D865PERC or D865GBF?
    This used motherboard i got from ebay constantly freezes on me anyone have any clue whats wrong with this thing?
    It was suposed to be D865PERC but aparently its D865GBF? both models are writen on the board what the hell?
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    Re: D865PERC or D865GBF?
    Could my PSU and video card posibly be cousing the computer to constantly freeze up?
    My Computer.
      Does it have a voltage monitor in the BIOS? If so, make sure all voltages are in spec.
        When its running in windows Xp i have intel active monitor and all power meters look normal.
        My Computer.
          A lot of Intel i865 boards ended up with the defective HN and HM.
          Mann-Made Global Warming.
          - Dr Seuss
            What are you doing when it freezes? Run a memory test, does it freeze? Anything get extra hot? Download hiren's boot cd and test with some of the apps. Also try a linux live cd or an XP live cd and see if it freezes.
              These boards are sensitive to bad caps. The row of capacitors behind the CPU and other capacitors around the memory slots, four 100uF in little neat row behind northbridge, and few capacitors around the HOT running regulators near southbridge are your issues.
              Cheers, Wizard
                Like the one i just got?
                My Computer.
                  Only one?
                  I just got 5 in. - Bad shape.
                  I might be able to fix one.
                  The other 4 have holes or melted spots on the chipsets.
                  - Presumably had bad PSUs in use. I dunno their history.
                  - Dr Seuss
                    Only one?
                    i was talking motherboard but sounds like your talking about the psu and mine should be fine its relitivly new.
                    as for i too the advice of creating a boot cd whats it mean if it dont freeze from the boot cd or the mini windows xp in hirens boot cd?
                    My Computer.
                      Cheers, Wizard
                      Thats why i got the mother board from ebay was to replace my old one that had 2 blown caps on it.
                      My Computer.
                        Then get to it recapping the one with blown caps. The one that came from ebay, probably bad (might had been ruined by bad PSU).
                        Cheers, Wizard
                          Is it possible to identify it visually? Got bad system (Intel D865PERLL), but capacitors look fine.
                            Cheers, Wizard
                            ill probley do that but dont want to do it my self i was thinking of sending it in to badcaps for recapping .
                            My Computer.
                              thats the same motherboard i had and i think its a pretty good board in general whats it doing? what issus you having with it or is it just a caps problem?
                              a few years back i was having problems whare it would freez on me all the time im not sure how i fixed it but i think adding more ram to it helped.
                              My Computer.
                                No, I was talking about motherboards.
                                - Dr Seuss
                                  Problem caps are Nichicon and have HN or HN(M) or HM or HM(M) marked on them.
                                  Bad date codes are 2001-2004.
                                  H0311 would be week 11 in 2003.
                                  - Dr Seuss
                                    Fans spinning, otherwise dead system (tested with new PSU, video - all other devices disconnected) - no beeps, blank screen. Either motherboard or CPU, could not test further. So motherboard and CPU were replaced, new system works fine, old parts wait for better times.
                                    Thanks.
                                      Thanks.
                                      oh well that is bad.
                                      My Computer.
                                        ok
                                        My Computer.
