizard
                          • lmcancu
                            • Oct 2009
                            • 158
                            Was the AC adapator, got a new one off e-bay and battery is now charging
                            • yyonline
                              • Jul 2009
                              • 692
                              Beware of the cheap generic adapters that are all over the place on eBay. If it's a real Dell adapter, great. If it's one of the generic "For Dell" adapters - I've seen those overheat to the point of causing burns when handled, stop working, and in one case melt to a smoky plastic blob. I can't find it now, but someone on here had a link to a site where they opened up one of the generic adapters to look at its internals - which included metal plates to make it feel heavier - and scoped its outputs. It wasn't pretty.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                ebay and replacement laptop psu=shit.
                                get an original!you may get lucky and score a used original for about the same as a crappy "replacement".
                                • yyonline
                                  • Jul 2009
                                  • 692
                                  Even new old stock genuine adapters can usually be found for under $30
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    or in my rare case, free + shipping. ask in the for sale forum... i got 2 dell chargers free that way.
                                    sigpic
                                    (Insert witty quote here)
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      that was in my ebay laptop rant forum (which became my d400 steal thread). the link:
                                      http://www.electricstuff.co.uk/acadapter.html
                                      LOL
                                      sigpic
                                      • lmcancu
                                        • Oct 2009
                                        • 158
                                        Well I suspected it was the ID chip in the adaptor that went bad, and did not want to take a chance on a generic model which may have not included the chip so I made sure to get a genuine DELL adaptor off of ebay (I'm assuming its old stock). It looks pretty authentic (looks exactly the same as the old one I have) and I paid a little more ($19.00) for it so high probability it is an original one from old stock.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Thomasraud
                                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                          by Thomasraud
                                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                          QUOTED
                                          -It works on charger (without battery connected-only charger)
                                          -It works on battery (without charger connected-only battery)
                                          -& it also works when plugged in battery & charger, but it's not charging the battery
                                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                          and..
                                          QUOTE
                                          The IC cannot maintain the input current level
                                          06-28-2022, 06:47 PM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • benwaterson
                                          Main rail / charging circuit issues on Bucky/BenSolo 17859-1 board from Dell Vostro 5581
                                          by benwaterson
                                          Hi All
                                          Been a while since I have been here, and a bit rusty.
                                          I have the above laptop motherboard that was working and now the charging circuit is faulty.
                                          Have 19v in fine until it hits PU4403 - not shorts I can see and thermal cam reveals nothing.
                                          I have swapped out the ISL9538 and also the two mosfets (PU4403 and PU4405). Have 2.8v at the power switch, which pulls low when pressed - charging light comes on and goes straight off
                                          Below are measurements (pin names are per the datasheet for the ISL95338 (couldn't find one for ISL9538,...
                                          05-03-2024, 03:25 AM
                                        • Grucha98
                                          Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
                                          by Grucha98
                                          Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
                                          Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
                                          09-09-2024, 11:22 AM
